| binge |
 binge Emo Kiddy
| Phoenix |
 Phoenix Twisted Firestarter
| geordiecbrblo... |
 geordiecbrblo... Trackday Trickster
 Posted: 09:42 - 19 Apr 2009 Post subject: |
Hmmm what about investigating the faults? The fuelling / cutting out won't be fixed with a new engine cos you don't normally get the ancilleries with the engine. The rattle? CCT? 1st gear, strip, clean, re-lube linkages? Might not cost much at all...
If you do go for the engine swap, I'd recommend staying with the 600 - at least the bike can be sold as standard then, rather than spending a lot of cash to devalue / limit the bikes resale.
Just my 2p  |
| Keir |
 Keir World Chat Champion
 Posted: 10:36 - 19 Apr 2009 Post subject: |
| geordiecbrbloke wrote: | Hmmm what about investigating the faults? The fuelling / cutting out won't be fixed with a new engine cos you don't normally get the ancilleries with the engine. The rattle? CCT? 1st gear, strip, clean, re-lube linkages? Might not cost much at all...
Just my 2p  |
id say pretty much the opposite. if youre going through all the hastle of a swap you might aswell get a power boost out of it too. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| Coxyzxr |
 Coxyzxr Brolly Dolly
| sickpup |
 sickpup Old Timer
 Posted: 17:42 - 19 Apr 2009 Post subject: Re: GSXR600 SRAD to 750cc |
| binge wrote: | A mate of mines got a Gixxer 6. SRAD. Bit of an old girl, Overall quite a good bike. But its high mileage and the engines a bit run down.
After a long run, It starts to cut out, And die, As if its flooding out. |
Whats the mileage on it? those lumps are good for 80K+
Either it needs a good service, the fuel filters need cleaning or someone has pissed about with the carbs.
| binge wrote: | Theres an un-nerving rattle coming from the engine. |
Fit a new cam chain and tensioner, you will have change form £100
| binge wrote: | The clutch is shocking. First gear doesn't select 90% of the time. It needs to be really stamped into gear. |
The hole for the pivot bolt in the clutch lever is worn. £10 fix, fit a new lever.
| binge wrote: | To cut a long story short, It would be cheaper / easier to either replace the bike. Or the engine as a whole. |
Very much doubt it.
These are all common problems on the SRAD, cheap and easy to fix. |
| binge |
 binge Emo Kiddy
| Coxyzxr |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:24 - 19 Apr 2009 Post subject: |
seconded. mines on just under 35k and going perfect.
i had a fuelling problem like the one described, but a new fuel pump sorted it.
rattle is likely a CCT problem. £40 for the part from APE for a manual one which is less likely to fail.
the gearbox problem sounds clutch related almost, as when i dont fully disengage the clutch mine doesnt like going into first, but then again, i do prefer the biting point close to the bars.
try keeping downward pressure on the lever and letting the clutch out slightly. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| MaybeGuy |
 Posted: 20:27 - 19 Apr 2009 Post subject: |
sounds like the CCT is rattling as the cam chain changes tension. i personally dont think its the clutch, ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| sickpup |
 sickpup Old Timer
| binge |
 binge Emo Kiddy
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
There is a gap of 248 days between these two posts... |
| acks |
 acks L Plate Warrior
 Posted: 07:14 - 24 Dec 2009 Post subject: |
Normal for the SRAD to battle getting into first.....Its nothing abnormal for this bike. I sometimes stop on mine in 4th, and battles to go all the way down to 1st.
Just an SRAD Issue, clutch, I had the same problem, and the rattle, i got it too, have no clue what it is, but only at high revs. The other chain rattle is your cam chain and tensioner, replace them.
Id stick to the 600 SRAD, im not imressed with the 750 SRAD, there really isnt much difference, and the 600 pulls off faster, I think its because its carbed.
Thats my 2 south african cents worth trust me thats not much over your side! |
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
