AR80 revs high on cold starting
AR80 kawa
PostPosted: 15:25 - 14 Apr 2009    Post subject: AR80 revs high on cold starting Reply with quote
Hi all,
Hope you can help with this
My AR80 revs upto 7000 rpm (sometimes more) when I start it from cold
The revs drop down gradually over a minute or so and then it ticks over very well. If left ticking over for a while say 5 mins or so it does eventually stop, but starts ok and ticksover again.
It runs well and does around 60ish mph
I have tried the following to cure this fault
New crank seals and bearings - they were worn
New big bore 93cc kit - original bore was worn
New CDi
different air filter
New seal between carb and inlet manifold
Carb has standard 80 jets
DTI set the timing - the original was slightly out but made no difference
The exhaust is a Ginelli system and has been on the bike since i bought it so i don't know if it is that as i don't have another to try
any ideas please
cheers
finpos
PostPosted: 19:10 - 14 Apr 2009    Post subject: Reply with quote
Sounds more or less as expected to me, it's not got an automatic choke, has it?
f.
AR80 kawa
PostPosted: 16:29 - 15 Apr 2009    Post subject: Reply with quote
it is a manual choke
I have had many 2 strokes and have never had one that revs this high when cold
finpos
PostPosted: 17:25 - 15 Apr 2009    Post subject: Reply with quote
Assuming then it's doing this with the choke off, have you tried running it on premix with the oil feed (presuming it has one...) blocked off?
f.
AR80 kawa
PostPosted: 15:49 - 16 Apr 2009    Post subject: Reply with quote
no i haven't tried that but I will now you have suggested it
thanks
The last post was made 16 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 15 - Page Size: 41.5 Kb
