NSR Restriction
UKRedwing
PostPosted: 19:38 - 18 Apr 2009    Post subject: NSR Restriction Reply with quote
So I've established theres no intake restriction tract plate and the exhaust looks like its allready been tampered with but I'm not sure, I don't even know what the exhaust restriction is on the NSR 2003 reg.
Pushing just over 80 mph max..
0-60 is pretty fast, I mean it's not 11 seconds like peopel say the restricted nsr is.
Anythign else that could be slowing my bike, its a UK spec so i doubt it has any CDI restricors etc..
BenR
PostPosted: 19:49 - 18 Apr 2009    Post subject: Reply with quote
https://www.125ccsportsbikes.com/forums/index.php?showtopic=17347
UKRedwing
PostPosted: 20:51 - 18 Apr 2009    Post subject: Reply with quote
Already have the document downloaded, no help with regards to the original exhaust
buddy
PostPosted: 09:25 - 19 Apr 2009    Post subject: Reply with quote
does it have restricted electronics?
check for the tv-78 cdi and ci626 powervalve controller unit thingy
sounds like your powervalve isnt opening fully
whats the frame number, ya can find it in the right side of the headstock
When this baby hits 88 miles per hour... you're gonna see some serious shit.
UKRedwing
PostPosted: 14:54 - 19 Apr 2009    Post subject: Reply with quote
ZDCJC22C01....... Uk spec according to wikipedia.
UKRedwing
PostPosted: 15:06 - 19 Apr 2009    Post subject: Reply with quote
Heres a pic of the exhaust
It would be immensly helpful if someone with knowledge about it could direct me as to where in the exhaust the restriction is,
Then I can easily do it at home with all my proper monkey wrench etc tools.
https://i39.tinypic.com/vq47c0.jpg
Paint edit skills anyone?
UKRedwing
PostPosted: 18:23 - 19 Apr 2009    Post subject: Reply with quote
Bump.
So no-body knows where the restriction is O_o.. ?
PostPosted: 18:30 - 19 Apr 2009    Post subject: Reply with quote
Chill.
This should have what you need:
https://www.nsr125.com/derestrict.htm
It's at the manifold end, where the exhaust meets the engine.
buddy
PostPosted: 18:31 - 19 Apr 2009    Post subject: Reply with quote
the restriction is right near the exhaust port, the only proper way to check is to take the exhaust right off and have a look inside
actually, here is a website that will help ya https://www.nsr125.com/derestrict.htm
also have ya upjetted it yet? ya will need a 42 idle, 65 power and a 138 or a 140 main
140 is probably better performance wise
UKRedwing
PostPosted: 18:46 - 19 Apr 2009    Post subject: Reply with quote
I r blind.
PostPosted: 18:47 - 19 Apr 2009    Post subject: Reply with quote
Mr.Ormes
PostPosted: 19:07 - 19 Apr 2009    Post subject: Reply with quote
the restriction should be right at the end of the expansion chamber/manifold, where the exhaust meets the barrel, there should be a copper washer or cone, or something which restricts gas flow there, simply drill/cut/grind/dremmel it out and you are de restricted!!!
DT 125 1995
Thumpstar 120
Suzuki ZR 50
UKRedwing
PostPosted: 19:54 - 19 Apr 2009    Post subject: Reply with quote
Gonna sort it tomorrow then.
Anyone know how much a compression check test should cost? Gonne see if its above 130 pounds per square inch
UKRedwing
PostPosted: 18:31 - 20 Apr 2009    Post subject: Reply with quote
Took exhaust off today, no restriction atall. Im stumped now theres no other restrictions on the uk 03 spec which my bike is.. so I don't get why it only reaches 80 mph flat out
PostPosted: 19:41 - 20 Apr 2009    Post subject: Reply with quote
First off, can you confirm that you are red-lining it in each gear, throttle held wide-open when accelerating?
Next, I'd be tempted to whip the head off and see how the piston/cylinder looks. They can start to lose a bit of go as it gets near rebuild time.
