| Pickledswede |
 Pickledswede Traffic Copper
 Posted: 14:37 - 16 Apr 2009 Post subject: What tools do I need for general maintenance? |
Basically when my dad moved out he took all the useful tools for bikes, and we're left with a load of crap bits and bobs...
So really I want to try and consolidate existing tools, and see what I need.
What I want to be able to is fix problems with/service my CB500, as I'm planning to get a good mechanical knowledge from this bike so I know what I'm doing!
So what tools are essential for this? Or what would be useful but not essential (e.g. I tried to check the spark gap the other day and didn't have a wire guage or something?)
Cheers  |
| gmanxiii |
 gmanxiii World Chat Champion
| gmanxiii |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 15:57 - 16 Apr 2009 Post subject: |
Don't forget a bonking stick.  |
| Kal |
 Kal World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
| Kal |
| Pickledswede |
 Posted: 17:29 - 16 Apr 2009 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 17:33 - 16 Apr 2009 Post subject: |
Decent screwdrivers - Phillips No's 1,2 and 3 and equivalent sized flat blades. Forget the interchangable-bit screwdrivers you'll kick yourself when you have to strip the bike (or even worse, the engine) to fish out a lost end and most are crap quality anyway.
Long screwdriver - at least 300mm blade. One flat and one No2 Phillips (not pozi-drive). Keep these safe for undoing hard-to-reach jubilees.
A good set of allen keys. I have a set of ball-end 'Lazer' allen keys that are bloody good for the cost of less than a tenner. For your bikes toolkit I'd buy the fold-away set you get in the bicycle section at Halfords.
A medium ball-pein hammer, centre-punch, and pin punches.
Large standard pliers, long-nosed pliers and side cutters.
Tidy set of combination spanners. Go by the finish, if the chrome is smooth and the edges are crisp then it's probably worth having. Cheap is usually, but not always crap. Believe it or not I got a cracking set my wife bought new from a boot fair tool-stall for £8. I use them more than my better set simply because they are not in a case, just loose in a drawer.
3/8" drive metric sockets, and allen-sockets. There's a lot of rubbish out there, if you bought a set from Halfords you won't go far wrong.
A 6mm and a 7mm nut-runner. These are to stop you wrecking tight jubilee clips. They look like a screwdriver with an end like a socket. Probably one of the handiest tools you'll have in th elong run.
A rubber mallet - £2 from Wickes. For whacking stuff like wheel spindles in.
Stanley knife.
Cheap test meter.
Cheap battery drill - one of my favourite tools. Put a 1/4 drive extension in the chuck and an 8mm socket and whizz those clutch-cover bolts off.
Oil catch can & 5-gallon drum - for oil changes.
A nice 3-drawer top-box to put it all in. Cantilever toolboxes are okay but they fall apart quick when overloaded and get full of spare parts, oil & crap.
If you shop-around you should be able to get fair quality stuff and spend about £100 at a guess. Don't bother with the '180 tool-piece set for £30' deals they are mostly very poor quality.Avoid stuff that has lots of un-necessary-sized tools (like 5.5mm allen key - has anyone ever actually used on of them?). ____________________ a.k.a 'Geri'
| Pickledswede |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 19:52 - 16 Apr 2009 Post subject: |
hi,
favourite screwdrivers - draper screwdriver set.
belonged to my late father, so must be al least 25 years old .
comes in a blue plastic wallet, handle is that yellow see through plastic.(i have accumulated a spare handle, thou that one has "felo" stamped on it?)
& the "blades" come out, comes with about 7 or 8 different types, incl. the one that gets master cylinder screws off without rounding them! (& some dangerous pointy things!)
has out lasted every other screwdriver.
got a load of draper expert stuff, cant fault them, though the impact sockets i got with my cheap lidl windy gun are surprisingly good quality.
i never use hex keys now, i bought a decent set of hex bits a couple of years ago, came in a nice red tin & they have been invaluable, i just shove them on the 1/2 inch ratchet or breaker bar.
if theres no room to get them in, i just use the bits that go in the 1/4 inch socket/bit set.
cheers,
GAZ |
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
