Hornet 6 v Bandit 6
rac3r
PostPosted: 21:58 - 17 Mar 2009    Post subject: Hornet 6 v Bandit 6 Reply with quote
Quick comparison please! Not sure which year... what ever you can get for about 2.5k. So:
Which is better?
What are the differences?
Reliability
etc.
Thanks for your help Very Happy Thumbs Up
(ps 33bhp'd)
Chequered Flag
JakeyR
PostPosted: 22:06 - 17 Mar 2009    Post subject: Reply with quote
Do a search, Hornet will mince a Bandit.
I still miss my Hornet it was a crackin' bike, took some abuse too, they handle a thousand times better than bandits, yeah they're still on budget suspension but they do handle a shitload better. Plus they look far cooler. Biased much? Laughing
Itchy
PostPosted: 22:13 - 17 Mar 2009    Post subject: Reply with quote
Hornet almost always minces the Bandit, but there are some issues.
The Hornet bar the newest models is based around the old CBR engine which uses shimmed valves which are a PITA to adjust, and costly to get somebody else to do , but need doing only half as much as the bandit.
The Bandit uses rockers and its valves are much easier done but need doing more often.
Bandit is alledged to be much easier to tune to more guts, and if its an earlier model the bandit has better range, heh I remember a ride out where the hornets (two of them) had to stop twice as often as everybody else, ah I miss those 350 mile ride outs...
Some ancillary issues, the Bandit crashes better than the Hornet, the Hornet has a VERY weak minimal box frame which everything hangs off, the bandit has a wrap around frame.
You can get the bikini fairing for the bandit for newer models for some reason Honda stopped making the top fairing.
Just to confuzle you more , the Yamaha Fazer 600 is also very good not the new ones though the older ones. Headlights are like candles though. It also crashes very well better than the hornet again.
TheDonUK
PostPosted: 22:39 - 17 Mar 2009    Post subject: Reply with quote
Much of a Muchness. Whichever you buy i doubt you would regret it...
As has been said the Bandit has the better tank range, its also a phsyically larger and heavier bike carrying its weight higher up than the Hornet.
I owned both for a year and got on well with both, I still think top end the bandit was faster, purely because on a number of rideouts i remember passing flat out hornets very gradually but surely. (talking about indicated 125/130 ish)
The Hornet was probably quicker off the line. I also had the first Hornet model with its 16' front wheel which basically narrowed tyre choice down to pirelli diablos (good tyre though).
If you are a large guy or do motorway miles or intend to tour i would go for the Bandit, Whereas in short bursts the Hornet is probably the one to go for, I cant really find fault with the bandit except the exhaust collector box which was made of out mild steel and prone to corrosion, As for the Hornet i had overheating issues with mine which i hear is quite common for that CBR lump.
For me personally if i had to have one or the other again it would probably be the Bandit, The small fuel tank on the Hornet (100 miles ish) really became annoying towards the end, Plus IMHO Bandits with an aftermarket can sound better and dont have that whirring sound at idle that hornets seem to, they have a more meaty sound.
I also reckon for a given amount of money you can get a better example of a Bandit than a Hornet, plus i dont like the high level exhaust on them (i dont even like stubbie exhausts so feel free to ignore this).
In summary:
The Bandit for:
Top speed (Debateable)
Tank Range
Planted feeling round bends
Large Physical Size
Wheelies
The Hornet for:
Acceleration
Agile handling
Smaller size
Stoppies.
rac3r
PostPosted: 23:33 - 17 Mar 2009    Post subject: Reply with quote
I'm quite small and the tank range doesn't really bother me because I do mainly short journeys Laughing But the only thing is as you said for the money you probably get a newer/low mileage bandit. I really like the 03+ Hornet with the sharp tail but they come in at the 3k mark. Thanks for the info Thumbs Up Keep it coming if you have anymore
Chequered Flag
PostPosted: 23:50 - 17 Mar 2009    Post subject: Reply with quote
May I suggest a Triumph Speed Four as an alternative? Has better suspension than both bikes as standard, has a better tank range than the Hornet and is a lot lighter than the Bandit. I believe it might even be lighter than the Hornet but don't quote me.
