how do you know if an exhaust fits your bike?
clancy
PostPosted: 16:44 - 11 Apr 2009    Post subject: how do you know if an exhaust fits your bike? Reply with quote
i have a Rieju RS2 50. been wanting to change the exaust but i have no idea what fits or is compatible? and help would be appreciated.
KLX 300r
lonner
PostPosted: 17:13 - 11 Apr 2009    Post subject: Re: how do you know if an exhaust fits your bike? Reply with quote
well if you must change the pipe then get one that is made for your bike Rolling Eyes
simple really Thumbs Up
clancy
PostPosted: 17:25 - 11 Apr 2009    Post subject: new exhaust Reply with quote
yeah but unfortunately i cant find any made for my bike online.
well theres a few i can find online, but nothing that really appeals to me.
is there any particular places i should have a look ?
or a way to know if an exhaust would fit ?
any help appreciated.
leigh.
KLX 300r
Blue_SV650S
PostPosted: 18:00 - 11 Apr 2009    Post subject: Reply with quote
One thing you should keep in mind is that a 2-stroke (yours is a 2-stroke right?) is very heavily reliant on the length and shape of the exhaust.
Basically the exhausts are 'matched' to the porting etc of the bike, sling one on from a totally different design bike and realistically at best it'll run rough, at worst it'll run lean and you will blow it up!! Shocked
You'd have to be really lucky to find one from a random donor that just so happens to work properly with your motor (not fit - WORK) and that will actually increase power etc and not reduce it (which I assume you are after?).
In short, you are stuck with buying one for your bike or taking a massive gamble on if it will work. Its not just if it will fit, its if it will match your bikes tuning!
So if you can't get a zorst for your bike, then just knock the baffles out and ride it round until you can get a different/bigger bike!! Wink
clancy
PostPosted: 18:19 - 11 Apr 2009    Post subject: Reply with quote
yeah it is a 2-stroke.
yeah i didnt want to sink £150 odd on a exhaust if it weren't gonna work. but because its some chinese make theres not a lot in the way off "upgrades" so to speak on the internet.
im not to bothered about it bumping up the power or anything. just want it to finish off the look of the bike, because the stock one is rather crappy looking.
but obviously i dont want the power to suffer from buying one that wont work properly.
would it be worth asking in a garage if they could have a look and tell me what exhausts would work etc?
thanks for your help, leigh.
KLX 300r
Blue_SV650S
PostPosted: 18:24 - 11 Apr 2009    Post subject: Reply with quote
I doubt a bike shop will know either!! Wink ... these chinese engines are normally copys of a Jap engine, any idea what it is a copy of?? If so then its probably a reasonable gamble getting a zorst from the 'proper' engine and seeing if that fits?!?
All this aside, the bit that is important on a 2-stroke is the 'expansion chamber' i.e. the big fat bit .. the little silver silencer on the end really is just that and doesn't have such a catastrophic effect on how the bike runs. If you found an end can you liked the look of, then you could happily chop the original end off and get someone to weld on a nice looking one and it shouldn't carry the same risks as a full system swap!! Thumbs Up
That might be an option?
clancy
PostPosted: 18:30 - 11 Apr 2009    Post subject: Reply with quote
im not sure if its chinese or japanese. i know it has the same engine as an aprillia rs50 if thats any help ?
yeah ive found a nice can and im not to fussed about changing the whole system, so yeah that could be an option.
is there a chance it might fuck the can up though, i dont want to mess up a £150 can :S
leigh.
KLX 300r
Blue_SV650S
PostPosted: 18:36 - 11 Apr 2009    Post subject: Reply with quote
leigh.
If its an RS50 engine, then a RS50 'zorst should be ok engine wise, its just down to physically if it will fit your chassis ...
Do you know someone who has a MIG welder? If you only know someone with an ARC welder (or have one yourself) then there is a good chance its gonna either look sh1te or fall off again ... so get a quote from a local engineering place before spending out on donor zorst.
At the end of the day its just metal that is used to getting hot, so it won't harm the exhausts, its just trying to get the job done 'properly' that is your greatest consideration ...
clancy
PostPosted: 18:39 - 11 Apr 2009    Post subject: Reply with quote
ok, so if i look for rs50 exhausts i should have more luck ?
and if i play it on the safe side and took it to a garage, surely theyd weld it properly yeah?
leigh.
KLX 300r
Blue_SV650S
PostPosted: 18:51 - 11 Apr 2009    Post subject: Reply with quote
leigh.
If its an RS50 engine, then the RS50 exhaust should run absolutely fine (might be checking the specs of the main jets) its more if it will physically fit the fairing/frame/mount.
Get a quote for the welding before you buy anything, but you will want it welded 'properly' if you go that route. Thumbs Up
Also I don't know how monkey metal the Chinese expansion chamber is ... again your local welder should tell you if its feasible when you get the quote ...
Blue_SV650S
PostPosted: 18:53 - 11 Apr 2009    Post subject: Reply with quote
Just looked up what one looks like (in a big pic)
I think they look well cool for a 50 ... also I actually quite like the stock end silencer thingy!! Laughing ... it is a bit 'droopy' mind ... perhaps just get them to weld it at a different angle?
https://www.bikez.com/pictures/rieju/2006/23184_0_1_2_rs2%20pro%20matrix_Image%20credits%20-%20Rieju.jpg
clancy
okeydoke.
thanks for the help mate. much appreciated
KLX 300r
clancy
PostPosted: 18:57 - 11 Apr 2009    Post subject: Reply with quote
yeah they are pretty sweet, yeah thats the 08 or 09 one though, i have a second hand 05 one and the exhaust needs a bit of
TLC. but i cant get a nice finish on it like that. i recon a beowulf chrome exhaust would look sweet if it would work. would finish of the look of the bike dont you recon?
KLX 300r
tutton
PostPosted: 22:49 - 11 Apr 2009    Post subject: Reply with quote
Peugeot XR6 Exhaust (Very similar to your bike if i remember right your bike is a copy of the pug Laughing)
Peugot XPS exhaust (Uses rs50 engine i used to have one Smile)
Motorhispania furia exhaust (Same as the xps different make model)
Have a squint at some of them.
clancy
PostPosted: 07:35 - 12 Apr 2009    Post subject: Reply with quote
yeah ill have a look, cheers Thumbs Up
KLX 300r
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 89.62 Kb
