one cylinder "drops"
Dr. DaveJPS
PostPosted: 16:02 - 19 Apr 2009    Post subject: one cylinder "drops" Reply with quote
right i have a classic bike, and the right hand cylinder won't run without choke on, now i don't think it's the carb as is single carb and the left hand doesn't do this. also at high throttle the choke acts as a speed limiter (as in more choke faster top speed)
any suggestions as to the cause?
www.davejps.com
Billing
PostPosted: 16:05 - 19 Apr 2009    Post subject: Reply with quote
could there be an air leak on that cylinder? it could be running lean as its getting too much air and the choke brings it back to the right A/FR range
Dr. DaveJPS
PostPosted: 16:12 - 19 Apr 2009    Post subject: Reply with quote
it could be, how would i test this...?
www.davejps.com
Coxyzxr
PostPosted: 16:41 - 19 Apr 2009    Post subject: Reply with quote
Quick test would be spraying WD40 around areas/connections/boots/seals where the induction runner is.
Revs/idle etc should increase momentarily whilst the WD tempoarily seals it.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Billing
firstly check for splits and cracks in the inlet, when the bike is running listen for any hissing, maybe put a little bit of washing up liquid around the inlet and watch for bubbles.
Finglonga
PostPosted: 17:16 - 19 Apr 2009    Post subject: Reply with quote
Take it you have checked the plug is ok?
Andy Sez....
F.Y.Y.F.F.
Dr. DaveJPS
PostPosted: 17:26 - 19 Apr 2009    Post subject: Reply with quote
i don't think it is the plug as put a new pair in this morning, might be the HT lead though, but i'll do the air leak test on tues and report back
www.davejps.com
Dr. DaveJPS
PostPosted: 20:55 - 21 Apr 2009    Post subject: Reply with quote
well sprayed WD40 in and it didn't seem to increase the revs on that cyclinder, (scientifically tested by putting my hand over the exhaust). am gonna test if it is HT lead/ingnition based tommorrow. unless anyone has more suggestions?
EDIT: also i have a some sludge at the bottom of the oil tank, is there any way to remove this without unbolting it and flushing it with petrol?
www.davejps.com
The last post was made 17 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 54.96 Kb
