| Davie_G71 |
 Davie_G71 World Chat Champion
| Davie_G71 |
| Ichy |
 Ichy World Chat Champion
| Davie_G71 |
| Davie_G71 |
 Posted: 11:28 - 14 Apr 2009 Post subject: |
If the main seal is worn then it might give a soft lever, but I would expect it to just give no pressure. The seal in the master cylinder is shaped like a parachute, and under pressure will push out hard onto the walls of the cylinder.
One thing that is well worth trying is to pull the brakes hard, wrap a cloth around the top banjo bolt and crack it off a touch then retighten it. Air can get stuck in the top banjo and this can get rid of it (the cloth is there to catch any fluid sprayed out).
| Davie_G71 |
 Posted: 11:34 - 14 Apr 2009 Post subject: |
Thanks Keith, but again we've done the top banjo bolt as well.
I do get pressure, it's just very soft.
What i did notice is that i can pump it a few times and get good pressure, but if i leave the bike standing for say 3-5mins then i would have to pump it a few times to get the same pressure. It's very annoying.
I'm about to buy that re-build kit posted on ebay, but it just sayd for GSXR, GSX models etc, i can see a rebuild kit on wemoto that looks identical to the ebay one but will definately fit my bike, but is more expensive. I just want to exhaust all avenues before i buy something i may not need.
All the best,
David. ____________________ Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003. |
| Ichy |
 Posted: 11:35 - 14 Apr 2009 Post subject: |
In theory if the main seal is torn or just not sealing well it can provide some pressure, just not enough.
For bleeding I use a vacuum pump, never let me down and the only way I know of reliably getting fluid through new or empty pipes.
In line with what Keith mentioned about the banjo bolt on the MC, if you have a splitter its worth just doing the same with the bolts on there.
I've never tested a master cylinder before so can only suggest either changing it for a working one or maybe replacing the banjo with a normal bolt and seeing if it hold the pressure when you pull the lever? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Davie_G71 |
 Posted: 11:42 - 14 Apr 2009 Post subject: |
I had a similar problem with the ZZR600. In the end after new caliper seals and pistons I landed up rebuilding the master cylinder and replacing the lines, and spending hours bleeding the brakes and still had a lever that was pretty soggy but which would build up pressure if pumped (but lose it after 5 seconds or so). I landed up getting replacement calipers.
| Davie_G71 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 17:25 - 14 Apr 2009 Post subject: |
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=140313854580
they were working when i was using them, but they'll need cleaning out because they warped my disks.
near new pads on them too. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Noxious89123 |
| MaybeGuy |
 Posted: 18:47 - 14 Apr 2009 Post subject: |
split them, pop the pistons out, clean the pistons. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Davie_G71 |
| Noxious89123 |
 Posted: 21:06 - 14 Apr 2009 Post subject: |
+1
Logically thinking, what could physically be wrong with them to cause a problem??
My brakes tend to be a little soft, but i attributed that to old rubber hoses. But if i pump the lever, they do gain pressure a bit of presure temporarily.
/confused/ ____________________
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Ichy |
| Noxious89123 |
| Ichy |
| Davie_G71 |
The last post was made 16 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
