Help with cb125 starter
priestessuk20...
PostPosted: 13:08 - 01 Apr 2009    Post subject: Help with cb125 starter Reply with quote
ok help needed, she starts most of the time no problem,
but ever now and again she is dead, horn work but the start button does not, the neutral light goes of at the same time
so then you sit there and wait for the neutral light to come back on and she will start ok, now hubby has booked his test for monday
what will happen if the bike does this while on the test??
And anybody know how to fix this please
priestessuk
yes passed cbt 27/10/08
currant - honda CB125 T
Cigaro
PostPosted: 14:23 - 01 Apr 2009    Post subject: Reply with quote
Does the bike only start in neutral (with the clutch in)?
It sounds like a problem with the neutral sensor switch in the gearbox, to me.
You can bypass it fairly easily, if this is the problem.
priestessuk20...
PostPosted: 14:29 - 01 Apr 2009    Post subject: Reply with quote
dont know about that, we switch ignition on, hit the start and nothing, it was at this point that we noticed the neutral light wasent on as soon as it comes on we can start the engine,
was realy bad two days ago yesterday it only happen once but so far twice today !!
priestessuk
Cigaro
PostPosted: 14:33 - 01 Apr 2009    Post subject: Reply with quote
With the neutral light on, drop it into first and try starting it with the clutch in. Does it work then or not?
priestessuk20...
PostPosted: 14:36 - 01 Apr 2009    Post subject: Reply with quote
for that answer we will have to wait for the next time she wont start, will let you know,
will he get into trouble on test day?
if the bike dont start straight away???
priestessuk
Cigaro
PostPosted: 14:43 - 01 Apr 2009    Post subject: Reply with quote
No, try it when it will start. I am aiming to find out if your bike has an inhibitor so it won't start unless it's in neutral (safety feature). If so then this is probably what is causing the problem.
priestessuk20...
PostPosted: 14:51 - 01 Apr 2009    Post subject: Reply with quote
yes she starts fine in first gear.
priestessuk
Cigaro
PostPosted: 14:59 - 01 Apr 2009    Post subject: Reply with quote
Sounds more like a faulty ground connection then.
dgo1212
PostPosted: 16:34 - 01 Apr 2009    Post subject: Reply with quote
Have posted a topic with basically the same problem,i've found if i shake the starter solenoid it starts up fine,does it sound like it sparks as you try starting it?
priestessuk20...
PostPosted: 21:15 - 01 Apr 2009    Post subject: Reply with quote
hiya sorry had to do a few hours at work,
right when it plays up there is no noise once you press the starter,
and could he get into trouble if bike fails to start while on test??
priestessuk
priestessuk20...
PostPosted: 07:26 - 02 Apr 2009    Post subject: Reply with quote
ok
priestessuk
Cigaro
PostPosted: 10:21 - 02 Apr 2009    Post subject: Reply with quote
Depends what you mean by "trouble"?
They might not let him do the test if it refuses to start.
priestessuk20...
PostPosted: 10:23 - 02 Apr 2009    Post subject: Reply with quote
the longest we had to wait for the neutral light to come back is maybe 5 minutes.
priestessuk
priestessuk20...
PostPosted: 10:09 - 03 Apr 2009    Post subject: Reply with quote
darn and blast she is playing up again this morning
he checked the groundcable its ok, moving the front about left to right the light came back on, he is going to ride down to local garage to see if anybody there can help..................
he is nervous enough after two fails on DAS to be messed about with the bike
thanks for trying to help
priestessuk
finpos
PostPosted: 13:31 - 03 Apr 2009    Post subject: Reply with quote
Chaffed wire where the wiring loom passes around the headstock. If you are lucky the chaffing will be clearly visible (pull the loom away from the frame and look behind it for exposed wire), if you are not so lucky a wire will be broken inside the wrapped loom.
Another possibility is that one of the multi-block connectors is loose, give them all a good shove.
f.
priestessuk20...
PostPosted: 13:49 - 03 Apr 2009    Post subject: Reply with quote
he just come back in from last lesson,
speedo stopped so did his back brake light now and again,
he aint a happy bunny glad I am of to work soon
naught worse then a bloke in bad mood
must be my fault as it is my bike !!
priestessuk
tutton
PostPosted: 21:43 - 03 Apr 2009    Post subject: Reply with quote
If he failed two DAS tests, and is doing das again he wont be using your bike anyway?
The last post was made 16 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 90.08 Kb
