| indo247 |
 indo247 Derestricted Danger
 Posted: 13:37 - 15 Mar 2009 Post subject: Kmx 200 engine in 125 |
Hi all,
I've just got hold of a KMX 200 engine, and was thinking about putting it in my 125. it looks to me like i could use the KMX 125 bottom end and use the piston, barrel and head from the top end of my spare engine.. which would mean i'd have the 125 engine numbers
Has anyone here ever done this mod? i know i need a new exhaust and re-jet the carb. what about the electrics would it all be the same? |
| lukamon |
 lukamon World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 18:57 - 15 Mar 2009 Post subject: |
make sure you file off the bit that says ''198cc'' on the barrel. otherwise your just asking for trouble. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| dougon2wheels |
 dougon2wheels Nitrous Nuisance
| mad4it028 |
 mad4it028 World Chat Champion
| stevo as b4 |
 Posted: 23:36 - 15 Mar 2009 Post subject: |
The stroke is 54.5mm, the same as the 125. It's the bore which is bigger at 67mm. There is some extra power and torque to be had from the 200cc engine, and a good one can put nearly 95mph on the speedo in good/favourable conditions. It never feels as lively as a Kmx or DT 125 as there is much less of a power band and the engine is quite de-tuned in the port timing and by the exhaust and carb size, compared to the 125, so the extra 6bhp at peak you have as std never feels that much. It does not need tap dancing on the gearlever to find good acceleration and to be able to maintain 60-70mph like the 125 would need. The engine actually pulls well from 2500rpm, and with std gearing it will wheelie off the throttle in 1st and 2nd at 5000rpm. It's more like a DT175MX in it's power delivery than a DTR125 for example.
The carb is the same size, and just needs the jets, needle and slide changing. The gearing is 16/50t instead of 14/48t, and the exhaust is different. AFAIK the CDI is the same or at least has the same timing curve and no rev limit, except for the retarding of the timing at speeds above peak power, which does the same function as a spark cut. The gearbox internal ratio's are different on the 200 engine, but this wont make any difference to it fitting a 125cc bottom end. You need the head as well as the barrel as they are different. |
| indo247 |
| Kickstart |
 Kickstart The Oracle
| stevo as b4 |
 Posted: 22:44 - 16 Mar 2009 Post subject: |
Yeah my first 200 would in still conditions cruise at an indicated 75-80mph without pushing it. You could increase the top speed by 10mph almost by just sitting prone. It would do 80 easily, but an indicated 90mph was full throttle, which says more about the aerodynamics than the power available. The MCN official stats were a tested 93mph top speed, and 15.2sec 1/4m at 88mph.
I always have thought about what would a KMX200 engine be like in a Cagiva Mito. I've never come across a cheap Mito minus an engine, but if i did that would be my thinking!
For Cylinder repair/replating work you could speak to James at BDK engineering. I've had a chat with him as he used to have a KMX200 that was tuned to the hilt. He will be doing my cylinder re-conditioning and tuning work when i get around to sending it to them. |
| indo247 |
| Zedxfarin |
 Zedxfarin Nova Slayer
| stevo as b4 |
| Kickstart |
| indo247 |
| indo247 |
| Kickstart |
 Posted: 20:20 - 27 Mar 2009 Post subject: |
| indo247 |
| stevo as b4 |
| indo247 |
| indo247 |
| stevo as b4 |
| indo247 |
 Posted: 23:17 - 06 Apr 2009 Post subject: |
thanks for all your input, very helpful.
I compared the 125 valves to the 200 and they are much smaller, i'm still not entirely sure they are set right, but as i can't find any it will have to do for now?
I will try the 70/30 anti freeze, at the mo it's just got water in it, cos i don't hav any antifreeze, thats maybe why it's getting hot?
i still have the 125 gearing on it 14/48, i have a 16 tooth front sprocket but no 50 tooth back one thats the standard gearing for the 200. what would it be like if i just put the 16/48 on?
also the exhaust is a standard 200 one, was thinking maybe a straight through aftermarket one sometime, what other mods can you do to the 200? i put racing reeds in, but everything else is standard at the mo |
| Kickstart |
| BenR |
 BenR World Chat Champion
 Posted: 23:49 - 06 Apr 2009 Post subject: |
| Kickstart wrote: | Hi
For a replate try PJ Engineering in Wolverhampton.
Only other place I know of that actually does replating (rather than just sending it out) is Langcourt Engineering down near Bath, but I don't have their details.
Keith |
Stan Stephens also does replating.  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| Kickstart |
The last post was made 17 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
