Bike won't start :(
blurry
PostPosted: 14:17 - 05 Apr 2009    Post subject: Bike won't start :( Reply with quote
Hi, I have an aprilia rs125 07 model. Its been stood a couple of months, and now I cant get it to start. Theres plenty of petrol in the tank and Ive been and bought a new battery. When I push the start button it clicks but wont start. Ive also had it in first and rocked it back and forth just to make sure the starter motor isnt stuck...it sounds like it wants to start. I've tried bumping her down the street several times but nothing...help Sad What can I check next?
Thanks in advance.
tutton
PostPosted: 14:25 - 05 Apr 2009    Post subject: Reply with quote
Carb,
most likely needs a clean out
especially the main and pilot jets.
Although you dont say whether your hearing the starter trying to turn it over at all?
blurry
PostPosted: 14:35 - 05 Apr 2009    Post subject: Reply with quote
When I press the start switch it clicks but dosent go ant further than that, its not turning over.
I rode it a while back and everything was ok...
tutton
PostPosted: 14:36 - 05 Apr 2009    Post subject: Reply with quote
Did you charge up the brand new battery?
sounds like first you need to get it turning over, the clicking noise is usually caused by a dead flat battery, not having enough power to spin the starter over.
PostPosted: 14:37 - 05 Apr 2009    Post subject: Reply with quote
Dead battery Thumbs Up
Maybe you're not getting a spark because of it.
blurry
PostPosted: 14:44 - 05 Apr 2009    Post subject: Reply with quote
The batteries fully charged Confused
PostPosted: 15:01 - 05 Apr 2009    Post subject: Reply with quote
The engine should turnover then.
Blue_SV650S
PostPosted: 15:33 - 05 Apr 2009    Post subject: Reply with quote
How do you know the battery is fully charged? Have you measured its voltage?
Its possible the new battery you bought is faulty.
Are you sure you have connected it the correct way?
blurry
PostPosted: 16:52 - 05 Apr 2009    Post subject: Reply with quote
The battery charger says the batteries full, and yup its all conected the right way. Ive just bought a new spark plug for her too.
Blue_SV650S
PostPosted: 17:13 - 05 Apr 2009    Post subject: Reply with quote
If you have a voltage sensing charger, its still possible to have a dud battery and its showing its as good.
A battery can produce a healthy voltage, but have no actual 'punch'. I think we need to eliminate the battery as a possible cause before going further. The best way to do this is with a set of jump leads direct from a car. i.e. Jump start it from a car Thumbs Up
Ben_m
PostPosted: 17:14 - 05 Apr 2009    Post subject: Reply with quote
Im not saying your an idiot at all mate but my battery charger said exactly the same thing on my battery a couples of weeks ago but the bike wouldn't start. I measured the voltage and it was only about 5v - 6v. I got a new battery, charged it, fitted it and the bike started as soon as I pushed the button.
blurry
PostPosted: 18:23 - 05 Apr 2009    Post subject: Reply with quote
thanks for the replies, jump starting it from the car was the next option Very Happy I'll let you know how it goes...
joan33987
PostPosted: 20:11 - 05 Apr 2009    Post subject: Reply with quote
engine seized due to rust or corrosion of the cylinder walls.
My SR 50 seized after I left it untouched for 3 months in a cold shed.
But i'm not sure, cuz i sold it as spares and repairs in ebay straight away
current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project
Blue_SV650S
PostPosted: 21:29 - 06 Apr 2009    Post subject: Reply with quote
Come on, don't keep us in suspense! ... how did you get on with the jump-start? Thinking
PostPosted: 00:42 - 07 Apr 2009    Post subject: Reply with quote
Try bump starting it this can free up the engine if it is seized abit like joan says.
Sit on the bike with the ignition on and get some mates to push you, first try in first or second gear with the clutch in once your up to speed let the clutch out fast if this should turn the engine over. Give it some gas and bounce on the seat.
Draining the tank and putting fresh juice in would be a good idea.
blurry
PostPosted: 01:05 - 14 Apr 2009    Post subject: Reply with quote
Hi, I finally had chance to take another look at her. It was the filter in the fuel tank that was clogged up. When I emptied all the fuel out the bottom was full of crap. She's all good now Smile and Ive had her out for a spin today Smile
Thanks for all your help and advise Smile
The last post was made 17 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 88.72 Kb
