XR125 starter solenoid
dgo1212
PostPosted: 11:42 - 01 Apr 2009    Post subject: XR125 starter solenoid Reply with quote
have bought an XR 125 which had a starting problem when i got it,when i pressed starter button it seemed to ark out across top of terminals,both wires are tight and secure however it was hanging on the frame,put it back in the right place as i thought it was earthing on frame and it was starting fine yesterday however this morning its arcing again,wiggled it and put it back and it started,anyone had this before?i don't mind buying solenoid if it's broke but why would it arc across the top?
Cigaro
PostPosted: 12:01 - 01 Apr 2009    Post subject: Reply with quote
It could arc across the top as when you release the starter button the solenoid springs back and the magnetic field collapses causing back-EMF, which can be of sufficiently high voltage to cause an arc.
By the way, the starter is meant to be attached to the frame, that's how it connects to ground.
dgo1212
PostPosted: 12:18 - 01 Apr 2009    Post subject: Reply with quote
wasn't arcing on release was arcing as i pressed start button and the starter wouldn't turn it just cut the power off altogether for about 10 seconds,the solenoid was hanging on the frame but is now mounted onto the plastic mount in the clip where it should have been before,it only does it now and again now have to shake the solenoid to get it to start but it means removing the side panel,just want to be sure it was the solenoid thats faulty and not a faulty wire or something
There is a gap of 3 years, 224 days between these two posts...
threepot
PostPosted: 21:22 - 10 Nov 2012    Post subject: XR125 Starter prob Reply with quote
My daughters xr (recently purchased) makes a clicking sound when starter button pressed. Noise Seems from starter solenoid? Could this be the prob? Battery is good. Will only start on bump. thanks
Fizzer Thou
PostPosted: 15:17 - 12 Nov 2012    Post subject: Reply with quote
If you short across the two main posts of the solenoid does the bike then start?
Although you say that the battery is good,if the earth strap from the negative side of the battery to the frame is not making a good connection,the starting power from the battery to the starter motor is insufficient to spin the engine over.
If you have a multimeter a few small checks will be sufficient to enable you to isolate the problem.
Always have a 'Plan B'
The last post was made 13 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 43.78 Kb
