| JonnyFoxtrot |
 JonnyFoxtrot Trackday Trickster
| simk2 |
 simk2 Renault 5 Driver
| Kickstart |
 Kickstart The Oracle
 Posted: 22:23 - 12 Apr 2009 Post subject: |
It is easy enough to flood a 2 stroke. Take the plug out and give it a good clean (blow torch). Also check that the carb is not overflowing (ie, worn needle valve, think the PHBH carb in the NS has a viton rubber tip which might have been damaged).
While there are numerous things that could stop it running (eg, sheared woodruff key allowing the ignition timing to slip, worn / non sealing reed valves, etc) I would be tempted to try bump starting it, or better get a couple of willing volunteers to push you on it to try and start it.
| JonnyFoxtrot |
| JonnyFoxtrot |
| JonnyFoxtrot |
| G |
 G The Voice of Reason
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 14:06 - 13 Apr 2009 Post subject: |
hi,
this is kick start only, right?
i'd agree with the above keep trying!
but i'd remove the spark plug again.
& if the bike is kept indoors, i'd leave the spark plug out overnight, with a teaspoon of 2t down there.
then following day, give it a few kicks before puting a new spark plug in.
this always worked for me on my ns125r( tc01)
make sure the battery is fully charged.
check the floats are working ok, while your there might as well give the carb a clean & blow through with air-line.
test for a spark.
put it all back together,& open the drain screw at the bottom of the carb.
when petrol starts pissing out, close it.
the carbs full of petrol, so if you've got compression & a spark so it should start.
leave the air filter off for the time being.
then give it a few kicks,with choke on & throttle closed.
it WILL start, lol
cheers,
GAZ |
| c-m |
 c-m World Chat Champion
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
