Suzuki Bandit brake upgrade?
mrsteko
PostPosted: 23:30 - 08 Mar 2009    Post subject: Suzuki Bandit brake upgrade? Reply with quote
I own a 98 bandit and have has constant trouble with "stiff" brakes since I bought it. I have added braided hoses and changed the piston and dust seals, but still the calipers seem to stick and make it very difficult to move around. There is nothing else I can do, did suzuki just put shit calipers on this model?
If anyone has any ideas on an upgrade, perhaps a compatible caliper, I'd be very interested in hearing about it.
Cheers,
Stephen.
Theory passed Dec 05 : Practical passed 28th April '06
Bikes : 1999 NSR 125 R (sold)
: 1998 bandit 600
Bezzer
PostPosted: 00:07 - 09 Mar 2009    Post subject: Reply with quote
600 Bandits have calipers with a fixing hole spacing of 63-63mm (can't remember which) only the 600 Teapot and SV650 have the same size spacing and that's because it's the same caliper so you can't really do a straight swop/upgrade other than perhaps getting newer better condition ones.
The bigger bikes with the 4 pot and 6 pot calipers are 90mm fixing, you need adaptor brackets to fit them to the 600, you see them now and again on fleabay or you could get some made if you want to go that route.
mrsteko
PostPosted: 00:23 - 09 Mar 2009    Post subject: Reply with quote
when i measured between the points where the caliper makes contact with the bracket, the measurement was 90mm, and about 10mm less than this on a 2005 bandit.
I don't know where your measurement of 63 comes from but perhaps you may be onto something with the switch over between a different bike's calipers.
Stephen
: 1998 bandit 600
sickpup
Old Timer
PostPosted: 00:28 - 09 Mar 2009    Post subject: Re: Suzuki Bandit brake upgrade? Reply with quote
Hmm maybe you could ask for help from someone who sells this stuff for a living, preferably someone you haven't just tried to insult in another thread. Thumbs Up
https://astor.linuxmasters.info/images/buddy_jesus.jpg
Sometimes I feels I take this internet's business too personally!
sickpup
Old Timer
PostPosted: 00:37 - 09 Mar 2009    Post subject: Reply with quote
Bezzer wrote:
600 Bandits have calipers with a fixing hole spacing of 63-63mm (can't remember which) only the 600 Teapot and SV650 have the same size spacing and that's because it's the same caliper.
Only the later Bandit has this type of caliper from 2000 onwards. The OP's bike uses the earlier type shared with the RF600.
mrsteko
PostPosted: 00:38 - 09 Mar 2009    Post subject: Reply with quote
Um, no thanks,
Didn't want to say anything but I've bought stuff from you before. All I did was to warn that chap in the most subtle way possible. But thank you for your contribution.
Stephen.
: 1998 bandit 600
sickpup
Old Timer
PostPosted: 01:00 - 09 Mar 2009    Post subject: Reply with quote
mrsteko wrote:
Um, no thanks,
Stephen.
I know you have. Heat is the only way to cure that chaps problem, a bike shop wouldn't tell you I will. The seals can handle a pretty high temperature anyway, after all brakes do get very hot.
Problem you are getting is down to the braided lines (no give they feel wooden) and possibly the pistons partially seizing as well as the shafts partially seizing often caused by old grease
mrsteko
PostPosted: 01:07 - 09 Mar 2009    Post subject: Reply with quote
Well whatever he decides to do I would always advise anyone to spend a bit more and go for manufacturers standard parts. Will save you money in the long run and there is a huge difference in the quality.
My problem existed before i had the braided lines fitted but I don't dispute that they may contribute to the problem.
Stephen.
: 1998 bandit 600
PostPosted: 03:32 - 09 Mar 2009    Post subject: Reply with quote
Put a GSXR/TL front end on it, buy a better bike or put up with it.
sickpup
Old Timer
PostPosted: 08:45 - 09 Mar 2009    Post subject: Reply with quote
Stephen.
Hold on, now I'm lost.
I advised him to take a blow torch to something that was seized, I didn't try and sell him anything.
As to the huge difference in quality items like seals actually come from the companies that supply the caliper makers so there should be no difference.
If you had a problem with something you had off of me if asked I would have given a refund so what exactly is going on here? I'm not at all bothered about this being discussed in Public either, how I deal with customers who have problems is an important part of my business. There just seems to be some kind of problem here of which I am not aware.
mrsteko
PostPosted: 16:30 - 09 Mar 2009    Post subject: Reply with quote
No problem at all, I wrote that purchase off a long time ago,
You came to my thread looking for me remember. I only advised someone else not to buy pattern parts as I have in the past and they are largely a waste of money.
I'm believe that is allowed, I would actually consider it a favour, I never mentioned names and I certainly didn't make any attempt to assassinate anyone's character, lol
Good luck,
Stephen
: 1998 bandit 600
Bikeless
PostPosted: 16:40 - 09 Mar 2009    Post subject: Reply with quote
I disagree to a point with the OEM parts thing as i used to buy bearings and stuff,genuine Honda but came in a Koyo box with a Honda motif on also,dealer advised me that the patterns were Koyo too,exactly the same as OEM,different box,just an example.
mrsteko
PostPosted: 17:18 - 09 Mar 2009    Post subject: Reply with quote
Hmm, I see. But as another example I bought piston rings once and I didn't like the look of them, so I bought genuine honda parts and the difference was unreal. The thickness and the build quality of the honda rings were a world apart from the pattern part rings, which looked paper thin in comparison. Would have blown in a second.
