More help needed Honda NS 125 F rebuild
Dilusi
PostPosted: 12:04 - 15 Apr 2009    Post subject: More help needed Honda NS 125 F rebuild Reply with quote
Ok I've just ran into another slight problem with the rebuild. One of the rubber bushes on the rear suspension linkages is knackered and needs replacing. I've been to a couple of local places but none seem able to get hold of this part. Anyone know were I might be able to get one?
PostPosted: 12:29 - 15 Apr 2009    Post subject: Reply with quote
Which bush? Any chance of a piccy?
Loads of NS bits are no longer available from Honda. However it should be possible to get a bush from one of the pattern suppliers, or even to get someone to knock one up on a lathe.
Dilusi
PostPosted: 13:20 - 15 Apr 2009    Post subject: Reply with quote
I'll try to put a picture up later when I get home.
Basically its the triangular shaped linkage which connects the shock, frame and swing arm together. There are three bushes in total, two of them are just metal bushes and seem fine the third is a rubber bush with a metal sleeve inside and the rubber has perished. I also have the part no. and description from the Honda micro fiche at home.
PostPosted: 15:29 - 15 Apr 2009    Post subject: Reply with quote
The part is "52451-GE2-000" which is "Bush, Damper Lower".
CMSNL list it for about £6 (they price in Euro):-
Clicky
Dilusi
PostPosted: 16:24 - 15 Apr 2009    Post subject: Reply with quote
Cheers Keith!
Thats the same part number and description the guy at RH Motorcycles gave me.
https://img3014.photobox.co.uk/99337507e7ba86e91ecca1b123ab182f0291da6dc1f1328d7d11d724c1384f0d7373f9e4.jpg
https://img3014.photobox.co.uk/75834782be23f8818889e78b133004b1181da1a9997aec5c1db48317bae731cf3b7a8cd5.jpg
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 45.16 Kb
