Datatool3 problem
bEN_
PostPosted: 21:16 - 07 Mar 2009    Post subject: Datatool3 problem Reply with quote
Right the bike has been hibernating for a couple of months, a few days ago decided to charge it up and the plan was to run it for a few minutes.
all i have done on the bike is removed a few bits, done some cleaning and not really touched the alarm.
i did accidently break the small LED light that tells you if the alarm is active etc as it was rusted it just snapped off. , which i have a replacement LED for but not yet fitted.
anyway, left it overnight to charge, try to start it, alarm sounds like it's disabled etc . .
try to start it and there's just an electrical 'buzzing' sound, this is the same sound i had when my battery was nearly flat when i left the lights on by accident.
i left it another night to charge, just tried it now, same result.
the lights come on bright and the charger shows it's fully charged.
either i've shagged the immoboliser or that stupid LED light is actually quite important?
just wanting abit more info as i've had no trouble with it since owning it and thinking of getting rid, untill i read around a see it's a bitch to remove aswell. i'm abit stalled.
on my day off i'll solder the new LED on there if it is actually important but apart from that i don't really know, fuses seem fine to Confused
hmm https://sportstourer.org/index.php?name=News&file=article&sid=40
2010 Ducati 848 Dark
Lamp Post Enthusiast
Indurate
PostPosted: 10:00 - 09 Mar 2009    Post subject: Reply with quote
Its actually very hard to shag the immobiliser
The LED shouldnt make any difference
When you disarm the alarm do the indicators flash, if not you have lost the fuse that supplies the alarm.
Disarm alarm does the fuel pump prime at switch on and starter motor turn when button pressed, if they do then the fault will not be your immobiliser.
Arm alarm switch ignition on, hot wire detect should sound alarm during this listen for fuel pump prime and press starter button, nothing should happen. If all this happens your alarm is OK and the fault is on the bike..
From experience I would say your battery is shagged.
Alarms rarely go faulty despite what everyone says, its just that people don't understand them and that includes 90% of mechanics and installers.
Indurate
Bat
PostPosted: 10:04 - 09 Mar 2009    Post subject: Reply with quote
I'll second that, the buzzing you describe sounds like a starter motor not getting enough juice. Bike batteries are not hard wearing at all and if your battery has had it the charger will think it's fully charged because it can no longer take the required charge.
bEN_
PostPosted: 11:39 - 09 Mar 2009    Post subject: Reply with quote
Brill that does clear it up quite abit.
it does prime when i turn it on
the indicators do flash and it beeps when alarmed / disarmed
i thought the battery was quite weak last year, if i didn't ride it for 4-5 days it would go flat.
however if i turn the lights etc on they come on bright and ok.
i guess the starter needs alot more power though . .
so new battery it is then, thanks Thumbs Up
Bat
PostPosted: 13:05 - 09 Mar 2009    Post subject: Reply with quote
Spot on, the starter needs way more juice than the lights etc. A battery that flattens in 4-5 days is in technical speak, buggered Laughing
The last post was made 17 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 4.49 - MySQL Queries: 13 - Page Size: 46.2 Kb
