Bike moving off with no throttle
Visitor Q
$25 whore
PostPosted: 22:01 - 14 Mar 2009    Post subject: Bike moving off with no throttle Reply with quote
Just chucked in a new fuel pump, from a different model (possibly a vfr Rolling Eyes) so required some bodging of the wiring (yay junction box and liquid metal).
Anyhew, all that happened before was the old one died, so the bike ran rough until it killed what was left in the carb inlet pipe.
However, just taken the bike out and it is acting like the choke is still on, in the sense that in first of second from stationery, letting out the clutch makes the bike move off (without touching the throttle).
Obviously this isn't the best of things.
Choke is fully off (at the lever, haven't checked the cable yet).
Idle is set low (1.5-2k, fiddled a bit but its not made much difference).
Throttle is working fine, although you have to close it manually (pretty much). But I don't think it's that.
What do you reckon? Gonna ride in to work tomorrow on it anyway as its a quiet sunday, but monday might be interesting. So wouldn't mind a few ideas to potter with tomorrow night.
Robby
Dirty Old Man
PostPosted: 22:34 - 14 Mar 2009    Post subject: Reply with quote
I would assume that if it's chucking in far too much pressure then it'll overfuel, giving the impression of having the choke on.
See if it runs like a bag of arse warm. If it does, it's running rich. Also, if it starts easily from stone cold with no choke, then it's probably running rich.
lonner
PostPosted: 00:42 - 15 Mar 2009    Post subject: Reply with quote
hi
idle speed should be 950-1100 on most bikes as 1500-2000 is way to high
alun111
PostPosted: 02:56 - 15 Mar 2009    Post subject: Reply with quote
zzr lon wrote:
hi
I'd say 950 is too low, but 1100-1200 sounds more like it. I'd definately say 1.5-2 is too high!
damz
PostPosted: 16:13 - 15 Mar 2009    Post subject: Reply with quote
zzr lon wrote:
hi
my tachometer doesnt start until 3000 on the 250 lol.
how does the bike run while riding it?
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
Visitor Q
$25 whore
PostPosted: 17:22 - 15 Mar 2009    Post subject: Reply with quote
Rode the thing to london and back today. Bike seems a bit hesitant at times, like the chain is sticking. But only rarely and for short periods Thinking
Idle is set that high because it tends to ping about all over the place, and it gets higher when its warm Confused
The small amount of go when at closed throttle is abit dodgy round slow corners/roundabouts though, so could do with sorting it soon.
alun111
PostPosted: 18:56 - 15 Mar 2009    Post subject: Reply with quote
When was the last time you had your carbs balanced? This could cause a rough idle. Sort this problem out first instead of just setting your idle higher!
lonner
PostPosted: 20:54 - 15 Mar 2009    Post subject: Reply with quote
bit pointless trying to solve it realy as it sounds as though its a bodge all over.
good luck with it Thumbs Up
iooi
PostPosted: 23:07 - 15 Mar 2009    Post subject: Reply with quote
Why not ???
Could be something is sticking at carb end and not allowing slides to close fully.
I would look at cable's and sort that out before starting on taking the carbs to bits.
Visitor Q
$25 whore
PostPosted: 18:35 - 16 Mar 2009    Post subject: Reply with quote
Have to take the carbs to bits to properly access the cable anyway Rolling Eyes Joy.
And it's not a bodge /all/ over, just alot of it Laughing
Yes the carbs probably do need balancing, and its on my to-do-list along with valve clearances. Will probably wait until I have money and get a mechanic to do it.
Did have a thought though, if the old fuel pump was on its last legs, it might have countered a dirty air filter. Now its running well this would then mean it was getting enough air, hence rich. It would explain the occasional hesitance at high speed.
Used 15% less fuel today though Thinking
AngelGrinder
PostPosted: 23:26 - 16 Mar 2009    Post subject: Reply with quote
I can get some vacuum gauges for carb balancing, so if you need them let me know...I might even be able to help if you havnt done it before.
Let me know!
PostPosted: 00:38 - 17 Mar 2009    Post subject: Re: Bike moving off with no throttle Reply with quote
I read this before and still don't quite understand - on some bikes its possible to pull away by slowly letting the clutch out. Definitely with an idle that high.
Pretty standard that you can do this in cars.
Visitor Q
$25 whore
PostPosted: 07:33 - 17 Mar 2009    Post subject: Reply with quote
Let me know!
Thanks Martin, a mate has one too and offered a hand, but has since got a gf and dropped off the face of the earth,, Rolling Eyes
Haven't really got the time at the moment anyway, but certainly something I'd like to get done Thumbs Up
G, yeh I know, but I wouldn't of said my idle was that high. Annoying thing is it gets higher when it warms up Evil or Very Mad
There is a gap of 193 days between these two posts...
damz
PostPosted: 03:13 - 27 Sep 2009    Post subject: Reply with quote
did you ever find out what caused this problem? my fzr has developed a similar problem and might be caused by the same thing
Robby
Dirty Old Man
PostPosted: 10:09 - 27 Sep 2009    Post subject: Reply with quote
I've got his bike in my garage while he's off in South Africa. The idle is still all over the place. I'm going to pop the spark plugs out today and see how they're looking, I'm hoping to see at least one cylinder indicating a lean burn, which would point to an inlet rubber leak.
I may also have to remove the carbs, although I hate doing that, to check for wear in the needle or jets, which could cause rough running.
Then there's the electrics. I'm not going to town on them. The reg/rec is fine, I might try the coils of my own CBR6 (same model, more or less) and see if they make a difference.
His clutch is fucked too. He shouldn't be allowed near bikes, it's like handing a box of hammers to a chimp on meth.
Visitor Q
$25 whore
PostPosted: 14:58 - 27 Sep 2009    Post subject: Reply with quote
I still think it's something sinister. Beyond my mechanical ineptness.
Robby
Dirty Old Man
PostPosted: 18:01 - 27 Sep 2009    Post subject: Reply with quote
I'll try it on my fuel pump too, although I doubt that's a problem. Pickup coils can always be a possibility, but pretty unlikely and they mean taking off a side panel.
Not even thinking about the clutch yet. Externally it looks fine, so you may be right about shite springs.
Visitor Q
$25 whore
PostPosted: 18:10 - 27 Sep 2009    Post subject: Reply with quote
Are you equally amazed it didn't explode during my trips to work... or my horrific trip to drop it off to yours for that matter.
I'm very shocked. Very.
I wasn't exactly nursing it either Embarassed
The last post was made 16 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 102.38 Kb
