Bearings, eh..
Mr Hammers
PostPosted: 13:06 - 16 Mar 2009    Post subject: Bearings, eh.. Reply with quote
Recently, the NSR developed a vibration at high speed, which initially I put down to the expansion chamber not sitting correctly on its bracket (a previous problem). Until that is, I noticed some play in the rear wheel.
So, picked up some new bearings on Friday, and took the old ones out on Saturday. Then I saw just what condition the r/h side bearing was in when I took it out;
Hmm...bit grubby in there...
https://www.planetash.net/bcf/rwbearing1.jpg
And then...
https://www.planetash.net/bcf/rwbearing2.jpg
I've had chips that were greasier... Very Happy
A Guide To Powerbands
BanditsHigh
Worse than a woman
PostPosted: 13:39 - 16 Mar 2009    Post subject: Reply with quote
Looks like an OEM bearing, they either have no seals or only one ... just perfect to let all the grease out as the bearing heats up Rolling Eyes
I take it you are replacing with sealed bearings Thumbs Up
Mr Hammers
PostPosted: 14:37 - 16 Mar 2009    Post subject: Reply with quote
I can't afford for it to be off the road (again) so I had to get the bearings they had in stock at the time. One of those is sealed, luckily the same side as the above, which is under the most stress, but unfortunately the other wasn't. I'll just keep an eye on it add it to my monthly Grease It list, and it should be ok.
baldy
PostPosted: 18:47 - 16 Mar 2009    Post subject: Reply with quote
Don't they sit behind normal seals anyway? So the only advantage of the bearing being sealed is to keep the grease in.
One day i will rule the world, just not today.
BanditsHigh
Worse than a woman
PostPosted: 19:39 - 16 Mar 2009    Post subject: Reply with quote
The OEM bearings are usually fitted with the seal to the outside, leaving the unsealed side to the inside of the wheel which means the grease can move to the inside of the wheel Thumbs Up
iooi
PostPosted: 22:10 - 16 Mar 2009    Post subject: Reply with quote
Have you ever taken a new sealed bearing apart ???
You will get a real shock when you see how little grease is in them.
Best advice is to very carefully prise the seal off and fill full of grease, they will last even longer then.
baldy
PostPosted: 22:55 - 16 Mar 2009    Post subject: Reply with quote
I know, i always take the seals out, wash what ever crap out that is in there and pack it full of proper grease, normaly silicon grease.
The last post was made 17 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 52.93 Kb
