Making your own exhaust (started)
SoND
PostPosted: 02:41 - 09 Mar 2009    Post subject: Reply with quote
Why are you trying to create backpressure?
MaybeGuy
PostPosted: 09:29 - 09 Mar 2009    Post subject: Reply with quote
because it makes a difference even on 4 strokes (if it isnt a 2 stroke).
plus its probaby loud as fucking fuck
s44678
Guest
PostPosted: 12:40 - 09 Mar 2009    Post subject: Reply with quote
What you are trying to achieve here, apart from trying to impress people by showing that you know some general engineering terms?
I imagine you would have to have a pretty good knowledge of fluid-dynamics (and engines) to design and build an exhaust that does anything other than make a loud noise. So why bother?
PostPosted: 12:51 - 09 Mar 2009    Post subject: Reply with quote
What is important is not the pressure itself, but the pressure waves that are created and where they are bounced back from. More to do with down pipe design than just an end can.
Cigaro
PostPosted: 13:19 - 09 Mar 2009    Post subject: Reply with quote
Have a pipe down the middle, sealed at one end with holes drilled in it.
This will create some backpressure and have a silencing effect too.
proximity
PostPosted: 13:27 - 09 Mar 2009    Post subject: Reply with quote
Kickstart is right, you do not need to bother thinking about pressure waves unless you are building downpipes. Just make it as unrestrictive as possible, unless you want it to be shit.
I built one for my zephyr, but only because i did an engine swap on it and couldnt get an exhaust to fit. Its straight through. I put a can on it though, so technically its just a mid section.
I think the rules for cans are along the lines of length/exit diam = loudness, can diameter = deepness?
2004 Aprilia Tuono
MaybeGuy
PostPosted: 13:35 - 09 Mar 2009    Post subject: Reply with quote
oh right, i thought he meant a whole system.
PostPosted: 13:46 - 09 Mar 2009    Post subject: Reply with quote
Even then you still don't want to obstruct the flow of gas. The pressure waves are bounced back from where pipes join / end.
The trick is making an exhaust that flows well and bounces pressure waves back at appropriate revs. With a can the trick is to make it flow well while absorbing noise. Flowing well and not absorbing noise is easy (just don't bother with a can).
PostPosted: 18:40 - 09 Mar 2009    Post subject: Reply with quote
I would just go for a basic setup. Cap on each end with a perforated tube between then. Match the size of the holes in each cap to your existing pipe and to the perforated tube. Wrap sound absorbing material tightly around the tube when you assemble it, and taking up the space between the perforated tube and the outer tube.
For real cheapness use loft insulation, but don't expect it to last that long. You can buy baffle packing material fairly cheaply (try a local motocross shop).
PostPosted: 19:35 - 09 Mar 2009    Post subject: Reply with quote
Yep. The packing will compress and loose effectiveness over time but if you make it bolt together you can repack it easily (the old Allspeed 2 stroke exhausts held the baffle in with a large circlip which made repacking them a doddle).
Presume you will make up a pipe for it to slip on to the rest of the system with and tart up the outlet a bit.
proximity
PostPosted: 19:45 - 09 Mar 2009    Post subject: Reply with quote
I had a can with rusted end caps and the idea went through my head of buying endcaps to make exhausts. I know you can buy them because i've seen them on ebay. Im wondering if any manufacturers do them as spares, but saying that they wont be cheap.
edit: found this:
https://www.pjengineering.co.uk/products.asp?cat=10
2004 Aprilia Tuono
PostPosted: 23:16 - 09 Mar 2009    Post subject: Reply with quote
I know that some exhaust makers have used stainless steel wool as baffle packing (being long lasting), but no idea how effective it really is. Real small bits of swarf would be useless as they would just fall through the holes in the perforated tube.
There is a fair chance that whatever you do will mean having a play with jetting. You will change the flow of gases, but whether by enough to have enough affect that you care is another question.
proximity
PostPosted: 23:24 - 09 Mar 2009    Post subject: Reply with quote
It depends how restrictive your stock one is inside, its probably a load of chambers flowing back and forth.
Generally as long as its not a massive exit diameter it shouldn't be too bad, maybe copy the exit diameters of some of the commercial cans available for use without rejetting. I suspect though that they arent any different to any other race cans as generally bikes run ok with just an end can.
I'd be weary of a full system though unless you are confident you can get it right and the drawings you have a from a good source. An end can wont make much difference to your engine but a full system certainly will.
Consider having a smaller diameter exit pipe inside of the perforated tube aswell for further noise reducing db killer style.
2004 Aprilia Tuono
PostPosted: 00:22 - 10 Mar 2009    Post subject: Reply with quote
the warped one wrote:
So with this method will it be road legalish because the bike will be used everyday.
Good question. Honestly do not know.
And Kickstart, who the hell do you know so much? Are you sure your not in mensa or something?
Sign of reading too much and a brain that seems to have given up any short term memory for long term memory. Seriously, I normally struggle to remember what (if anything) I had for breakfast.
PostPosted: 01:19 - 10 Mar 2009    Post subject: Reply with quote
Isn't the GTR injected? if so no jets. You may need a power commander but I doubt it, I haven't seen a big bike ever run crap (Carb'd or injected) by putting a straight through can on it.
PostPosted: 18:01 - 10 Mar 2009    Post subject: Reply with quote
That will like depend on your specific exhaust. Could just bolt on or there could be a short stub that slides in before you can bolt it on.
SoND
PostPosted: 22:50 - 10 Mar 2009    Post subject: Reply with quote
And just a quick thing about marking the bolt holes, as i'm still using the bike, would I get a acurrite measurement from putting my divviders into the bolt hole and then makinga trinangle then turning it in to a circle? If anyone can understande that.
Make a cardboard template and transfer it to the plate. Don't bother trying to measure it still on the bike, it'll be awkward and a waste of time.
Rottweiler
PostPosted: 23:14 - 10 Mar 2009    Post subject: Reply with quote
bit of a nobed comment by skluff cant he make an exhaust because he wants to ? cant see the point of the comment you made
were: piaggio nrg..ybr 125
now: cg 125
The last post was made 17 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 136.65 Kb
