What is this? *NSR 125*
Xanthic
PostPosted: 20:01 - 10 Mar 2009    Post subject: What is this? *NSR 125* Reply with quote
https://i181.photobucket.com/albums/x313/xanthicflex/S5030802.jpg
And what does it mean when it buzzes horribly and your bike doesnt start?
Shocked
And also, to remove the starter motor, do I go in through the left side and remove the engine casing first?
Thanks in advance!
Smile
First & Current: Honda NSR 125 R1
Link fixed - https://apopandagumshield.wordpress.com
Bikeless
PostPosted: 20:15 - 10 Mar 2009    Post subject: Reply with quote
Probably the relay for the starter motor so your starter motor may be o.k. if the relay is knackered.
baldy
PostPosted: 21:12 - 10 Mar 2009    Post subject: Reply with quote
It's the starter relay. If it buzzes it means that your battery is either flat of completely dead. I wouldnt muck about with the starter motor until you have sorted the other problems first.
One day i will rule the world, just not today.
Xanthic
PostPosted: 21:21 - 10 Mar 2009    Post subject: Reply with quote
After months of bump starting and faffing around, I got a feeling it may be my starter motor that's knackered. Either that or the reg/rec. The battery is a brand new battery from Dec and the bike only ever seems to fire up if the battery has been on charge overnight... reg rec dead? The starter motor makes a whirring sound when attempting to start....
PostPosted: 21:24 - 10 Mar 2009    Post subject: Reply with quote
So are you saying the starter motor spins but doesn't engage with the engine?
Could be the starter solenoid.
Bikeless
Run the bike and put a multimeter set to 12 volts on the battery terminals,you should be getting between 13 and 14 volts if your reg/rec is working.
Xanthic
PostPosted: 21:47 - 10 Mar 2009    Post subject: Reply with quote
It reads 12.7 with the engine off and lights off
13.8 with the lights off and idling at approx 1400rpm
10.8 with the lights on and idling at approx 1400rpm
11.7 with the lights off and revs at 3000rpm
10.00 with the lights on and revs at 3000rpm
ANNOYING!!!
Thanks everyone Thumbs Up
Bikeless
PostPosted: 21:49 - 10 Mar 2009    Post subject: Reply with quote
This happened with my mates R1,when we revved it,the voltage went down,he then went and bought 2 reg/recs off ebay until we tracked it down to a bad earth,so don't assume it's the reg/rec just yet.
Xanthic
PostPosted: 21:55 - 10 Mar 2009    Post subject: Reply with quote
I have no clue about electrics, do I just go through the whole bike making sure everything is properly connected?
The last post was made 17 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 61.53 Kb