UKRedwing
PostPosted: 19:57 - 20 Apr 2009    Post subject: Reply with quote
Yes mate, raches redline in every gear effortlessly except for 5th, if you try to take it into 6th it will just slow down.
I'm not mechanically competent atall so I have no idea what I should be looking at engine wise for wear, but the bikes done 13,200 miles so its nowhere near rebuild time, might need some piston rings though, have put 2k miles on it since I bought it.
Hopefully I can get compression checked in the engine and the tires, and grease the tire bearing see that they spins freely, plus a new chain and maybe a different sprocket set up. Don't know when gear box oil was last changed either so will check that.
Does anyone know where the CDI "box" thing is? I don't actually know what this is but I heard it might be the restricted version.
Cheers.
salty21
PostPosted: 19:02 - 21 Apr 2009    Post subject: Reply with quote
did you not like the look of this suggestion? it's most probably the right one aswell
UKRedwing
PostPosted: 19:40 - 21 Apr 2009    Post subject: Reply with quote
Oh yeah Im trying it, not sure if the jets are allready at that though as the bikes fully derestricted prior to me owning it. The jets are on there way, they wont make that much difference tho right? between 80 mph flat out and 110 mph O_o
checked CDI its the fully derestricted one =/
should i cut a hole in my airbox and coved that hole in mesh for better airflow? would I need to upjet AGAIn ?
PostPosted: 19:55 - 21 Apr 2009    Post subject: Reply with quote
Sorry, yes piston rings I was including in 'rebuild'. A compression check will give you an idea if it needs these - I'm not that great inside engines myself, but sure there's guides showing you what it looks like (with the head off) too, when they're starting to blow a bit.
UKRedwing
PostPosted: 21:42 - 21 Apr 2009    Post subject: Reply with quote
Okie doke, well its pay day soon so Im going to get a mechanic to fit these jets when they arive, use a paddock stand or something (i dont have one) so cant really check whether wheels are spinning freely, new chain n sprockets, new piston rings. Might sort things out.
stirlinggaz
PostPosted: 22:02 - 21 Apr 2009    Post subject: Reply with quote
hi,
changing the jets takes 10 minutes.
(takes longer to get at the carb), can sometimes get away with not even removing the carb, just loosen off the 2 hose clamps & turn the carb upside down.
though probably better taking it off & giving it a clean while your there.
theres a very good guide to carbs from our resident 2t guru, Kickstart, on this very forum.
buy yourself a compression tester, should cost £18 for the basic one up to £40 for a kit with a few adaptors.
then you can test the compression yourself.
then if you need to do anything, there a good guideto doing top end re-builds, floating around, i'll post a link if you need it.
why pay someone to do something you could probably do yourself?
cheers,
GAZ
UKRedwing
PostPosted: 15:44 - 22 Apr 2009    Post subject: Reply with quote
Cheers, yeah i could probably so it myself but my airbos is sucha fcuker to get back on poperly over the carb i'de rather them take 5 mins to do it. Cash is a little hosrt atm so i can't afford to go out and start buying PSI equipments and stuff.
Whenever im not revving or idling and the bike is slowing down, I don't know if its cus im paranoid or i have started paying attention to my bike but is a has a sort of throuty "gurgle" as it slows down, not sure if this is normal, airbox and everything is on properly.
Any ideas?
buddy
PostPosted: 17:35 - 22 Apr 2009    Post subject: Reply with quote
hey mate
i had a similar problem to you, upjetting made abit of a difference and so did an irridium plug
before both of these my top speed was 85 and is now about 95
also be aware, i will take a very very long time to actually get to 95mph(well its prob not that long but it seems ages)
and ya have to get right down on the tank
my bike has done 24,000 miles aswell
Dilusi
PostPosted: 18:26 - 22 Apr 2009    Post subject: Reply with quote
What sprockets are you running? I had a simular issue with my old MTX125, could hardly use 6th as it was geared too high. I replaced the chain and sprockets with standard items and it flew through the gears and would top out (eventually) in 6th. Used to see 90-95 on the clock which I thought was pretty good for a trails bike.
The last post was made 16 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 123.46 Kb