Sure, they are a bit ugly, but they are also comfy and quick. And pretty cheap too. I got a 2001 model for £2k last year with 7k miles on the clock.
colin1
Captain Safety
PostPosted: 00:04 - 18 Mar 2009    Post subject: Reply with quote
another vote for a speed four
they have better brakes, suspension and chassis
at the moment, there is a 2004 speed four with cat c light cosmetic damage on ebay for £1500
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250375419519
tt600 is the original version, which is fully faired, but you can just take the fairings off if you want
they regularly go for less than £1000 on ebay
OssY
PostPosted: 01:00 - 18 Mar 2009    Post subject: Reply with quote
BIASED BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT BANDIT
much love
PostPosted: 01:48 - 18 Mar 2009    Post subject: Reply with quote
Another vote for a Speed Four,
Hornet would come second, I wouldn't touch a Blandit again.
Slow, heavy, piss poor handling, and generally boring.
Point to make I've got a S4 had a bandit 600 (01) and ridden bandit 650 (56)/1250(08) (put a few thousand on each) Hornet 600(99 a few times briefly) So believe I have a fair amout of experiance with these bikes.
alun111
PostPosted: 01:56 - 18 Mar 2009    Post subject: Reply with quote
I have a bandit 4 and a hornet 6. A mate of mine had a bandit 650s.
If it's anything to go by my bandit 4 is an absolute pig to work on. Everything's in the worst location, and you need small hands!
I had a go on my mate's bandit 650 the other week, was nice.. better handling I thought (although it is 6 years younger! and he also has full on sports tyres on it where as I have sports touring). The race can he has doesn't sound as nice as the one on my hornet (again, different can though).
As for the hornet, I've had mine for about 7k now and it's not let me down at all.. the only problems I've had is a puncture in the back tyre and I've managed to dent both of my wheels somehow (nothing to do with the bike... my riding somewhere). The fuel is a bit annoying, but I don't go on long rides so it's fine by me. I love the power, and I love the looks.
As already said, bandits can be picked up for MUCH cheaper, hornets are pretty expensive really.
All that probably wasn't of much help, but thought I'd give it a try.
PostPosted: 08:36 - 18 Mar 2009    Post subject: Reply with quote
Get the hornet. It's a cracking bike. Cool
Kris
PostPosted: 11:59 - 18 Mar 2009    Post subject: Reply with quote
The choice really depends what you want the bike for.
If it's for hooning and mostly fun rideouts then the Honda will most likely suit. It handles better, that's for sure. Plus the 110 mile tank won't pish you off as much.
If however you will be using the bike for mostly commuting or as an 'every-day' bike then I'd say that the Bandit would suit you better. Plusher ride, 160 mile tank, and if you get the S version then a fair bit of weather protection. Centrestands make home servicing easier and easy-valve adjustments reduce servicing bills.
For £2.5k you will get a nicer Bandit than hornet although the Bandit will deteriorate quicker if neglected.
www.prisonplanet.com
rac3r
PostPosted: 12:23 - 18 Mar 2009    Post subject: Reply with quote
More confusion! Doh!
I'd LOVE an S4 but the problem is every one I've found is more than 3k. The one above (CAT C) looks nice, my favourite colour for that bike too but how does that CAT C/D stuff work?
Chequered Flag
PostPosted: 12:41 - 18 Mar 2009    Post subject: Reply with quote
Here's me not trying very hard to find a Speed Four.
Clicky
Kris
PostPosted: 13:15 - 18 Mar 2009    Post subject: Reply with quote
What are the running costs of a Triumph S4?
Won't be as cheap to insure (Group 10) or as economical (45mpg) as a Bandit I'd have thought...
rac3r
PostPosted: 14:22 - 18 Mar 2009    Post subject: Reply with quote
Clicky
Embarassed I stand corrected. Last time I checked there weren't that many.
