nc29 clutch problems
cormac83
PostPosted: 20:41 - 31 Mar 2009    Post subject: nc29 clutch problems Reply with quote
Hey been working on the bike for the last few weeks - had real problems with trying to get it to start, due to alarm imobliser that was fitted (meta) i removed this and with some persuasion and a lot of fiddling i got it to start on the button. Very Happy
Now when trying to put it into first gear the bike just cuts out.
Clutch is held in and when selecting first there is a clunk, the rear wheel moves a bit then the engine dies. Mad
Initally i thought it could be to do with the alarm removal that i did - checked all the wires i disconnected - resolidered and still happening.
Then checked the sidestand, light comes on when its down and goes off when up, i assume this is ok as its all connected.
The bike was fine before and could engage and move in first.
Any ideas??
Thanks
Suzuki GSX750 Inazuma
lonner
PostPosted: 20:53 - 31 Mar 2009    Post subject: Reply with quote
hi
i would check the stand switch thoroughly as it sounds like its stuck in even though the light goes out and any other safety switch hth
user
PostPosted: 21:34 - 31 Mar 2009    Post subject: Reply with quote
Try pushing the bike, first gear, cluch in and engine off. If the motor is trying to turn over (or more likely locking the back wheel), there is a problem with the cluch. If not, look at the electrics again, maybe try disconnecting the swich?
The last post was made 17 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 35.48 Kb
