electric start on a tzr125 92 jap import
madmonkey125 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
Hex
Party Boy
PostPosted: 22:17 - 20 May 2004    Post subject: Reply with quote
You posted the same question here:
https://www.bikechatforums.com/viewtopic.php?t=25643
Asking more than once wont get you an answer quicker.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 23:25 - 20 May 2004    Post subject: Reply with quote
Possible using the bits from other Yamahas using the same engine but with an electric start, but not really worthwhile and likely to be expensive.
bikedudextrm
PostPosted: 01:30 - 21 May 2004    Post subject: Reply with quote
It may be possible, but will be expensive as you will have to get a starter motor, internal components , starter relay, switch cluster/button and all the hastle of wiring it up.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
jimbo
PostPosted: 19:37 - 21 May 2004    Post subject: Reply with quote
The first thing to check is that the ring gear for starting is on the flywheel. If not, forget about it.
As i recall (5 years since i've looked at a tzr) the starter motor hole is blanked off, but the recess and mounting holes are still there. In this case you just have to pop the blank out and bolt in the starter motor.
All the work is from the outside, so the engine doesn't have to be dismantled.
Wiring up the electrics would be a problem. If you really want to do it, i would connect it directly to the battery via a push-button switch mounted on the frame or something, rather than trying to splice back in to the electrical system. Would save a lot of hassle.
It can be done on lots of bikes, so if the gear and recess are there go for it Karma
The last post was made 21 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 44.85 Kb
