Brakes or Gears?
ish765
PostPosted: 13:59 - 10 Mar 2009    Post subject: Brakes or Gears? Reply with quote
Which do you use (or think is best) for slowing down at junctions ect. And why?
RXS100 On the Road.
D O G
PostPosted: 14:00 - 10 Mar 2009    Post subject: Reply with quote
Both, it allows me to stop if I need to. Neutral
Personally I prefer to use BRAKES rather than BREAKS, but there you are. Wink
Seriously though a combination of the two. If you're just using one or the other it's poor riding IMO.
If I HAD to use only one then it would be the brakes are they are infinately adjustable and offer far more control than gears alone.
PostPosted: 14:04 - 10 Mar 2009    Post subject: Reply with quote
Mainly engine braking / gears for pulling up to junctions, just using the brakes for finer / final control (or making up for making an error). That said you cannot really slow to a halt using engine braking alone, especially going down hill.
tafflade
PostPosted: 14:08 - 10 Mar 2009    Post subject: Reply with quote
On my Aprilia I use engine braking a hell of a lot because it is so damn effective for normal A road riding, I can arrive at a corner at the right speed in the right gear to power through and accelerate away.
On th BMW it is so damn heavy the engine braking isn't as effective and the brakes are so damn good I tend to use them a lot more.
So its a combo of both really but to use engine braking means you have to be looking into the distance to read the road and plan what you are going to do before you start doing it.
ish765
PostPosted: 14:15 - 10 Mar 2009    Post subject: Reply with quote
Thanks for that. Thumbs Up
RXS100 On the Road.
ish765
PostPosted: 14:18 - 10 Mar 2009    Post subject: Reply with quote
I have been using gears mostly, but I wonder about the effect on the engine?, and the fact that people may not think I’m slowing down ?
RXS100 On the Road.
Graprilia
PostPosted: 14:30 - 10 Mar 2009    Post subject: Reply with quote
As do i Thumbs Up
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
PostPosted: 14:36 - 10 Mar 2009    Post subject: Reply with quote
It can affect the engine, but that's on race bikes, not on the road. Well unless you're consistently letting the clutch out with the engine spinning up near the redline. Slipper clutches have helped stop this too.
I also find it's usually a good idea to show you brake lights to the vehicles behind.
On my test they taught me to press lightly on the rear brake even if I slowed using the gears only. e.g. when slowing from a 40 limit to a 30 to the traffic behind that I was slowing.
PostPosted: 14:37 - 10 Mar 2009    Post subject: Reply with quote
With "gears" you are not slowing down that quickly (in inverted commas as much of the time I suspect you are just using the engine braking without changing down), but you can always pull the brakes lightly to illuminate the brake light if you want.
Stamping it down gears is probably not going to do the gearbox any good, but do it smoothly and blip the throttle and it should be fine. Possibly some extra wear on the clutch plates but I can't say I would worry about that.
Fuel wise which is better will depend on the actual engine. Using engine braking on a carbed engine means you will still be drawing in fuel which is doing nothing, and pulling in far more than if you pulled the clutch and let the revs drop to idle. With some injected engines they will cut the fuel supply when the throttle is closed at revs above idle, hence with these you would actually use more fuel by dipping the clutch and letting the revs drop to idle. Again though the difference would be tiny.
There is the argument that brake pads are cheaper than gearboxes, but the counter to that is that a new front end is a hell of a lot more than brake pads if you have cooked your brakes by the time you need to use them in anger.
All that said, I think some people have mentioned that going down the gear as you slow down to use engine braking is now frowned on in the driving test.
Blue_SV650S
PostPosted: 14:38 - 10 Mar 2009    Post subject: Reply with quote
Both, do people really coast (have the clutch in) when slowing down? Thinking
I'd say - unless you have a particularly odd riding style - people either use BOTH or just engine braking ...
Personally, I'm too impatient to rely on engine braking alone!! Wink
Walloper
PostPosted: 15:41 - 10 Mar 2009    Post subject: Reply with quote
I stop for nothing.....
Mostly engine braking.
Brakes for parking and to prevent piling into some moron who never saw me.
It really depends on size of engine and piston configuration.
The big I have has seriously useable engine braking but my multi cylinder Jap bikes had not much.
May be due to design and reducing friction loads to minimum or sumat.
Kal
PostPosted: 17:29 - 10 Mar 2009    Post subject: Reply with quote
Surprised at the two strokes using engine braking, I wouldn't have thought they were that effective.
