Fuel Leak
Poseidon
PostPosted: 19:43 - 15 Mar 2009    Post subject: Fuel Leak Reply with quote
Now then folks. Had my Trident at home for just over a week (she's something of a project) and everytime I spent any time with her I could smell petrol. At first I thought it might be fuel leaking into the carbs but after removing the fairings and lifting the tank up, I've found the leak. It's only a slow steady drip, but it obviously needs sorting. It's allegedly had a new fuel tap on it (I'm a bit concerned about the state of the bolts holding it on... yellow circle in pic) but the leak is from where the tap meets the tank (red circle in pic shows a drop of petrol). I would've thought it would have had a new gasket with the new tap, but as I'm yet to get the tap of the tank, I can't confirm this. To make matters worse, I cant get the other fuel hose off (got the first fuel hose off and it pissed fuel everywhere, it was then I reaslise that whilst I was pulling the fuel hose off, I'd managed to turn the tap from "on" to "prime" with my wrist Rolling Eyes ... vacuum hose came off okay too). There's no retainer clip on any of the hoses either!
So folks, my questions are;
If the gasket is fine, could I use silicon sealant to stop the leak... and any tips for getting stuck hoses off? (i've tried pulling, twisting ect and am seriously thinking of just cutting it off as there is plenty of hose to re-connect)
I've run out of light today for working so left it for the night, I wanted to spend a good day on her tomorrow anyways so Intend to get this little problem sorted.I've attatched two pics, one of the leak and partialy stripped bolt and one of the stuck hose... Let me know your opinions folks!
1977 Honda CG125
inchi55
PostPosted: 19:54 - 15 Mar 2009    Post subject: Reply with quote
Try using a hair dryer to warm up the pipe it should soften it and you will be able to get it off.
As for the leak make sure the surfaces are flat and clean or even put an extra gasket on.
past bikes-gt185, gsx250, gsx600f, gsx750f and now rf900/
yea suzuki man all the way.
Poseidon
PostPosted: 19:58 - 15 Mar 2009    Post subject: Reply with quote
inchi55 wrote:
As for the leak make sure the surfaces are flat and clean.
Valid point... I'm working on the assumption that whoever did the work would've done this. Isn't there a phrase about assumption being the mother of all cock-ups!
1977 Honda CG125
inchi55
PostPosted: 20:34 - 15 Mar 2009    Post subject: Reply with quote
Yea been there and learned the hard way. Crying or Very sad
Poseidon
PostPosted: 21:20 - 15 Mar 2009    Post subject: Reply with quote
to make matters worse, all the wine glasses seem to have disappeared... I'm having to drink pinot noir out of a champagne flute Rolling Eyes
If all else fails with the seal... the silicone would do the trick though, wouldn't it?
1977 Honda CG125
inchi55
PostPosted: 22:59 - 15 Mar 2009    Post subject: Reply with quote
don`t know how it would react with petrol could be dodgy.
Poseidon
PostPosted: 23:40 - 15 Mar 2009    Post subject: Reply with quote
It's ok with oil... otherwise you couldn't use it with the valve cover, would've thought it'd be okay with petrol. Hopefully getting the surfaces properly clean will do it though.
Edit: Petrol desolves silicone... may have to resort to plan B... Thinking hmmm... whats plan B???
1977 Honda CG125
The Artist
PostPosted: 23:51 - 15 Mar 2009    Post subject: Reply with quote
Assume makes an "ass"/out of "u"/and "me"
Poseidon
PostPosted: 00:10 - 16 Mar 2009    Post subject: Reply with quote
I like it!
Okay, here goes "Plan B":
Stop looking at ways to bodge the jobs and repair the bike properly (draws attention away from the gun gum on the exhaust Whistle ). If I'm going to the lengths of ordering new bushes for the forks (when I change the oil seals) then I can order a new gasket if it's needed! If a jobs worth doing!!!
This bike is turning into a real love hate thing... I love the bike, the bike (and probs my wife) hate me!
1977 Honda CG125
A Weetabix box Wink
EDIT: Honestly, it probably would work, don't order a gasket just yet. It costs nothing to try so you might as well.
