Odd problems with PC
SoND
PostPosted: 18:57 - 02 Apr 2009    Post subject: Odd problems with PC Reply with quote
PC has been quite unusual in the past couple of days and I have no idea what is going on.
Process list in the task manager doesn't update properly, specifically the Mem Usage. Normally the figures are jumping about and changing constantly but now they're pretty much fixed and sometimes the process doesn't clear after I exit a program and it won't let me end it manually.
The CPU and Page file graphs under the performance tab haven't worked ever since I upgraded my ram to 4gb, I've put this down to windows being pissy with it's 32-bit wall.
I think firefox updated yesterday and now cookies and sessions won't save. Every where I would be automatically logged in I'm logged out and need to log in manually when I open the browser. Usernames and some passwords are still saved in the textboxes in the login menus. Everything in the options looks set ok and hasn't changed from before. It managed to hit over 1,000,000K usage last night somehow with less than 50 tabs open, I'm not sure I have seen it go that high even with 300 tabs open. Google suggested finding the cookie file in the profile and changing the extension to .tmp, didn't help.
Got a random BSOD and restart when I booted up today. Wasn't doing anything in particular, hasn't happened before and hasn't happened again just yet.
Some programs 'encounter a problem' and need to close. Windows media as soon as I open a file, you could move the error and it worked properly, this has stopped though. Fallout 3 is completely random when it does it can happen after several minutes or several hours. 3dMark06 everytime I click to view my results, reinstalling did not help. This has been happening longer than the task manager problems.
Have ran Memtest86 and OrthosPrime95, passed both no problems. Tried windows system file checker and that didn't reveal any problems.
AVG, Spybot, SuperAntiSpyware, Avast, Malwarebytes are all updated and finding nothing except the odd tracking cookie.
The 500w power supply I have at the minute is borderline for my system but everything was working fine for a few weeks, a new one is on it's way.
Do my problems sound familiar to anyone? Googling hasn't found me anything. Confused
Specs
XP Pro SP3
E5300 2.6ghz OC to 2.9
9800 GTX+ standard clock with latest drivers
4gb DDR2
3x SATA Plenty of space left
https://img.photobucket.com/albums/v612/SoND/taskman.jpg
https://img.photobucket.com/albums/v612/SoND/cpuzscreen.jpg
https://img.photobucket.com/albums/v612/SoND/3dmarkerror.jpg
The Artist
PostPosted: 08:58 - 03 Apr 2009    Post subject: Reply with quote
Looks like its time for a fresh install of xp...
UnknownStuntm...
PostPosted: 16:34 - 03 Apr 2009    Post subject: Reply with quote
^^^lol^^^
Anyway, it's most probably your memory - try taking a chunk of it out and see if the problem goes away. Memtest doesn't stress test the ram, it only writes and reads it, and I've read a fair few cases where it hasn't reported errors but they're definitely there. I'm fault finding similar with the techies at Crucial at the mo, they said take a stick out and try it. Then swap sticks about to see if you can id a duff stick.
PostPosted: 17:10 - 03 Apr 2009    Post subject: Re: Odd problems with PC Reply with quote
Before you start ripping memory out and reinstalling XP, have you tried rolling back to a restore point prior to when you started having probems?
GodzGift
PostPosted: 19:00 - 03 Apr 2009    Post subject: Reply with quote
conficker virus has got you, the only solution now is for you to burn your PC.
Bike Level: Amateur | CBT Passed
SoND
PostPosted: 15:24 - 04 Apr 2009    Post subject: Re: Odd problems with PC Reply with quote
Forgot about system restore. Tried it and it said something about how it was useless and no changes were made.
Took the memory out and was able to set it to 333mhz with 1 stick, it doesn't boot up at this speed with 2 sticks. With either single stick, at both clock speeds, the computer ran slower and more unstable than with 2.
Neutral
Flip
PostPosted: 17:33 - 04 Apr 2009    Post subject: Reply with quote
If my pc gets that fubared I back everything up and go back to factory settings. Yet to have a problem not fixed by this.
WildGoose
White Van Man
PostPosted: 23:05 - 04 Apr 2009    Post subject: Reply with quote
No idea im afraid, but just thought I would empathise, as I got my first BSOD on XP this evening for no apparent reason, then it rebooted without giving me time to read the blue screen.
Got a services.exe running under 'owner' in the task manager processes, which I don't recognise, and think it is some sort virus trojan thing.
Comp has been getting steadily slower for months, music jumps and skips quite a lot, and it will hang for ages sometimes with no obvious excuse.
Hate this stage in the microsoft cycle.
WildGoose
White Van Man
PostPosted: 21:36 - 05 Apr 2009    Post subject: Reply with quote
Quick update, just spent the latter half of the day formatting the bastard Evil or Very Mad , was up until 3am last night trying to get rid of the virus and getting nowhere, meanwhile the PC was slowly dying and chugging slower and slower.
Binned F-secure as I now have no faith in it Thumbs Down , and brought in Kaspersky instead Thumbs Up . Rather impressed, it has found over a dozen dodgy things in files i've had downloaded for ages, that f-secure didnt even blink at.
First proper full format, and it wasn't as painful as I was imagining, except thousands of loading bars, nice to have that fresh install feeling again, got 3 years out of it without major issue, think thats pretty good for windows. Partitioned it differently this time, the way I wanted to when I first built it but for some reason didn't. So hopefully should run better this time round.
