Fixing on L Plates
Mattastic
PostPosted: 12:38 - 25 May 2004    Post subject: Fixing on L Plates Reply with quote
Not sure if this belongs in here but I', sure it'll be moved by the powers that be if it isn't. My rear L Plate keeps coming off and it is doing my head in. Somehow my front one seems ok, despite it being a little torn, but the rear one keeps tearing off. I've been attaching them to the bottom of the number plate by screwing the bottom number plate screws through it but again this morning, when i got to work I had two little pieces of white plastoc where my L plate once, proudly, stood!
Anyone know of a better way to attach the bleeding thing as the last thing I want is Plod giving my 3 points and a fine.
Too skint to buy a bike Sad
McJamweasel
BCF Junkie
PostPosted: 12:44 - 25 May 2004    Post subject: Reply with quote
Are you using the flexible ones? If you are then thats why. The rigid ones should last much longer.
carvell
Scuttler
PostPosted: 12:52 - 25 May 2004    Post subject: Reply with quote
I glued mine to a bit of wood and attached the wood to the bottom of the numberplate.
Yamaha TDM 850
priller
PostPosted: 13:15 - 25 May 2004    Post subject: Reply with quote
I had two little pieces of white plastic
Sounds like your using the hard ones then, are you drilling the holes too close to the top of the plate.
daz|n00by
The Internet
PostPosted: 14:34 - 25 May 2004    Post subject: Reply with quote
why not use a bit of clear perspex and stick your L plate on it then attach it to your number plate if u get some nice thin perspex it is flexable enough not to snap but strong enough to bend
hope thta gives u some ideas
Mattastic
PostPosted: 14:36 - 25 May 2004    Post subject: Reply with quote
I'm going to attach my new plates to something more sturdy then attach this to the number plate!
Thanks for the advice, I'm so impractical it's unbelievable!
The last post was made 21 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 47.47 Kb
