| Hello there mandem |
 Hello there mandem Scooby Slapper
| B10Hazard |
 B10Hazard World Chat Champion
 Posted: 21:41 - 04 Apr 2009 Post subject: |
I am asuming you have your bike restricted to 33bhp via your carb ( with throttle slide stops )
It's quite and easy job so long as you have some idea what your doing when it comes to working with carbs ( ie taken one apart to clean etc )
https://www.indyhpmedia.com/pics/BennyBlown2v/R1/slidestop.jpg
This is a picture that may help ( Of a carb that has a throttle slide restriction)
If you are unsure and not to confident or not really machanically experienced enough i would have a shop or someone who knows what there doing properly to do it.
Before you go ahead and remove them make sure your bike isn't restricted in any other ways.
dan ____________________ Current bike .. The police stole it
No longer any socks
Let me take you on a trip . . let me show the world in my eyes. |
| blutonium92 |
 blutonium92 Scooby Slapper
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 22:59 - 04 Apr 2009 Post subject: |
its really easy, even on v4 (no offense intended, it just takes bit more effort to get the carbs free of the boots)
pull the tank off air box off, then the carbs, the washers are between the carbs and the intake,
while you re t it remove the float bowl and check the size of the main jets to see if they have been changed as well. then pull the top of the carb off nd have look t the slide/piston to see if nother hole hs been drilled in it (not common, but they sometimes do it) re-assemble every thing, nd bobs your uncle, job done,
it should tke bout 1-2 hours if you have never taken crbs off before, if you have then its half hour job
have fun  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| B10Hazard |
The last post was made 16 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
