AHHH help - Rs125 - Over Heating
Mcyd
PostPosted: 14:56 - 11 Mar 2009    Post subject: AHHH help - Rs125 - Over Heating Reply with quote
Right well i think my rs is over heating or something,
What happens is this,
Ill start up the bike, it'll run for around 4 mins then just die on me no matter what i do , it gets to about 48 oC then when it drops down to like 42 oC itll start up again, i have no idea whats wrong but went to get it running , i miss riding.
To be honest i should of kept my Nsr 125.
Please help me out , if it all goes to shit the bikes being stripped n sold. if intrusted let me know.
Aprilia Rx 50 - Top Speed 70 - Sold - Honda nsr 125 - Speed 103 - Sold
Aprilia Rs 125 - Top Speed 121 - Sold - Honda Vfr 750 - Top Speed ? - Running
Suzuki Sv 650 S - Top Speed ? - Running - Ish
Itchy
PostPosted: 17:03 - 11 Mar 2009    Post subject: Reply with quote
At a guess vapour lock? , in that check the proximity of your inline fuel filter (you do have one right?) and fuel pipe to the engine.
In that if it is too close then the heat causes the petrol to vapourise inside the fuel line or filter causing a pressure block in the fuel line which causes fuel starvation.
A way to check this is to run the bike wait till it dies then splash (Carefully) some cold water on the fuel filter , if it starts up again fine there is your problem, if not its somewhere else.
Mcyd
PostPosted: 18:05 - 11 Mar 2009    Post subject: Reply with quote
will a 2007 engine fit into a 2002 bike?
5v3d3b0
PostPosted: 18:22 - 11 Mar 2009    Post subject: Reply with quote
You're jumping from the bike dying on you to buying a new engine? Show some commitment!
At least try what Itchy told you before even considering something else.
Mcyd
PostPosted: 18:25 - 11 Mar 2009    Post subject: Reply with quote
the engine out , its been in the garage they cant tell whats wrong with it, its anoying me i want to be ont he road again fed up of the bloody bus, see why?
Itchy
PostPosted: 18:27 - 11 Mar 2009    Post subject: Reply with quote
Vapour lock test costs NOTHING, if it is vapour lock the fix is in pennies (ie wrap the filter or heat shield it.
Mcyd
PostPosted: 19:44 - 11 Mar 2009    Post subject: Reply with quote
can you , liek grab a couple of diagrams togeather to help me out please?
Itchy
PostPosted: 21:09 - 11 Mar 2009    Post subject: Reply with quote
Under the petrol tank connected to the petrol tank you will find a fuel tap , follow this along and you should find something cylindrical this should be your fuel filter it should look like this
https://www.germes-online.com/direct/dbimage/50039182/Plastic_Fuel_Filter.jpg
it should run to the carb or fuel pump I forget if the RS has a fuel pump or not, run your bike as normal , when it cuts out spash some cold water on the fuel filter.
If it is vapour lock the petrol vapour inside the fuel filter should condense into liquid petrol again and the bike should start up on the button.
If this doesn't work its something else, its one of those random problems that can't be replicated in a garage.
If it is vapour lock heat shield the fuel filter or buy some longer fuel hose and move it away from the source of the heat.
Mcyd
PostPosted: 21:12 - 11 Mar 2009    Post subject: Reply with quote
just checked my bike there isnt one, goes from tank to carb
stirlinggaz
PostPosted: 21:15 - 11 Mar 2009    Post subject: Reply with quote
hi,
no in line fuel filter on the rs.
only filter is in the carb, a gauze one.
oh & inside the fuel tank, behind the fuel tap, bugger to get at though.
suspect its nothing to do with overheating but carb related. as i have run the rs at around 100deg! when sitting in traffic, unless the thermostat or guage is dodgy.
try running it without the thermostat to rule it out.
time to take it back to basics.
got compression?-needing around 120psi +
got spark? (stick a new plug in)
got fuel? (keep the tank full & make sure the breathers arnt blocked, try it with the fuel cap open)
is the carb needing the floats adjusted?
cheers,
GAZ
Mcyd
PostPosted: 18:23 - 19 Mar 2009    Post subject: Reply with quote
right, my thermostat is always open,
brand new spark plug,
its got petrol,
the water pump spins with the gears
stirlinggaz
PostPosted: 19:38 - 19 Mar 2009    Post subject: Reply with quote
hi,
start with the basics,
you say its a new plug, but are you actually getting a spark?
is petrol getting to the carb? (try opening the drain screw & see if any petrol dribbles/pours out)
what voltage is the battery showing? dont trust the lcd,use a multi-meter.
is the spark plug wet or dry after you try & start it?
is the engine back in the bike?
cheers,
GAZ
Mcyd
PostPosted: 22:44 - 19 Mar 2009    Post subject: Reply with quote
battery has been check is fine, it runs for four mins or so then cuts out
The last post was made 17 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 79.92 Kb
