| Notj7 |
 Notj7 Brolly Dolly
 Posted: 18:09 - 17 Apr 2009 Post subject: My CBR 125 Chain's Broken !? |
Hi guys,
Been riding only for around 6 months now on my CBR 125, loving every minute of it. Last night I was about to set off from Town on my bike when I heard this loud click and then my bike rev'd really high but wouldn't move. I got off and realised, my chain had broken! :O I had to push it (and it was hard to push I might add because the chain was caught somewhere) for 2 and a half hours to get it home.
I brought it brand new from Honda 6 months ago, it's done around 2700 miles and I lube my chain every 2 weeks or so, so I don't know why it broke!? Here are some pics, hopefully someone might be able to shed some light? Is it my fault, I tried to look after is, or is 6 months just daft and I need to get onto Honda?
(Can get more pics if needed - Images large so you can see enough)
https://img17.imageshack.us/img17/4082/img0154r.jpg
https://img91.imageshack.us/img91/4124/img0155o.jpg
https://img17.imageshack.us/img17/1986/img0156l.jpg |
| gavcarter |
 gavcarter Could Be A Chat Bot
| Notj7 |
 Notj7 Brolly Dolly
 Posted: 18:22 - 17 Apr 2009 Post subject: |
Thanks for the reply Gav,
Yeah first bike, and I was really trying to look after it, lubing it often, washing it every week etc. My pride and joy .
I haven't moved the wheel back or anything. Only things I have done on the rear part of the bike is adjust the chain so that it has about an inch of play. |
| gavcarter |
 Posted: 18:38 - 17 Apr 2009 Post subject: |
Maybe you've twisted the wheel then, if you've only adjusted one side and thats why its snapped (just a possibility).
When you adjust the chain tension you need loosen the back wheel fully so it slides back and forth freely, and adjust both tensioners equally! They have little lines and arrows on, visible through cut-outs in the side of the swingarm, make sure they are both in the same postion before re-tightening the rear wheel. (maybe buy a torque wrench for this as you dont want to crush the wheel bearings by standing on a spanner - or have the back wheel come loose).
Your does look a little rusty in places, which means you probably go through them quicker. I think theres a good guide to keeping your chain nice and fresh in the handy links section of the workshop...
DONT BUY A GENUINE HONDA CHAIN (unless you really really want to)
They cost at least double a "pattern" chain and dont last a whole lot longer.
You can get a new chain here
https://shop.wemoto.com/index.dyn?oid=5835573
Or from a local garage.
Or if your in my area I think I have an old one going spare it should have a couple of hundred miles left in it. |
| Notj7 |
 Notj7 Brolly Dolly
| gavcarter |
| Ste |
 Ste Not Work Safe
| Eddie Hitler |
 Eddie Hitler World Chat Champion
| Faraz |
 Faraz Nearly there...
| Eddie Hitler |
| Faraz |
| truslack |
 truslack World Chat Champion
| Faraz |
| The Artist |
 The Artist Super Spammer
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 01:49 - 18 Apr 2009 Post subject: |
The only chains I've seen with that much rust usually had an anchor on the end ... Have you been parking the bike in the harbour?  |
| Vincent |
 Vincent Banned
| neil. |
 neil. World Chat Champion
 Posted: 21:47 - 18 Apr 2009 Post subject: |
The chain on my YBR now has over 13'000 miles behind it so I'm surprised to see this as I'd imagine we have similar chains. Admittedly I'm now on the penultimate notch for the back wheel adjusters, so next service it will be treated to a new chain and sprockets.
Every time you ride in the rain you should clean/lube your chain. Every time you wash your bike you should do this too. Clean it before you lube it or the grit that sticks to the lube makes a nice grinding paste. I'll tell you what I do:
Get a nice brush and some paraffin in one of those spray bottles and give the chain a good spraying/scrubbing then spray over it again with the paraffin to rinse off the loosened/remaining crud. Dry it THOROUGHLY, then lube it up. Spray the INSIDE of the chain whilst rotating the back wheel. I tend to aim towards the engine to avoid any lube getting on the back tyre. Let it soak in for a few minutes and then gently wipe off any excess. Some people like to ride for 10-15 minutes to warm the chain up before lubing but I never have and it's lasted this long...
For correct tension, you want about 1 inch of movement up/down on a tight part of the chain where the it runs beside the tyre.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Robby |
 Robby Dirty Old Man
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 00:05 - 19 Apr 2009 Post subject: |
Apart from the fact it's broken, that chain looks well fucked
I don't get why so many people have longed assed complex ways of lubing their chains like removing them etc.
Can of SDoc100 chain cleaner. Bike on centre stand. Spray the entire chain. Leave for 15 minutes, then spray off with a hose. (I usually do it just before i clean the entire bike). Recoat with lube. The spray on sticky lubes are crap, all they do is attrach loads of dirt. I just cover the chain with some ScottOil and then let the scottoiler take care of it for a fortnight, then repeat the process. The scottoiler helps the chain stay cleaner and better lubed for longer, but it still needs cleaning every so often, especially if ridden in the wet.
Without a scottoiler or similar, I'd be cleaning and relubing the chain atleast once a week, and after everytime you've been out in the rain. Also relube during the week if it's looking a bit dry. It's a total PITA which is why i put a centre stand and scottoiler on my bike shortly after i got it. Also had a new C&S as the old ones were shagged. Done about 5k on these C&S now, and not had to adjust it once, and it still looks like new. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| ram_doom |
 ram_doom World Chat Champion
| stirlinggaz |
 stirlinggaz World Chat Champion
| Notj7 |
 Notj7 Brolly Dolly
| Notj7 |
 Notj7 Brolly Dolly
 Posted: 21:43 - 22 Apr 2009 Post subject: |
| Noxious89123 |
 Posted: 22:50 - 22 Apr 2009 Post subject: |
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 23:28 - 22 Apr 2009 Post subject: |
The last post was made 17 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
