Chain Snapped, Do I need new sprockets?
John
PostPosted: 22:49 - 24 May 2004    Post subject: Chain Snapped, Do I need new sprockets? Reply with quote
As the title.
Chain snapped. Luckily the bike and I seem to be fine. The chain/sprockets had only done about 1000 miles, maybe a little more or maybe a little less.
Can I stick with my sprockets with no bad effects or should I buy some more?
Ta.
TT600 neeeeeeeeeeeeeeeeeeowwww!
McJamweasel
BCF Junkie
PostPosted: 22:50 - 24 May 2004    Post subject: Reply with quote
Have a look at them. If they're in good nick then keep them - if they're worn buy new. Oh - and chain lube helps. Wink
craigT19
Jolly Green Giant
PostPosted: 22:52 - 24 May 2004    Post subject: Reply with quote
i snapped one on my nsr and didn't need a new sprocket...altho the chain did take a sizable chunk of metal out of my engine casing Laughing
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Phoenix
Twisted Firestarter
PostPosted: 16:25 - 25 May 2004    Post subject: Reply with quote
Replace the sprockets, replacing just the chain is daft, they cost about £20 for new Renthals.
True Blue
PostPosted: 19:50 - 26 May 2004    Post subject: Reply with quote
Do you know what caused it to snap? Confused
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Frost
PostPosted: 20:20 - 26 May 2004    Post subject: Reply with quote
it depends on what cause the chain to snap.
if the sprockets are the problem or were damaged as a result of the chain snapping, then you definitely need to replace them.
Have a look at the sprockets, if they look fine put a new chain on, lube it up and give it a good check over.
check the chain for any loose or tight spots. i once had a bike which ate chains due to a a mysterious tight spot Confused
The last post was made 21 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 48.23 Kb
