My daily transport
Billing
PostPosted: 16:16 - 02 Apr 2009    Post subject: My daily transport Reply with quote
Bought this in april last year, so far it's been a cracking little bike, cost me next to nothing to run so far. came with 28350 miles on the clock, I misaligned the speedo drive and did 1200 miles before putting it right, so it currently ''only'' has 34700 miles on the clock!
https://i207.photobucket.com/albums/bb73/sam_billing_91/Photo-0132.jpg
https://i207.photobucket.com/albums/bb73/sam_billing_91/Photo-0134.jpg
The only things I have had to replace because they properly broke was the clutch cable (£10) and the front wheel bearings (£15)
As for servicing:
Rear tyre £30
Inner tube £10
Oil £40 for 8 litres (its burning a little bit atm)
2 X Spark plug (£3)
Chain and sprockets £45
Bulbs/other less than £15
I wanted it for the solid reliability and excellent fuel economy (try 650 miles for £31.50!)
Recently fitted a new set of clocks as the others had been damaged after someone tried to remove the key with the ignition on while I was waiting at the trafic lights =[ they now show just over 21000 miles Thumbs Up
PostPosted: 17:34 - 02 Apr 2009    Post subject: Re: My daily transport Reply with quote
What oil have you been using?
Billing
PostPosted: 23:00 - 02 Apr 2009    Post subject: Reply with quote
Rock oil 10W40, I think the rings are on thier way out because if I take off hard it smokes a bit, but usually its clean. It uses 50 - 100ml per 150 miles, so I'm not that fussed. I've changed the oil 3 times already to keep it nice and clean
PostPosted: 23:08 - 02 Apr 2009    Post subject: Reply with quote
It just sounds very expensive for oil that you're putting in a CG. If I had a CG it'd be having £2 a litre mineral oil.
Billing
PostPosted: 23:26 - 02 Apr 2009    Post subject: Reply with quote
Well when I first got it I got some from halfrauds and it made it difficult to start without the choke for some reason, got a bottle of Rock, dropped the halfrauds stuff out and its been running much better ever since, never ever needs the choke =]
Billing
PostPosted: 12:51 - 30 Apr 2009    Post subject: Reply with quote
The CG is in bits in the college workshop, I got a new set of headstock bearings and have gotten 60% of the way through, just gotta put the actual bearings in, and then get the forks back on Smile
sunama
PostPosted: 01:04 - 30 May 2009    Post subject: Re: My daily transport Reply with quote
BillingTZR wrote:
... after someone tried to remove the key with the ignition on while I was waiting at the trafic lights
Can you give us more details about this incident. It sounds very interesting and I also wonder how someone builds up the courage to do something like that, while the owner is sitting on the bike.
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 54.03 Kb
