Heavy bar ends
T0MMY
PostPosted: 01:08 - 27 Mar 2009    Post subject: Heavy bar ends Reply with quote
Anyone know a good place to get heavy bar end weights cheap?
My CBR still vibrates too much and I'm beginning to give up on ever finding the reason Confused It has shitty aftermarket alloy bar ends so getting some heavier ones should at least help mask the problem Laughing
ZX6R + CBR600RR
Itchy
PostPosted: 13:34 - 27 Mar 2009    Post subject: Reply with quote
My CBR600F (99) bar ends appear to be light alloy also, however the actual clip ons appeared to be solid steel in that I was curious and had an angle grinder and a seriously bent clip on that was junk.
However the CBR600F is a smooth bike IL4 , maybe the vibes are an indication of something else wrong?.
Ie are your carbs sync'd (take a girlie on the back if they are not).
Valves done? ,
Chain correct tension
CCT in good condition?.
Wheel bearings in good nick?.
I did the Andorra to Bilbao in one day and didn't suffer any vibration problems bar the bolts at the top of the screen which were poorly tightened up anyway.
tsmith
PostPosted: 16:48 - 27 Mar 2009    Post subject: Reply with quote
try here
https://www.hvmp.com/
lonner
PostPosted: 19:31 - 27 Mar 2009    Post subject: Reply with quote
tomsmith wrote:
hi
fitted heavy weight bar ends to my honda sp2 and it stopped me getting dead wrist's and pinkies Thumbs Up
got mine of ebay for about £20 and worth every penny Very Happy
ajb
PostPosted: 21:20 - 27 Mar 2009    Post subject: Reply with quote
Interestingly my screen seems to get reverb around certain RPM. Did it before I had the DB screen fitted (the rubber washer things were fucked). I wonder if I need to tighten them.
CBR125R '05 > CB500 '00 > CBR600F '99
CrispyYzF
PostPosted: 20:47 - 21 May 2009    Post subject: Bar End Question Reply with quote
Trying to remove the Bar ends on my '95yzf 750. Having a little trouble. I dont know if its the screw in sort or the expandable sort.....anyone?
swiftb
PostPosted: 21:59 - 21 May 2009    Post subject: Reply with quote
zzr lon wrote:
tomsmith wrote:
hi
interesting stuff. After about an hour or so of riding i get pins and needles in my pinky and ring finger and in the palm/wrist area immediately below them. Is this a vibration issue then?? Thinking
Charlie
PostPosted: 22:10 - 21 May 2009    Post subject: Reply with quote
My left hand's middle finger goes totally white sometimes, apparently it is from holding onto something that vibrates a lot, and it can travel up your arm and is meant to be very painful if you get it bad.
Luckily it has only ever been my finger. Laughing
temeluchus
PostPosted: 22:24 - 21 May 2009    Post subject: Reply with quote
I'd be tempted to say you need to get your carbs balanced, I've never gotten whitefinger from any of my fours (and Ive owned quite a few).
Either that or try a grear above second......
mooserx
PostPosted: 09:46 - 22 May 2009    Post subject: Reply with quote
My old cbr used to vibe like mad, tried all the suggested things in this thread, ended up buying foam grips and big heavy bar ends. Sorted.
The grips used to get soaked in the rain but meh, they were only about £3 so a new pair every week wouldn't break the bank.
TL1000r-handful.
Charlie
PostPosted: 11:27 - 22 May 2009    Post subject: Reply with quote
Normally in 6th on the motorway/a-road.
80mph is around 11,000 rmp though... I felt sorry for the bike making it do that all the way back from Cornwall to Preston Laughing
PostPosted: 11:44 - 22 May 2009    Post subject: Re: Bar End Question Reply with quote
4s are not that smooth. If you want a smooth one get one with a balance shaft.
However they are normally not that bad but quite often land up with one spot in the rev range where they do vibrate, and if you are unlucky this lands up at your cruising speed (my FZ750 is was 70mph).
Not certain, but on quite a few Yamahas the end weight is threaded and screws into the bar.
T0MMY
PostPosted: 20:36 - 22 May 2009    Post subject: Reply with quote
Turns out that the vibes of my CBR600 are down to 2 separate things I reckon. Firstly, the engine does vibrate more than other CBRs I've ridden because it has much higher mileage but there is a more significant vibration under engine braking or very light engine load which I had failed to distinguish from the "other" vibration. This is possibly the clutch basket or something as it largely disappears if I take the slack out of the clutch cable. Any ideas Keith?
ZX6R + CBR600RR
PostPosted: 22:42 - 22 May 2009    Post subject: Reply with quote
Wouldn't expect taking the slack out of the cable to so much for vibration. Possibly if the clutch thrust bearing is on its way out, but suspect that would get worse taking the slack out.
T0MMY
PostPosted: 23:59 - 22 May 2009    Post subject: Reply with quote
To clarify; I mean if I'm cruising along the motorway on a light throttle and then apply very slight pressure to the clutch (not enough to cause it to slip) the vibration goes away. This is even more pronounced under engine braking.
ZX6R + CBR600RR
PostPosted: 08:16 - 23 May 2009    Post subject: Reply with quote
Afraid I can think of nothing likely to cause that.
With the clutch lever released the springs in the clutch should be pushing everything together pretty firmly. Only things that would not be firmly pressed together (and so likely to vibrate more like this) would be the thrust bearing, and the clutch lever (at both ends).
T0MMY
PostPosted: 08:27 - 23 May 2009    Post subject: Reply with quote
Ok, thanks Keith. I think I'll have to take it apart and just have a look, it is quite strange really but I've got into the (bad) habit of riding along with my hand resting on the clutch lever which makes the bike feel much more bearable on long journeys.
ZX6R + CBR600RR
The last post was made 17 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 100.94 Kb
