CB left me stranded :(
Ant132
PostPosted: 19:07 - 11 Mar 2009    Post subject: CB left me stranded :( Reply with quote
After i 'restored' the inside of my fuel tank i thought the bike was going to be fine. But today i was going to college and going along the road at 40mph, traffic cleared up and i went to accelerate and it was very reluctant to do so.
I went to change down a gear but when i pulled the clutch in i felt the bike want to die until the clutch was released. Realising something was obviously wrong i coasted to a halt (at this point the engine had cut out.) Bike would turn over but not fire.
I managed to pull the fuel line off and petrol flowed out freely. I never had any tools on me to check spark or anything, so i locked it up in a nearby car park and walked the rest of the way. At the end of the day i walked back to the bike and went to start it. To my surprise it started and i let it warm up whilst i got all my kit back on, i rode to the petrol station and filled up as i was pretty low.
The bike got me home fine minus two minor things. At the lights (twice on two seperate occasions) it 'went' to cut out, as in i heard it want to die suddenly, but it saved itself almost instantly. Like it had been turned off and back on very quickly, if you know what i mean.
I was about 10 minutes into my journey when this happened.
Any ideas? Cheers, Ant. Thumbs Up
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Eddie Hitler
PostPosted: 19:33 - 11 Mar 2009    Post subject: Reply with quote
Check all the earths (usually 2), and check the wiring for wear/short circuits etc.
Blue_SV650S
PostPosted: 19:48 - 11 Mar 2009    Post subject: Reply with quote
If it starts and runs fine, then after a given time feels fuel starved, then it sounds like the breather hole is blocked. Next time it happens, release the fuel cap and see if you can hear sucking (vacuum) with the cap off (and allowing time for the fuel to re-fill the carb) try re-starting.
I especially suspect this as you say you have had problems with the tank ...
Ant132
PostPosted: 20:30 - 11 Mar 2009    Post subject: Reply with quote
Will check Thumbs Up
I took the filler cap off and no difference. I couldnt hear any sucking but it's not a vaccuum tap (just on, off, reserve) and tube going from tank to LH carb. No vaccuum lines or anything.
It did, however, start on the choke but was at idle speed and would cut off when i gradually pushed the choke in. Confused
Blue_SV650S
PostPosted: 20:40 - 11 Mar 2009    Post subject: Reply with quote
I was meaning that a blocked breather (its in the cap) will mean that as the bike uses fuel, no air can get in the tank to replace the volume lost .. end result a partial vacuum ... it gets to the point where the vacuum overpowers the gravitational feed and the carb/bike gets starved of fuel!!
I wasn't referring to a vacuum operated tap ...
Did you try popping the cap at the time?
If it started on choke, then it is deffo fuel problems NOT electric ...
If its not a blocked breather, then its time to take the carb apart and clean it ...
p.s. I had a CB100N, cracking little bikes ... the cable operated front disc is a fag mind Sad
EDIT ... this thread is about the superdream ... not the 100N (just read a thread about that too and got mixed up!! Embarassed) ... I had a 250N too, it too was a good bike, but had a normal hydraulic front brake!! Laughing
Ant132
PostPosted: 20:46 - 11 Mar 2009    Post subject: Reply with quote
The thing is, after the fuel tank problem, in the process i had bought new float valves and throughly cleaned the carbs (they were put back on Saturday morning), new fuel line and a new fuel filter along with a tank treated with the Frost restoration kit. So i wouldn't be expecting any problems in the fuel department to be honest.
I did check the breather at the time (first thing i checked) and it made no difference at all. The fact it started and ran fine after it had been left - if the carbs were blocked or the breather blocked wouldn't it continue to refuse to start? It could be that something has had time to cool down and is no working again - but 'what' is another question Laughing
Thanks Thumbs Up
Blue_SV650S
PostPosted: 20:58 - 11 Mar 2009    Post subject: Reply with quote
Thanks Thumbs Up
The seal on the tank and the blockage is not normally 100%, therefore over time air will leach back in ...
Next time, if it starts cutting out, pull the choke on and see if it picks up slightly. If it does, then it is fuel starvation.
It could be something electrical, but from the symptoms you have given, it sounds more fuel related ....
I'd certainly have the carbs off again before looking elsewhere ...
Ant132
PostPosted: 21:05 - 11 Mar 2009    Post subject: Reply with quote
Yeah, i think you're right. But wouldnt a blockage in the carbs give me a more consistant problem. My first thought was some sort of heat related problem, especially as a couple of threads down i read of a guy having a similar problem to me and Itchy gave an interesting diagnosis of 'vapour lock' to do with the heat. I will also give that a try next time.
On a different note, what symptons would overheating of the engine give? Or head gasket leakage as i suspect i 'may' have a leaking HG aswell Confused
Ant Thumbs Up
Blue_SV650S
PostPosted: 21:12 - 11 Mar 2009    Post subject: Reply with quote
Ant Thumbs Up
If it is sh1t floating around in the bowls, then it'll get picked up at random intervals ...
