Idiot. Low oil on Hornet 900
Bat
PostPosted: 10:12 - 09 Mar 2009    Post subject: Idiot. Low oil on Hornet 900 Reply with quote
Hi all,
Because I'm stupid I didn't notice the oil level had dropped right down on my Hornet 9 until yesterday when it was well below the minimum mark. I had to add well over a litre to get it up to the max line.
It was fine a couple of months and approx 200 miles ago. Am I likely to have done any damage?
Cheers,
el_oso
PostPosted: 11:18 - 09 Mar 2009    Post subject: Reply with quote
maybe a little bit more engine wear than normal. depends how you rode it. high revs especially from cold would be bad. if all sounds and runs fine fine then assume it is. if you notice anything weird at all check it out. probably haven't done that much damage
PostPosted: 11:21 - 09 Mar 2009    Post subject: Reply with quote
If there was enough oil that the oil pump was never left wanting then no problem at all. If the oil pump couldn't pick up any oil (which might have triggered the oil pressure warning light) then potentially a hell of a lot of damage.
Bat
PostPosted: 12:16 - 09 Mar 2009    Post subject: Reply with quote
Thanks guys. I never ride hard from cold and haven't given it any stick really due to the road conditions and the fact that I've recently upgraded from a 600 Divvy.
The warning light did not show at least that I noticed and it runs and sounds fine so fingers crossed!
Incidentally would you say it's normal for an engine of this type to get through a litre of oil in a couple of months with some short journeys and several 20 mile trips to work and the same back?
PostPosted: 12:30 - 09 Mar 2009    Post subject: Reply with quote
Does seem a bit much for oil consumption, but make sure you haven't over filled it, and that it wasn't a bit low before.
If the oil level had been low enough for the pump not to pick anything up then the damage would happen when you rode off even if you took it a bit easy.
NSR Mick
PostPosted: 12:32 - 09 Mar 2009    Post subject: Reply with quote
Did you check the level on the stand or upright as how you should check it can vary.
Bat
PostPosted: 12:58 - 09 Mar 2009    Post subject: Reply with quote
Hi,
I checked it with the bike level. On the side stand the inspection glass doesn't show any oil at all when the level is at max with the bike level.
Thanks,
The last post was made 17 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 52.35 Kb
