6-Pot Front Calipers - Strange Noises
TheDonUK
PostPosted: 20:23 - 12 Mar 2009    Post subject: 6-Pot Front Calipers - Strange Noises Reply with quote
Hi all,
A rare post in the workshop for me, nothing is broken but as a preventative measure i thought i would ask for some advice,
Before winter started my old Tokico calipers on my ZX6 were shagged so i brought new ones, And in that time i have not cleaned them or done anything TBH, due to laziness and lack of knowledge/experience.
So today riding at slow speed i hear a knocking sound from the front of the bike when i initially apply the brakes.
If i had to guess it would be that there is a slight gap between the end of the pads in the caliper, ie the pads have a milimeter or so of travel.
I only notice it at slow speed, as if the disc grabs the pads and knocks rotates them slightly clockwise knocking the caliper before they run out of free space.
I have explained that poorly and when they do bite there is still good feel from the front (although not as good as when new).
Has anyone had similar? Is this dangerous and what can be done?
Ill say now i dont really have the confidance to work on my own brakes even with some of the cleaning guides such as killa's that are on here..
Any ideas would be appreciated cheers Thumbs Up
el_oso
PostPosted: 20:40 - 12 Mar 2009    Post subject: Reply with quote
this may sound stupid but are the calliper bolts loose. never had this happen on a motorbike but my mountain bike has disks and it did the same. took me forever to figure out that the bolts holding the calliper on were loose.
Itchy
PostPosted: 20:42 - 12 Mar 2009    Post subject: Reply with quote
I was informed that this is happening on my CBR600F too since I changed the pads on Tuesday, it passed an MOT test fine , the only issue is that it makes an unpleasant noise and that the brake is very grabby according to the MOT tester and thus very very very sharp as the MOT tester on the brake test nearly dropped the CBR.
TheDonUK
PostPosted: 01:47 - 13 Mar 2009    Post subject: Reply with quote
Sounds similar Itchy, Its only noticable at a very gentle pace ie 5mph, almost as if theres slightly too much room in the caliper for the edge of the pads.
I will check the bolts and give it a good once over before i ride tomorow Thumbs Up
PostPosted: 08:55 - 13 Mar 2009    Post subject: Reply with quote
Could it be the disks floating and clicking slightly too much on their mounts as the disks are worn?
Itchy
PostPosted: 10:01 - 13 Mar 2009    Post subject: Reply with quote
The guy who did it couldn't find anything wrong with the bike I think they wanted to fail me as the MOT was incredibly through, they didn't like the sound at all:
They looked at pad movement - nope
They looked at loose calipers - nope
They looked at disc warpage - nope
They looked at disc being too thin - nope
They looked at the pads being too fat to sit in the caliper - nope (I filed them down slightly on the edges)
They looked at wheel bearings - nope
They looked at headstock bearings - nope
They looked at fork seals - nope
The only thing one of the MOT testers could figure out was that there might be an airgap between the piston and the back of the pad a tiny paper thin one which meant when the piston comes out it has free space to accelerate into the back of the pad.
Or pad glazing , still passed the MOT though and they said it should go away after I do a few 100 miles to bed the pads in properly.
Mark65
PostPosted: 10:03 - 13 Mar 2009    Post subject: Reply with quote
I would check the bolts are the right size and tight then check the caliper isnt sticking open slightly or that the pads arnt damaged inside on the edges, then the disc.
Mark
the grim reaper
PostPosted: 10:43 - 13 Mar 2009    Post subject: Reply with quote
I take it they checked the pins that the pads slide on, if one of these is worn or notched, the pad will sit in this groove and not be properly applied at low speed.
Grim
Itchy
PostPosted: 10:47 - 13 Mar 2009    Post subject: Reply with quote
Grim
Now you mention it one of the pins did have sort of a groove in it when I fixed the brakes, BUT this groove was about 1cm long and it didn't look as if it was a result of wear in that it was completely smooth as if they were milled that way. Probably replace them when I have the money , its not expensive.
I can't remember what they looked like when I last did my pads.
But the pad shims are in , took me ages to get them in and I have them the right way as I disassembled the calipers individually to use the other as reference.
Irezumi aka Reuben
Carrot Top
PostPosted: 21:22 - 13 Mar 2009    Post subject: Reply with quote
Perfectly normal sound.
Where there are six pistons the calipers dont get applied flat so knock around a little bit against the calipers. Don't worry about it.
The last post was made 17 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.05 - MySQL Queries: 15 - Page Size: 73.19 Kb
