engine
piaggiowill
PostPosted: 09:09 - 26 Mar 2009    Post subject: engine Reply with quote
Hi all i have fitted my new engine and had it checked by the garage to make sure it was fitted ok, now i have rode it for a day and the revs die out in between half revs and full revs but then it keeps the revs on at full throttle but isnt goin fast then all off a sudden it just picks up speed, but then after five mins off riding it doesnt die out but when you stop for traffic lights it takes ages to build speed up again and i mean like 5mins. could it just be shit in the carb like the bloke from the shop said or is there something else ?
ringer
PostPosted: 10:36 - 26 Mar 2009    Post subject: Reply with quote
Sounds very much like fuelling problems. Suggest you remove carbs, strip them down and clean them. Take care stripping them down - watch out for how springs etc are attached. Take lots of digital photos as you go. Blow air through the jets - whatever you do don't poke at them with a bit of wire or needle!
Suzuki GT250 (stolen 1980), Kawasaki H1 500 (blew up 1982), Piaggio Liberty 125 (since 2008), Moto Morini 500 Strada (since 2008), CB125T (in bits)
piaggiowill
PostPosted: 13:16 - 27 Mar 2009    Post subject: Reply with quote
hi all i have stripped the carb down and cleaned it, it is still running as bad, i am just wondering what else it could be ?
ringer
PostPosted: 13:57 - 27 Mar 2009    Post subject: Reply with quote
Although I still think it will be a fuelling problem, let's eliminate other possibilities.
Buy and fit a new spark plug and plug cap - won't do any harm and will cost less than a tenner.
What you riding (I assume a Piaggio of some sort) and how old is it?
piaggiowill
PostPosted: 14:13 - 27 Mar 2009    Post subject: Reply with quote
ah right ok thanks Smile yeh its a piaggio zip 5 2stroke 2001 model with a 2004 engine Smile
Danzio
PostPosted: 14:23 - 27 Mar 2009    Post subject: Reply with quote
does the bike have a manual choke? if so turn it off Laughing
i was young and dumb once and forgot to turn my manual choke of on the nsr....wondered why it kept konking out at traffic lights, and when i pulled the throttle fully back...!
ah well!
:EDIT: this wont have a manual choke so forget what i said and put it down to random blethering....
piaggiowill
PostPosted: 14:36 - 27 Mar 2009    Post subject: Reply with quote
im just sick off it now, got the carb cleaned and put back together and then started it up and it run with no revs but then when i increase th revs up it runs fine at half revs but then dies at full revs and starts backfiring a little, i had the compression checked at the garage and it was at 115 so its got enough compression, i have also changed the spark plug and its still the same.
ringer
PostPosted: 14:51 - 27 Mar 2009    Post subject: Reply with quote
Good you fitted a new plug. For the sake of a couple of quid, fit a new plug cap too.
Next to check is timing - particularly advance mechanism (if a scooter has one) if it's not running right and backfiring at higher revs. Although I too have a Piaggio have been unable to get covers off so not too familiar with ignition setup.
piaggiowill
PostPosted: 09:07 - 01 Apr 2009    Post subject: Reply with quote
hi all just a update,i took the carb off cleaned it out and checked the main jat and it only had a 52 in so i took the carb off the old engine and took the main jet off that and its got a 72main jet o put that on and it seems to be working fine. cheers for the help guys Smile
The last post was made 16 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 65.29 Kb