As I said, I think the carbs (and fuel line) are your first port of call ...
As for 'vapor lock', its gravity fed .. vapor lock (getting fuel vapor in the fuel pump causing an air lock) cannot be your problem ...
You said you replaced it ... how long is your fuel line? ... does it go down and up at all? You could however have an air lock in there ...
also the in line filter ... does it look full of fuel??
Ant132
PostPosted: 21:25 - 11 Mar 2009    Post subject: Reply with quote
This is a quick paint illustration of the currect set-up. The original picture shows the old set-up which turns out to be too short a route, if run with an in-line filter, as it kinks.
New set-up (as shown in pic) is pipe from tap, round the back of the carb and underneath the bottom of the carb, then filter, then back up straight to carb spigot.
https://i101.photobucket.com/albums/m62/ant-147/carbset-up.jpg
I could check for any crap in the carbs, but the fuel tank is immaculate inside now and new fuel lines and filter, i find it hard to believe that crap would have got it, but possible so i will check. The in-line filter looked full of fuel when i broke down, i pulled the pipe off and petrol came out freely. Thumbs Up
Blue_SV650S
PostPosted: 21:31 - 11 Mar 2009    Post subject: Reply with quote
WTF .... dude, you have an air lock ... plain and simple!! Very Happy
You might be able to 'flick' the air bubble out, but with it like that its bound to cause problems ...
The tap itself should have a little gauze filter in it ... the in line is a good idea, but shouldn't really be needed and with the line ran like that ... well you now know what can happen!! Laughing
Ant132
PostPosted: 21:32 - 11 Mar 2009    Post subject: Reply with quote
I was advised by my MOT tester to situate it like that, so i did. Laughing Is this a bad way? Embarassed
Blue_SV650S
PostPosted: 21:35 - 11 Mar 2009    Post subject: Reply with quote
I think its asking for trouble ... again, it might be ok, but having now seen that, I'd deffo try putting a straight bit of pipe in and see if it clears your fault ... having established what we have to this point (that you have cleaned the carbs etc) ... I bet a shiny e-Penny Coin that fuel line routing and filter position is all your problem is!! Wink
Ant132
PostPosted: 21:38 - 11 Mar 2009    Post subject: Reply with quote
Ok, will do that in the morning. The reason we had it like that is because doing just a short bit of pipe doesnt allow for an in-line filter to be fitted without kinks. In the manual it doesnt show there being a filter, just a straight tube, thats it.
Hmm, i really hope it is just the fuel line Smile
Ant Thumbs Up
Blue_SV650S
PostPosted: 21:43 - 11 Mar 2009    Post subject: Reply with quote
Ant Thumbs Up
You shouldn't need a filter ... it was a nice idea, but if you cant get a clean run, then its a no-go I am afraid ....
I think if you 'snaked' the run from the tap to the carb (but always in a downward direction) you should be able to get the filter in there (horizontal ish - try not to get 100% horizontal or we might get another air lock problem). Bur for now, just run a straight bit of pipe and see if your fault clears ...
you can always retro-fit a filtered 'snake' run ... but we need to ensure this is deffo your problem first ...
p.s. Isn't that a 'square' inline filter in there in the original pic??? ... can't you just get another one of those?
Ant132
PostPosted: 21:51 - 11 Mar 2009    Post subject: Reply with quote
Right, im just going to fit a straight bit of tube tomorrow as i know the bit you mean in the tap, i checked that before re-fitting the tap and its clean.
I will take it on a nice long run tomorrow and hopefully it will be ok Smile Will let you know. Thumbs Up
Edit: I could get another square filter but the thing is, with it fitted, the fuel line is kinked on the end. I do have a smaller filter somewhere, i'll try and sort it out and if i can fit it without any kinks then i'll leave it be. Smile
Ant132
PostPosted: 22:05 - 11 Mar 2009    Post subject: Reply with quote
Here is the old set-up, its not very clear but the red line shows the bends.
https://i101.photobucket.com/albums/m62/ant-147/tapset.jpg
The yellow line shows where the tap spigot ends so i cant shorten that tube anymore to try and stop the kink. The sharp bend towards the end shows how the fuel tube kinks. Thumbs Up
Blue_SV650S
PostPosted: 02:48 - 13 Mar 2009    Post subject: Reply with quote
Any joy??
Ant132
PostPosted: 18:45 - 13 Mar 2009    Post subject: Reply with quote
Was just to about update Smile Thanks for enquiring mate Thumbs Up
The excellent news is that the bike is FIXED! The morning after i started the thread, following your advice, i re-routed the fuel tube to a short straight line with an in-line filter, similar to how it was originally but with no kinks. I've done around 80 miles today and yesterday without a hiccup, and when the problems arose it started within 2/3 miles.
Thanks for your help. Smile
Blue_SV650S
PostPosted: 20:29 - 13 Mar 2009    Post subject: Reply with quote
Wicked ... sometimes it is the most simple things!! Thumbs Up
The last post was made 17 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.66 - MySQL Queries: 15 - Page Size: 116.32 Kb
