Aprilia RS50 Serios Problem
Theoutsider
PostPosted: 16:57 - 02 Apr 2009    Post subject: Aprilia RS50 Serios Problem Reply with quote
I don`t know why but i get oil in water(coolant).I reckon it is oil engine.Is this possible>?What should I do?
baldy
PostPosted: 21:00 - 02 Apr 2009    Post subject: Reply with quote
Are you sure it's oil? The water jacket is completely separate from the gearbox oil. I think it wouldn't run for long if there was a passage between the two before it seized up. Do you have water in the oil?
One day i will rule the world, just not today.
B10Hazard
PostPosted: 23:06 - 02 Apr 2009    Post subject: Reply with quote
Drain the system and put fresh in, could just be crap in there from previous owner etc.
If it is oil i highly doubt its from the engine matey. Thinking about it i cant find a way for oil to get there via the engine. Like baldy said . . completly seperate.
No longer any socks
tutton
PostPosted: 15:10 - 03 Apr 2009    Post subject: Reply with quote
he could be on about water in the gearbox oil...
Tristan.
PostPosted: 15:15 - 03 Apr 2009    Post subject: Reply with quote
Without knowing anything about the 'prillia 50 engines I would say the only likely place to have the coolant and the gear oil coming together would be at the water pump, unless it's driven off the crank.
Are you finding oil in your coolant or coolant in your oil?
Theoutsider
PostPosted: 22:38 - 03 Apr 2009    Post subject: . Reply with quote
Oil in coolant.Ok and I have few more questions.Why does it overheats?It doesn`t start from the button not even with the iridum spark plug,just bumb start,and when I accelerate I have to rev the shit out of it to go if not it dies,and it is really annoying and stresful
tutton
PostPosted: 22:41 - 03 Apr 2009    Post subject: Reply with quote
Needs a bump start and needs high revs to keep it going means you have very little compression if my memory serves me correct, thus needing a top end rebuild, if you want to proove this theory get hold of a compression tester.
Not sure on the oil in coolant yet..
baldy
PostPosted: 22:43 - 03 Apr 2009    Post subject: Reply with quote
It could be a few things, the mechanical water pump seal could be leaking ot the head gasket. If there is oil in the water you have a serious problem. If it overheats all the time it may seize up.
Theoutsider
PostPosted: 22:44 - 03 Apr 2009    Post subject: Reply with quote
I have checked the piston and the rings and they are perfect.I only have 1000 miles with this piston.Could it be gaskets?
The Artist
PostPosted: 22:47 - 03 Apr 2009    Post subject: Reply with quote
Surely you can't be serios?
baldy
PostPosted: 22:48 - 03 Apr 2009    Post subject: Reply with quote
How did you check them? Just looking at them wont tell you if they are worn out. It could be the bore that is worn. Do a compression test first. If you have had the engine apart you will have to renew the gaskets or they will probably leak. If you have changed the piston, did you change the rings, small end bearing, circlips and gudgeon pin and gaskets?
Theoutsider
PostPosted: 22:52 - 03 Apr 2009    Post subject: Reply with quote
I have changed everything except gaskets as they look alright and piston and rings
Theoutsider
PostPosted: 22:56 - 03 Apr 2009    Post subject: Reply with quote
Baldy have you got an nsr for sale>?can you give me more details.Thanks
baldy
PostPosted: 23:16 - 03 Apr 2009    Post subject: Reply with quote
Sold it this afternoon, the guy hasn't picked it up yet, but if it all goes pair shaped i'll let you know.
details are here
GSXR_Warrior
PostPosted: 23:41 - 03 Apr 2009    Post subject: Reply with quote
I have had this before on cars that I have owned, not on any bikes though.
Was always a head gasket problem.
GSXR600K4 Blue - fastest colour. No mods as yet. Happy with standard bike.
www.twitter.com/GSXR_Warrior
Billing
PostPosted: 00:39 - 04 Apr 2009    Post subject: Reply with quote
Just because the gaskets LOOK ok doesn't mean they are, they could be warped, and if so could be a cause for your oil in coolant problem Thumbs Up
Theoutsider
PostPosted: 15:28 - 04 Apr 2009    Post subject: Reply with quote
Ok no more oil in coolant.But it overheats and it does not start from the button.Badly of the guy doesn`t pick up the bike let me know.Thanks
Theoutsider
PostPosted: 18:09 - 04 Apr 2009    Post subject: Reply with quote
Sorry.What I did want to say was,Badly if the guy doesn`t pick up the bike let me know.
RugbyGriffo
PostPosted: 07:53 - 05 Apr 2009    Post subject: Aprilia Rs 50 Oil Reply with quote
Hey, My Bike Is Making A Serious Noise And i Found Out it Was The Gearbox But There was No Oil In There Shocked Does Anyone Know What Oil In Takes?
Very Happy
Aprilia Rs 50
70cc Bore Kit
21mm Carb
Arrow Racing Pipe
Few Other Bits Nd Bobs
75-80 mph
Aprilia Rs50 - For Sale Razz
Buying a TZR
The last post was made 16 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 97.64 Kb
