running a different head/barrel on a 2stroke...
hmmmnz
PostPosted: 11:13 - 10 Mar 2009    Post subject: running a different head/barrel on a 2stroke... Reply with quote
hi guys, well i have almost given up trying to find a barrel to fit my buggered kh125 barrel,
i have been reading about barrel conversions on vespas which seems like a fairly cool way of getting some extra hp out of an old air cooled scoot
my only hesitancy of doing something like this to my wee bike is that mine is currently a rotary valve engine, and as much as i loathe to convert it away from that as i really like the rotary valve system,
there are quite a few smokeys out there that run the same 50.6 stroke as my wee beast including the rg125 and 150s and rgv250 the kx125 rs125 the cagiva 125 range,
any of which i wouldnt have too much trouble getting a new barrel reeds and piston for, also i'd have to convert to 12v and run the donor bike cdi and power valves,
what do ya reckon
the humans are dead
I kick arse for the lord
PostPosted: 11:54 - 10 Mar 2009    Post subject: Reply with quote
To be honest I suspect it would be a pig of a job. Not sure which barrel would fit with close enough cylinder stud spacing to be modified, but suspect you would land up needing the carb and exhaust.
Power valve and the like is easy to do without (just get a barrel from an engine old enough not to have a power valve), and the same for a radiator (just get an air cooled barrel, eg Cagiva Roadster).
Why do you need a new barrel?
400bandit
PostPosted: 12:32 - 10 Mar 2009    Post subject: Reply with quote
I'm pretty sure that you wouldn't want to pay this much for one but you never know
https://www.cmsnl.com/kawasaki-1983-l1-kh125_model12345/partslist/1B.html
All the best,
Joe
400bandit
PostPosted: 12:37 - 10 Mar 2009    Post subject: Reply with quote
I've just had a thought, I'm not too clever when it comes to engine re builds and I have never touched a 2-smoke (yet).
Would it not be possible to bore the cylinder to accept a sleeve?
Joe
chillpill
PostPosted: 12:49 - 10 Mar 2009    Post subject: Reply with quote
i read a random thread on a german 2stroke tuning forum where a guy put a crosser barrel on a moped engine . he removed the cylinder studs and just modded an adaptor plate onto the crankcases. ill see if i can look up the thread for you Thumbs Up
PostPosted: 12:54 - 10 Mar 2009    Post subject: Reply with quote
Logan,theres a kh125 being broke on ebay:
Ebay link(shortened)
Any good?
DRZ-400sm
hmmmnz
PostPosted: 13:04 - 10 Mar 2009    Post subject: Reply with quote
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF2058Small.jpg
thats alread 1mm o/s before the groove
All the best,
i can't use a k or L model barrel as they changed the bore and stroke from the A models 56x50.6 to 55x52.5
yes more than possible, but they never made a sleeve for them, and making a new one to fit would set me back 6 times what i paid for the bike in the first place Very Happy
heres the page that made me think about it in the first place.
the ar125 which being a kwaka would probably be the best option
same bore and stroke (same as rm125) but no powervalves to worry about, same issue with the reeds though.
the early (70s) ke125 ar125 and kx125a1 all had almost identical engines to the kh, just with different port timings. and exhausts
alas i cant find any of them either Very Happy i did find a barrel in south america, but the guy wanted $400 usd for it (thats probably a few months wages to him) and that was too much money to pay for a bike that cost me the equivilent of $50usd
i dont mind spending money, and i'd like to have the bike original,
but im quite happy modifying a bike to get a bit more pep out of it as well
the humans are dead
hmmmnz
PostPosted: 13:10 - 10 Mar 2009    Post subject: Reply with quote
Any good?
i had already emailed him and he replyed that it was a c reg l1 kh125
so that rules that out as well Sad (different bore and stroke to the a model kh125's)
im seriously regretting not spending the 100 quid bike on ebay and getting you guys to strip the parts off for me
the humans are dead
kat250
PostPosted: 13:12 - 10 Mar 2009    Post subject: Reply with quote
The ar125 motor is a reed/rotary combo thing so it still takes in from the end of the crank.
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
PostPosted: 13:15 - 10 Mar 2009    Post subject: Reply with quote
There are places that will make up and insert a slieve. PJ Engineering in the UK for example.
While that would be about £100, and I very much doubt you could manage to fit an alternative top end (including getting the bits) for less.
The normal (1980s) AR engine is water cooled, and also an odd setup with a disk valve and reed valves, which might make the intake timing a bit screwy for your purposes.
hmmmnz
PostPosted: 14:23 - 10 Mar 2009    Post subject: Reply with quote
mmm well that rules out the ar125, i thought something looked a bit odd when i was looking at it.
on the other hand i do have 2 rg150 engines in various states of disrepair Very Happy
im picking that up this weekend from home, so ill have a measure about and see if its at all possible to make fit..
if they can do it to damn vespas i sure im good enough to do it to a kh
https://www.scooterhelp.com/moto.barrels/moto.vespa3.lg.jpghttps://www.scooterhelp.com/moto.barrels/moto.vespa2.lg.jpg
https://www.scooterhelp.com/moto.barrels/moto.vespa1.lg.jpg
the humans are dead
Blue_SV650S
PostPosted: 14:42 - 10 Mar 2009    Post subject: Reply with quote
How do you propose sealing off the rotary valve?
As kickstart said, a re-line is the simplest solution.
BenR
PostPosted: 19:39 - 10 Mar 2009    Post subject: Reply with quote
Why not just another engine in the bike? Wink
PostPosted: 20:22 - 10 Mar 2009    Post subject: Reply with quote
What about using the RG150 piston and boring the stock Kh barrel to accept it?
baldy
PostPosted: 20:58 - 10 Mar 2009    Post subject: Reply with quote
I agree, i would just bore the crap out of it.
Don't some places offer a service where they weld over the grooves and then bore it to standard? I'm shure that i read about it someplace.
One day i will rule the world, just not today.
hmmmnz
PostPosted: 22:27 - 10 Mar 2009    Post subject: Reply with quote
the liner is only so thick, going from a 56mm bore to 61mm there would be no liner left Very Happy
because that would be too easy Very Happy and i have to have matching engine numbers when i re register the bike.
i weld a plate over the hole and remove the rotary valve Wink
yes i'd agree it would be the simple solution.... if they were ever made for the bike, getting a new one made would cost far too much,
the humans are dead
PostPosted: 22:29 - 10 Mar 2009    Post subject: Reply with quote
The link I provided above was for about £100 to make and fit a liner. Doesn't matter that Kawasaki don't make them. There must be people doing a similar service in NZ.
hmmmnz
PostPosted: 23:10 - 10 Mar 2009    Post subject: Reply with quote
yeah there are, but the price is about $600 to get one made and then the price of a standard piston and rings on top of that.
considering i paid $100 for the whole bike im sort of loathe to pay that, as i could buy another rotary valve bike for that,
im being a bit of a cheap bastard i know and i dare say ill end up doing that in the end, but i have some rg150 engines and if its possible with out huge amounts of effort then ill give it a go, if not then ill fork out silly amounts of money on a bike thats not worth it Very Happy
the humans are dead
The last post was made 17 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 107.36 Kb