PostPosted: 21:58 - 05 Apr 2009    Post subject: Reply with quote
Nice, isn't it? I've just put a new hard drive in my laptop, the old one was 4200rpm and 32GB, this one is 5400rpm and 120GB. Took the opportunity to put XP Pro on instead of Home whilst I was at it. It's the first reinstall it's had since I got it in 2004, previously it took 1:55 to get to the desktop and 2:39 before it finished chuntering to itself loading stuff, now it's at the desktop and useable in 0:36.
Should have done it ages ago Smile
WildGoose
White Van Man
PostPosted: 22:15 - 05 Apr 2009    Post subject: Reply with quote
God you must have been seething to actually time it, but yes thats probably the most noticeable difference. Thumbs Up
The old install wasn't shutting down for over 6 months it would just log out and hang, nice to be able to shut down and restart and be back to the desktop ready for work within 60 seconds.
Won't last, but at least I know how to format this time, it wasn't as bad as I was imagining, like removing an engine, or any other of those males rites of passage.
JonB
Afraid of Mileage
PostPosted: 22:19 - 05 Apr 2009    Post subject: Reply with quote
Jesus. Imagine if you had a 7200RPM HDD. Razz
I know you all hate me for it, but one of the things I have found to be one of Vista's biggest selling points is the fact that it doesn't slow down over time.
I remember one of my old computers, it was getting so clogged up, I literally used to cry in anger when I installed a program and it would tell me to restart the computer, it used to take about 10 minutes. No kidding.
I do love a fresh install though. Used to do it every 3-6 months when I used XP, generally don't bother anymore.
SoND
Good to hear you've got it sorted again. Thumbs Up Did you do any general maintenance before it started slowing down?
I really can't be assed with formatting and reinstalling anything right now, not sure if it will make much difference. Everything seems to be running quick enough, just random program crashes and errors are getting on my tits. Will sooner try some new ram and the power supply, if that doesn't work then I'll do the reinstall. I've convinced myself the psu is a problem so hopefully it will be here tomorrow and shut me up. Laughing
JonB
Afraid of Mileage
PostPosted: 22:24 - 05 Apr 2009    Post subject: Reply with quote
It is no way going to be the PSU. The PSU is exactly what it says on the tin. A Power Supply Unit. It doesn't involve itself with software at all. If you have any issues with the power supply you notice other hardwares failing first.
It's just your current install of XP. 100% guarantee it. IF it is hardware it is going to be RAM, not PSU.
SoND
PostPosted: 22:59 - 05 Apr 2009    Post subject: Reply with quote
Current PSU is rated 20A on the 12v+ and it's recommended I need 26A for the graphics card. Also the fact that I can't run the RAM at higher speeds with both sticks makes me think it's on the edge without needing a lot to push it over.
https://extreme.outervision.com/PSUEngine - When I calculate it using this it's pretty borderline. I'm upgrading the PSU anyway for SLI so if it doesn't make a difference it's no loss to me, just one less thing to worry about. Smile
If I end up doing a reinstall I'll probably do a dual boot with vista. Thinking about 64-bit but don't know if my 32-bit games will play on it, not concerned about them making use of the 64-bit, it's the dx10 I'm after. Want the 64 for 3d modelling. What do you think? Laughing
GodzGift
PostPosted: 10:05 - 06 Apr 2009    Post subject: Reply with quote
How old is your PSU? generally speaking if you have it for a few years its a good idea to upgrade it, and I have seen PSU fail on many PCs before.
You can also get your PSU tested but if you planning on running SLI having a top spec PSU is a must.
JonB
Afraid of Mileage
PostPosted: 10:44 - 06 Apr 2009    Post subject: Reply with quote
Typical, I am just about to sell a year old OCZ GameXstream 850w SLI ready PSU. Cost me £120, was gonna sell it on for £50.
I decided to downgrade to a 520W modular PSU as I no longer use my PC for gaming.
PostPosted: 11:49 - 06 Apr 2009    Post subject: Reply with quote
That's because it comes ready-crippled out of the box Smile
SoND
PostPosted: 17:44 - 08 Apr 2009    Post subject: Reply with quote
I bought that exact one for £140 Doh!
I'm not sure what to say. Firefox sorted itself out over the weekend and is working normally again.
Got the PSU, put it in last night and didn't notice any immediate difference. Couldn't clock the memory up as I hoped, task manager and everything else stayed the same. Fair enough, it was a failure.
Today my task manager is working properly. Processes are updating and shuffling about like they should but the performance tab is working too Surprised. CPU and PF usage are showing up for the first time since installing the memory as if by magic. Yay they're working but I've no idea why Neutral.
SoND
PostPosted: 14:49 - 16 Apr 2009    Post subject: Reply with quote
Got 2x new 1gb sticks of RAM to try last night and it looks like everything is sorted now. Can set its speed to the full 667 and can overclock the CPU to 3016mhz now, up from 2964.
3dMark stopped giving me errors so I bought the advanced version to really stress the card. Could turn the memory on the card up to 1370 and run all tests except 1680 x 1050 with 8x anti-alias and 16x af. When the pixel shader test was repeated temps hit 68ºC and it froze. Had to scale it back to 1317 and it worked fine and temps didn't go above 61.
Haven't ran 1680 x 1050 overclocked without aa or af or 8x aa 16x af on default.
Overclocking the cpu made a big difference but it still runs 100% in a lot of the tests.
Card is a Inno3D 9800 GTX+
https://img.photobucket.com/albums/v612/SoND/rivatunersettings.jpg
https://img.photobucket.com/albums/v612/SoND/excel.jpg
The last post was made 17 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 113.97 Kb
