GS 450
RXLer
PostPosted: 16:00 - 13 Apr 2007    Post subject: GS 450 Reply with quote
Hey Guys. Im new here and I come from Croatia. I own a Kawasaki GPZ1000RX. But I need something else. Does anyone can help me and give me a link or can send me a service manuel for an Suzuki GS450 E? I have an service manual for an GS 500 but thats just not it. I cant bring it to work how it should. There for would I be very thankfull if you could help me. The Suzy my brothers bike. Smile
And sorry for the mistakes that i made writing...
UUUps.... just saw I opened a new topic. Neutral
Greets,
Marko
I dont drive too fast, i just fly to low Wink
sagiliam
PostPosted: 17:32 - 13 Apr 2007    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=63414&highlight=gs+450
hmmmnz
PostPosted: 17:34 - 13 Apr 2007    Post subject: Reply with quote
there is an owners manual on https://www.repairmanualclub.com/
you might be better with a old gsx manual they had similar engines
the humans are dead
I kick arse for the lord
There is a gap of 2 years, 4 days between these two posts...
zero_signal13
PostPosted: 21:07 - 16 Apr 2009    Post subject: Reply with quote
hey just a quick question, i'm having a problem with my 1980 gs450L it seems to be a common problem but i'm only getting a spark on one coil. i've replaced the ignitor unit and signal generator plate but am still getting the same problem, it only seems to be firing on the side fed by the black/yellow wire
zero_signal13
PostPosted: 21:10 - 16 Apr 2009    Post subject: Reply with quote
just a quick update, have tested for live out of the ignitor unit and the black/yellow feed pulses whereas the white feed just cuts out and loses its live bit of advice would be much appreciated as it's driving me nuts
hmmmnz
PostPosted: 01:25 - 17 Apr 2009    Post subject: Reply with quote
bugger, looks like you have a dry joint in the cdi,
depending on the cdi, you may be able to seperate the inner from the case, be careful, check all the solder connections, and re melt them all with a soldiering iron
its a common problem with all old eletronics,
the humans are dead
Odie
PostPosted: 07:04 - 17 Apr 2009    Post subject: Reply with quote
It might be a dry joint but normally its a resister inside the casing thats been compressed and broke due to stress, right where the multiplug goes in, common fault.
(mate used to repair C.D.I's)
odie
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 52.96 Kb