Depending on the situation, in my ideal world I will see the obstruction far enough ahead that I can just change down through the box and apply my brakes in the last few yards to come to a gentle rest.
Things are usually far from ideal so I usually tap the back to light up the brake and then change down, using the brakes if coming in a little quickly. Smile
Kal...
supZ
PostPosted: 17:34 - 10 Mar 2009    Post subject: Reply with quote
this for me too.
if im not actually stopping i'll often just roll off the throttle, clutch in, blip and change down letting the engine braking slow me down. if i need any more then i'll use the brake.
slowing quickly from speed is a different matter and i'll brake first then change down to aid decelleration
CBR954RR - Daily toy
CBR600RR - Trackbike
R6jonny
PostPosted: 17:35 - 10 Mar 2009    Post subject: Reply with quote
Brakes for slowing down, then pick the gear you want to be in...
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
ish765
PostPosted: 18:07 - 10 Mar 2009    Post subject: Reply with quote
Thanks people. Thumbs Up I guess I’ll develop my own way. I have been using the front break to show the light, just because I ‘m in the habit. I guess it should be the rear, though it’s rarely enough to actually feel it.
I imagine with time I could get used to wheel braking and selecting the right gear, at the moment I still feel I don’t know what it’s going to do when I let the clutch out. But it would mean I could start slowing later.
But using the gears does keep the revs sweet, seems good for my 2 stroke.
RXS100 On the Road.
Peirre oBollox
PostPosted: 18:09 - 10 Mar 2009    Post subject: Reply with quote
indeed ............Brakes are for slowing, gears are for going.
If your reving the engine and dropping a gear to slow down, over & over, all you`ll do is waste fuel, and increase wear & tear in the engine and drive train, and ultimately it will cost you more
The Tot
PostPosted: 18:13 - 10 Mar 2009    Post subject: Reply with quote
Engine braking from quite a long way away then use the brakes to fine tune the rate of deceleration. Dead stop at a junction; left foot down, right foot on brake. I like a smooth stop using engine braking.
You can say that using the brakes also puts wear and tear on the pads and disks Wink.
When i'm going for a blast, I hardly ever use my brakes and usually modulate my speed with the appropriate gears. Back brake often comes on to stabilise the bike mid corner.
Never argue with autism
ajb
PostPosted: 18:24 - 10 Mar 2009    Post subject: Reply with quote
This thread has interestingly made me think about the way I ride.
I'm trying to imagine what I do when slowing down, and I cant for the life of me remember how I change down gear under braking, I dont think I do Confused That must involve some ninja throttle tweak whilst applying the front brake.
I usually try to let off the throttle well in advance and pick a gear then use the brakes to come to a stop/move off again.
CBR125R '05 > CB500 '00 > CBR600F '99
OssY
PostPosted: 18:42 - 10 Mar 2009    Post subject: Reply with quote
I like to use engine breaking when i am slowing down at a junction that i know i have got a chance of just continuing at. But generally use both..
iooi
PostPosted: 18:50 - 10 Mar 2009    Post subject: Reply with quote
If the throttle is shut, it makes no diffrence.
Personally use engine braking most of the time and tickle the rear brake...
If the car is right behind me all the time then stuff the brake and scare the hell out of them.
Nothing shocks a car driver more than getting too close to you rear end. Twisted Evil
deanoet
PostPosted: 18:54 - 10 Mar 2009    Post subject: Reply with quote
Depends how close the tool behind me is. Smile
Normally just use the engine to slow me down, if there is a car 2 inches from my wheel i use brakes just so they see the lights
Gashead Harry
PostPosted: 19:29 - 10 Mar 2009    Post subject: Reply with quote
I tend to hold the clutch in and brake going down the gears as I slow down.
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
lukamon
PostPosted: 19:54 - 10 Mar 2009    Post subject: Reply with quote
actually, it does make a difference. shutting the throttle ob a high revving engine with a carb creates hugely more suction through the tiny opening the bike ides on, sucking more fuel.
on injected engines the ecu (usually) cuts the fuel supply on the overrun, and my ford engine hangs the revs up at 1.5k to reduce wear on the clutch (if you're useless at changing gear) while its above 6mph, o if you coast with the clutch in it actually wastes quite a bit of fuel.
killa wrote: Im an ass man myself
The Original Muzza
PostPosted: 20:27 - 10 Mar 2009    Post subject: Reply with quote
I use my feet, flintstones style. Failing that I just resort to a brick wall.
Seriously though downshift for engine breaking, then brakes when needed.
The last post was made 17 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 133.53 Kb
