Things to look out for on a VFR400?
Bike_craze1
PostPosted: 23:11 - 12 Apr 2009    Post subject: Things to look out for on a VFR400? Reply with quote
Thinkin of gettin a VFR400 as I won't be allowed anythin more at the moment cous of my parents.
But I really like this bike so, what should I look out for when buying one? and how much could I get a decent one for?
Yamaha R125 - Cagiva Mito 125 - Honda CBR 600
CBT passed: 22/07/08 Bike Theory passed: 28/03/09
Bike Test passed: 15/04/09
PostPosted: 23:18 - 12 Apr 2009    Post subject: Reply with quote
First and foremost make 100% sure that the exhaust is free from holes. Then check the wheels are round and not buckled. Check the brakes work and it doesn't have cheap alloy fittings on the braided hoses. Stainless or titanium are OK.
Check the head bearings
Check the forks for leaks
There is actually so much you have to check its really hard to get it into a post...
MaybeGuy
PostPosted: 23:44 - 12 Apr 2009    Post subject: Reply with quote
i think he means more model specific things...
ie: head gaskets on ZXR400s and CCTs on CBRs.
i guess with gear driven cams theres not much to look for in terms of wrongness, unless its running unevenly, which could mean damage to front cylinders (from oil starvation/wheelies). or could just be unbalanced carbs.
also listen for backlash in the cam gears. blip the throttle widely and listen for knocks at the points where the revs begin to rise and fall.
instigator
PostPosted: 08:27 - 13 Apr 2009    Post subject: Reply with quote
How much can you afford?
I generally see good condition VFR's go for £1400-1600 depending on age and what comes with...
PostPosted: 08:32 - 13 Apr 2009    Post subject: Reply with quote
Specifically on the VFR check that it is charging the battery. Regulator / rectifier units are reknowned for having a short life.
Check if anyone has done the valves as they are not easy to get at to do.
Check for accident damage. Most are bought as first big bikes and so regularly lobbed at the scenery.
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 45.4 Kb
