Plumbers a bit of help?
Itchy
PostPosted: 21:00 - 31 Mar 2009    Post subject: Plumbers a bit of help? Reply with quote
Right my shower unit is OLD yellowed and full of crud and has virtually seized I know if I force it any more the plastic tab to control the water mixer will snap.
Rummaging around in the attic however I found a stainless steel mixer shower tap thing.
The bolts look like they are an exact match as they line up and are the same size.
So is it just a case of turning off the water supply , undoing the big two bolts on the yellowed shower mixer tap and bolting it back on ? , or is there something more complicated with this?.
And yes Leggygirl that is the colour a white motorbike will turn to after some time.
Any thoughts ? Karma
Ta
Retro-Man
PostPosted: 21:41 - 31 Mar 2009    Post subject: Reply with quote
Not a plumber but basically yes, the only thing I would do is after closing the stop cock open the taps to drain any residual water pressure, oh and use a little PTFE tape on the threads when fitting the new mixer
https://domharnessphotography.webs.com
Ant
PostPosted: 13:33 - 01 Apr 2009    Post subject: Reply with quote
it should do yes, i am a plumber and i say dont wrap ptfe everywhere, the shower should have two rubber washers!
04 ZX10R ~
Itchy
PostPosted: 14:57 - 01 Apr 2009    Post subject: Reply with quote
Riight thanks , I'm going to have a crack at it tommorow, its kind of lucky the guy across the road is a plumber incase I mess it up. Thumbs Up
The last post was made 17 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 41.74 Kb
