Unleaded +Octane Booster/ Super Unleaded
Crestfallen
PostPosted: 15:22 - 12 Jul 2002    Post subject: Unleaded +Octane Booster/ Super Unleaded Reply with quote
Hi Peeps.
I have been using unleaded petrol in my bike and i though it was super unleaded but it was only normal unleaded petrol. I have been told that my RS125 needs 95 Octane or above and standard unleaded doesnt meet this octane.
My friend told me that i should drain the tank and put some super unleaded petrol in or add some octane booster to the my tank right away otherwise the engine may run lean. Is this correct?
Regards to all
andrew
Mister Road Rage
PostPosted: 15:37 - 12 Jul 2002    Post subject: Reply with quote
i was always under the impression regular unleaded had an octane rating of 95??
PostPosted: 16:00 - 12 Jul 2002    Post subject: Reply with quote
yea, as was I
Robby
Dirty Old Man
PostPosted: 16:01 - 12 Jul 2002    Post subject: Reply with quote
yeh, regular or "premium" has a 95 rating, super is 97 and lrp is closer to 99, although you kids with modern engines cant use lrp.
use super, you will feel a difference, or alternatively use a booster like silkolene pro boost or a power pill. do not use a power pill in conjunction with pro boost, it doesn't work, possibly becuase after a fair slug of pro boost its already 100 rating.
TiN
Pocket Tin
PostPosted: 16:16 - 12 Jul 2002    Post subject: Reply with quote
...most of the petrol stations should have the "RON" (Research Octane Number Cool ) rating on the pumps...I could swear that the unleaded pumps that I have used had "98 RON" written on them...but then again, I was probably high on the fumes at the time...Confused
Regular (Premium) unleaded should have at least 95 RON, unless you go to really dodgy and cheap merchants...
Tin
PostPosted: 16:51 - 12 Jul 2002    Post subject: Reply with quote
Normal unleaded is 95 RON (Research Octane Number), whereas old 4* and current lrp are 97RON. Super unleaded used to be 98 RON, and still is through most of Europe, but it is only 97 RON in the UK
Aprilia used to specify minimun 98 RON fuel, but they dont anymore. Not sure when they switched.
Using a higher octane fuel that necessary for a particular engine will not gain you any power at all
Ryan
PostPosted: 18:56 - 12 Jul 2002    Post subject: haha Reply with quote
so that bullsh*t u hear from ppl saying 'yeah i really notice the differnce with optimax' is just lies as i thought it was?
Robby
Dirty Old Man
PostPosted: 19:55 - 12 Jul 2002    Post subject: Reply with quote
depends on the engine, i get a definate difference between unleaded, super, and lrp - top end is the same but accel is better and power is better.
Dan
PostPosted: 22:26 - 12 Jul 2002    Post subject: 1 Reply with quote
yeah thats right primuim is 95 octane.
i can tell u from experience super does nothing to my nsr just costs u more. u won't notice n e difference i have swich back to unleaded now. As for a power pill they make loads of difference i like them he he
Doddmaster
PostPosted: 22:28 - 12 Jul 2002    Post subject: Reply with quote
Would I notice a difference if I put octane booster in my cruiser?
Dan
PostPosted: 22:29 - 12 Jul 2002    Post subject: 1 Reply with quote
not sure on octane booster, i guess it would make a difference to the acceleration
Robby
Dirty Old Man
PostPosted: 22:32 - 12 Jul 2002    Post subject: Reply with quote
only if your cruiser had an engine.
PostPosted: 10:22 - 14 Jul 2002    Post subject: Reply with quote
Optimax claims to have a higher energy content. This is not the same as a higher octane rating. Unless your bike has a knock sensor, or is set up for a higher octane fuel there will be no difference to peak power or acceleration by using a higher octane fuel.
For example, my better halfs car has a pair of turbos, and using a knock sensor to figure out the level of ignition advance and turbo boost that it can get away with. It is noticable faster on higher octane fuel. On my old Alfa 33 P4 I have tried supper unleaded (it was only 1p a litre more when I was working in Belgium, so if you pulled up at the wrong pump you didnt tend to bother moving to the correct one) and it make no difference at all. My cheapo lhd 1.3 Alfa 33 was orignally set up to run on 98 octane fuel, and it runs noticeably better on super unleaded or lrp, but not enough to pay the extra on a tank of fuel!
bikerboy1
PostPosted: 10:25 - 14 Jul 2002    Post subject: Reply with quote
i am the same i need min 97ron (super) and i dunno if petrol stations around my area do super so what do i do????????????
PostPosted: 11:04 - 14 Jul 2002    Post subject: Reply with quote
Use lrp as that is 97 RON, and cheaper than super unleaded (dispite the fact that lrp is just super unleaded with an extra additive).
bikerboy1
PostPosted: 11:12 - 14 Jul 2002    Post subject: Reply with quote
what kind of petrol stations will i get that?? e,g total.esso, tesco's ec ect
PostPosted: 19:03 - 14 Jul 2002    Post subject: Reply with quote
HI
Most still stock lrp, which is just 4* lead replacement petrol
The last post was made 23 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 89.71 Kb
