Starting issues, compression... '85 GSX550
Stelmer
PostPosted: 15:32 - 14 Mar 2009    Post subject: Starting issues, compression... '85 GSX550 Reply with quote
I know I need to get a compression tester but I thought i'd ask for advice first.
Just spent around an hour starting the GSX for the first time in 14 days.
It sounds like it's loosing compression on a cylinder as it makes an odd noise when cranking. Like the normal starting noise with a short, regular speed up then back to the normal noise.
Once it fired, it ran ok with no smoke from the exhaust but weak blue smoke from the breather hoses.
I let it warm up and from hot, it is a little hesitant on firing up but cranks somewhat normal. I've now turned it off and letting it cool before trying it again.
Any ideas?
Hopefully it's not the rings but it could be the head gasket or valves.
PostPosted: 15:38 - 14 Mar 2009    Post subject: Reply with quote
The GSX550 did have a habit of burning up the valves on high mileages. You might as well do a compression test.
Stelmer
PostPosted: 16:31 - 14 Mar 2009    Post subject: Reply with quote
Yeah, mileage is somewhat unknown so best get a compression tester.
Also, i could've flooded it... Embarassed
baldy
PostPosted: 18:10 - 14 Mar 2009    Post subject: Reply with quote
The blue smoke idicates that it's burning oil. It could just need a rebore and the valves lapping in.
One day i will rule the world, just not today.
Stelmer
PostPosted: 12:08 - 15 Mar 2009    Post subject: Reply with quote
It's the valves, or is likley the valves.
Earlier it sounded very odd and smoked like crazy.
Cleaned plugs (2 covered in oil) and it fired up easy and had compression. Bit of smoke and a misfire.
Time for an engine strip I think.
The last post was made 17 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 43.41 Kb