Poseidon
PostPosted: 00:12 - 16 Mar 2009    Post subject: Reply with quote
ms51ves3 wrote:
A Weetabix box Wink
lol... I mean... nah... just... lol
EDIT: honestly you think It will probably work? lol... we don't have weetabix in our house, would ASDA's wheat bisks work? (the box obviously, not the wheat bisks themselves)
1977 Honda CG125
PostPosted: 00:13 - 16 Mar 2009    Post subject: Reply with quote
ms51ves3 wrote:
A Weetabix box Wink
You may laugh but it's perfect material for paper gaskets. I made one out of a Shredded Wheat box and fitted it to my RX-S, never had an oil leak since.
Poseidon
PostPosted: 00:17 - 16 Mar 2009    Post subject: Reply with quote
Surely it would have to be a non-pourous material, wouldn't the petrol soak straight through it?
1977 Honda CG125
PostPosted: 00:18 - 16 Mar 2009    Post subject: Reply with quote
Go for it. Use the old gasket as a template Thumbs Up
Poseidon
PostPosted: 00:20 - 16 Mar 2009    Post subject: Reply with quote
I'm still not overly convinced... however, as the price is right for this repair... I'll give it a go. If it works, I'll buy you a bacon buttie and a cuppa (once she's road worthy!)
1977 Honda CG125
PostPosted: 00:21 - 16 Mar 2009    Post subject: Reply with quote
If it doesn't work, I'll buy you a bacon butty and a cuppa Wink
Poseidon
PostPosted: 00:23 - 16 Mar 2009    Post subject: Reply with quote
You're on! Wink
EDIT: https://www.bikechatforums.com/viewtopic.php?t=91536&highlight=gasket+weetabix
You want butter and sauce on the buttie chives?
1977 Honda CG125
spanner-zn
PostPosted: 10:38 - 16 Mar 2009    Post subject: Reply with quote
There is normally a rubber o-ring in-between the tap and the tank. You cannot use silicon where there is petrol around. Just buy a standard o-ring from your local car dealer of the correct size and if the two surfaces are smooth and clean it shouldn't leak. You can replace the bolts with stainless steel cap screws which won't corrode and will look a lot neater.
Poseidon
PostPosted: 12:53 - 16 Mar 2009    Post subject: Reply with quote
It definately looks more like a gasket than an O-ring, and I'm definately not putting silicon any where near it!
1977 Honda CG125
PostPosted: 13:18 - 16 Mar 2009    Post subject: Reply with quote
Silicon sealeant is petrol soluable as far as I know.
The bikes I have taken the tap off which are that style of attactment have been Yamahas which have had a rubber seal. Lozenge shape with a couple of cross pieces. The is exactly what it appears to be on the parts list link posted above.
Could be that someone has fitted a new tap and just used a piece of cardboard as a make do gasket (that tap looks new to me). Could also be there there is some corrosion to the outside of the tank resulting in a poor seal to the tap (looks like someone has tried to clean up the mating surface).
Poseidon
PostPosted: 15:58 - 16 Mar 2009    Post subject: Reply with quote
You're dead right there... got it to pieces and found the rubber seal.
The proper seal is there, and the mating surface on the tank has been cleaned, but it looks like whoever did it has used something really coarse and there does appear to be some corrosion. I've attatched a pic for a more detailed view without the tap in place. Should I use some form of liquid gasket (hermetite red springs to mind), or is there another way?
Many thanks
Drew
1977 Honda CG125
reckless_b
PostPosted: 16:12 - 16 Mar 2009    Post subject: Reply with quote
I recently had a very old very tightly stuck clear reinforced plastic petrol pipe to remove, after struggling for a while I got the wifes little steam cleaner, about the size of a kettle, two little blasts of steam and the pipe almost fell off it really made a difference.On the subject of the gasket,a thin smear of red hermatite should do the trick. Wink
40 years on the road on and sometimes off bikes with a very recent OFF
Poseidon
PostPosted: 16:20 - 16 Mar 2009    Post subject: Reply with quote
Got the hose off using the wifes hair dryer... although she did politely explain that it's not really for that purpose when she came out to the garage to see what I was up to! Laughing
EDIT:
Thought so... I'll grab some when I go to get the brake pads and discs for the car... so many repairs, so little time! Rolling Eyes
1977 Honda CG125
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 125.4 Kb