As for running costs like MPG they don't really effect me that much because my commute is so short (about 6 miles) and because it's so short I don't take the bike all the time Thumbs Up
Chequered Flag
neatbik
PostPosted: 14:25 - 18 Mar 2009    Post subject: Reply with quote
I get about 44 mpg overall from my s4, more if i do a sensible motorway run.
Insurance costs me £170 a year fully comp (29, 2 yrs no claims, had my license 2-ish years)
Its not heavy on brakes/chains/tyres, and in the time ive had it ive only spent money on servicing it, nothing has gone wrong.
I use it all year round and it lives outside, and it still buffs up well..
https://i349.photobucket.com/albums/q399/beatnck2/DSC00327.jpg
Before i got the s4 i test rode pretty much every 600cc naked bike out there, and a few more besides. None felt better than the Triumph.
It also looks a lot better than a bandit/hornet......... Mr. Green
Kris
PostPosted: 15:35 - 18 Mar 2009    Post subject: Reply with quote
Seems pretty good, probably a better alternative to the Hornet then...
Although still no contest if the OP is after a commuter bike really. To get a decent S4 (and I mean a good one) he'll be looking at spending his budget. Meanwhile I picked up a 3-year old immaculate Bandit with 7000 miles on the clock for £1950 two years ago.
Still, nice bike Thumbs Up
Keir
PostPosted: 16:28 - 18 Mar 2009    Post subject: Reply with quote
As someone else mentioned, also think about a Fazer. Probaby faster than the others and the brakes are amazing (blue spots). Parts are cheap and plentiful. Bikes can be had from £800-£2500.
Current : '08 Yamaha FZ1s
neatbik
PostPosted: 16:34 - 18 Mar 2009    Post subject: Reply with quote
Yeah, Fazers are pretty good bikes.
Kris, you're right, a Bandit can be picked up for less than an S4, but at the same time the S4 is a bargain really for what you get.
If i sold mine now i'd be very lucky to get any more than £2500, and mines a mint '06 plate...
teampots
PostPosted: 16:52 - 18 Mar 2009    Post subject: Reply with quote
Another Vote for Fazers here, the older ones anyway. very good bikes and very cheap to buy.
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
rac3r
PostPosted: 17:31 - 18 Mar 2009    Post subject: Reply with quote
I had a look at a few Fazers on autotrader and the 02 models look nice but i'm not sure for some reason it reminds me of couriers (no offence) Laughing
The insurance on the S4 comes out cheapest for me so it's going to be an S4 and if I can't find one then probably a Hornet. Thank you all for the info much appreciated Thumbs Up
Chequered Flag
Keir
PostPosted: 18:48 - 18 Mar 2009    Post subject: Reply with quote
Youre looking at bandits and hornets and accuse the fazer of looking like a couriers bike? lol. they are all courier specials!
craigs23
Mr Muscle
PostPosted: 19:32 - 18 Mar 2009    Post subject: Reply with quote
Seeing that they are used as courier bikes must say a little about their reliability and running costs.
I'd probably buy an early Bandit 6. Bomb proof engine, cheap as chips, job's a good'un. I was a little disappointed with my Hornet, didn't stir me.
colin1
Captain Safety
PostPosted: 22:13 - 18 Mar 2009    Post subject: Reply with quote
The way cat c/d works is that it has cosmetic damage that caused it to be an insurance write off do to cost of repair using brand new parts.
Cat c/d bike are safe to use on the road, as it was only cosmetic damage.
You can either just do what it needs to pass an mot, or, get all the cosmetic bits, to get it looking as it did before its little accident.
A lot of people drop their bikes anyway, so buying a cheaper pre-dropped bike means you dont devalue it if you drop it.
That cat C speed four I showed you may only need £50 spent on it to get it through an MOT, but to get it to look as it should, might need £400.
Having said this, to be honest, the TT600 and speed four, are more like sportsbikes than something like a bandit or a hornet.
They like being riden like a sportsbike, with a crouched forward riding position, as they have clip on bars, not high bars.
A bike for the weekend, rather than a commuter really. As your commute is a mere 6 miles, Im hoping you want something for the weekend.
The last post was made 17 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.41 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 137.39 Kb