I think for important parts like this, it's always a good idea to buy genuine.
: 1998 bandit 600
sickpup
Old Timer
PostPosted: 19:58 - 09 Mar 2009    Post subject: Reply with quote
This is why it's getting confusing.
You intimate there was a problem with an item I sold you. You haven't told me there's a problem, I've sold about 50 of the kits in the last year without a single 'known' problem. If there's a problem I need to know there's a problem, this is a question of peoples safety.
I also offer a money back guarantee on everything I sell, I offer people exchanges or refunds on items they have purchased in error way beyond what the DSR's require me to do. I've even replaced seals for free when people have damaged them in a cack (more inexperienced really) handed fashion while fitting them. I do my best to keep the customer happy beyond what I need to do.
Reread the thread, you asked for supplier, I supply.
As to the other thread considering I'm well known for what I do for a living (the link in my sig gives it away) telling someone to disregard what I say is an attack on me. Also I didn't try to sell anything.
I believe I should be informed if there's a problem with a product I sell. I also believe if there's a problem I should have a chance to put it right
Just because you mention no names doesn't mean I don't know it's about me. It's unjustified that nothing has been mentioned to me before so I can't deal with a problem in an amicable way.
mrsteko
PostPosted: 23:41 - 09 Mar 2009    Post subject: Reply with quote
Firstly, stop quoting me.
Secondly, if you do want to quote something, quote the bit at the top which mentions I have already replaced the seals, I am not looking for a supplier for these.
Thirdly I told you exactly what was wrong with your product at the time and you did indeed suggest i may have put them in "cack handedly". However the standard suzuki parts I bought right afterwards went straight in no problem, strange. You were given more than enough info about the part i needed in the beginning and I don't take kindly to the "try it and see" ethos with a view to refunding and posting back later should it not work- its a waste of my time and I have no interest in it.
: 1998 bandit 600
Bezzer
PostPosted: 00:01 - 10 Mar 2009    Post subject: Reply with quote
Stephen
My turn to quote you now Mr. Green
I know I'm onto something but are you sure you know what you're measuring?? the 62-63mm is the spacing between the caliper fixing bolts on the 600 dunno where you get 90mm from. All 1200s are 90mm fixing centres- including the K5 -I've got one of them Neutral
mrsteko
PostPosted: 00:04 - 10 Mar 2009    Post subject: Reply with quote
Its where the caliper joins the bracket. Not where the bracket joins the stanchion. I figured this would be better as a replacement caliper would still need to use this bracket if it were intended to be attached to the bike.
: 1998 bandit 600
mrsteko
PostPosted: 00:27 - 10 Mar 2009    Post subject: Reply with quote
Bezzer wrote:
I know I'm onto something but are you sure you know what you're measuring?? Neutral
Umm Cheers mate, lol
: 1998 bandit 600
mrsteko
PostPosted: 00:33 - 10 Mar 2009    Post subject: Reply with quote
Think I'll change the pots and maybe consider a rebuild of the master cylinder, if I can manage it being such a stranger to a spanner and all, lol. Thanks to all who provided a constructive comment.
stephen.
: 1998 bandit 600
sickpup
Old Timer
PostPosted: 00:49 - 10 Mar 2009    Post subject: Reply with quote
I've just worked out exactly which order you were.
You are the person who complained that the copper crush washers were too thin and flimsy to fit to your brake lines even though they are the ones supplied by Venhill the people who make Powerhose. Not to mention the idea of a crush washer is that they are deformable to create a seal.
You are also the person who didn't bother to talk to me about any problems, just left a neutral and I contacted you waiting a bit over two weeks for an answer. Your last email was pretty final and I decided to not contact you further as you seemed rather pissed off. I do still of course have copies of the emails should anyone wish to see them.
I didn't accuse you of cack handedness. In your own message to me you said how you tore the dust seal to shreds, the fluid seals were fine. Strange as they are matched in size and, the internal dimensions are the same and they are supplied as a set from the manufacturers. 5 dust seals and 5 fluid seals.
As to the 'try it and see' approach you seem to believe I have I don't. I offer a full refund in the case of problems generally with no need to return the items, in fact I've never required anyone to return a faulty item as a few people on here know.
I offered you a full refund, I didn't require the return of the seals you shredded and threw away or the copper crush washers you didn't like and threw away but you didn't take me up on the refund. There's not really anything else I could do.
Bezzer
PostPosted: 10:28 - 10 Mar 2009    Post subject: Reply with quote
The 600 Bandit calipers don't have a bracket, they fit directly to the fork leg. You either have non standard calipers with an adaptor bracket on there now or are confused as to what constitutes the whole caliper Thinking
sickpup
Old Timer
PostPosted: 12:08 - 10 Mar 2009    Post subject: Reply with quote
600 Bandit up to 1999 uses a 2x25mm piston sliding caliper that fits to a separate bracket and then the fork leg.
Bezzer
PostPosted: 14:35 - 10 Mar 2009    Post subject: Reply with quote
I count that "bracket" as part of the caliper it isn't as if you can use it without like a "normal" bracket as it locates the sliding pin.
sickpup
Old Timer
PostPosted: 16:08 - 10 Mar 2009    Post subject: Reply with quote
I agree, I was just clearing up the confusion. Thumbs Up
The last post was made 17 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 129.28 Kb
