need help with yzfr125 + gear indicator
KevShek
PostPosted: 00:49 - 03 Apr 2009    Post subject: need help with yzfr125 + gear indicator Reply with quote
Hi all,
Im trying to install a gear indicator on my r125, but having difficulty tracing down which wire i need. Ive got the wiring diagram for the bike but im stuck on a couple of the wires.
1. Tach wire
2. Speed wire.
Does anyone know which colours they are and where located?
I assume that both will goto the ECU but both sensors have more than one wire which goes to the ECU.
Can you measure revs at the ECU using a normal multi meter? if so, how?
Im gonna try the speed wire by manually spinning the wheel to see if any of the indicated wire give a variable resistance when the front wheel is in motion.
YZF R125
baldy
PostPosted: 17:48 - 03 Apr 2009    Post subject: Reply with quote
Can you not get the readings from the back of the speedo and rev counter? If not i would join the tacho wire to the low tension side of the coil, and the speed wire directly to the output of the speedo drive, that's if it's a electronic output not a cable drive.
One day i will rule the world, just not today.
KevShek
PostPosted: 18:54 - 03 Apr 2009    Post subject: Reply with quote
I've been on the phone to acumen and they have been really helpful. I've tapped into a couple of sensor wires by the ecu and fingers crossed, they shud work.
YZF R125
The last post was made 16 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 36.51 Kb
