Mito back on the road..with yet another problem(electrical).
spitfire123
PostPosted: 22:18 - 19 Apr 2009    Post subject: Mito back on the road..with yet another problem(electrical). Reply with quote
Hi all,
Got my mito done today,if you where reading my previous thread about the starter motor being a bit 'iffy' well it turned out the piston was very slightly to tight for the bore, squirt of wd and she went 1st time no probs!
Anyway as i say went out for a 35 km ride (below 6k) to run her in (stage 1) and on the way home i noticed the lights on the speedo where very fait....i then realised i had no indicators or rear brake light or lights and to top it my alarm on my bike was going off while i was riding it the battery was that low Laughing !at 11pm at night! so was about 1 mile from my house (luckly) with no traffic on the roads and managed to get home saftly.
Now....the last time this happend it was a blown fuse and the alternator wasn't charging the battery to run lights, i looked at the top of the fuse and it was slightly 'singed' at the top, like a rippled effect.
I went back to the workshop (end of my garden) with the bike and took off the seat and the multi meter mesures 10-11v where 5 mins erleyer the indicators wouldent even flash. so it gained 10v in 5 mins???
Anyway i stuck the battery on charge for toninght and changed the fuse ready for the comute tommrow....just hope its okay.
I dident have time to mesure what the altenator was putting out as it was way to late.
Do you all think its defanatly the alt fuse slightly gone?
the battery is 3 days old...and was fully charged before the ride.
cheers all Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
spitfire123
PostPosted: 22:23 - 19 Apr 2009    Post subject: Re: Mito back on the road..with yet another problem(electric Reply with quote
just to add....the bike dosen't turn over...battery to low...solonoid just clicking.
cheers Thumbs Up
spitfire123
PostPosted: 15:55 - 20 Apr 2009    Post subject: Re: Mito back on the road..with yet another problem(electric Reply with quote
right everyone an update...
took it to collage today and got the multi meter on it....battery at 13v(nor running) and running at 6k....12.5v Confused
i then changed the fuses....no differance
the soloniod also went so had to bump it Confused
could the solonoid being knackerd( works occasonly) be the reason its not charging?
as the thick wire comes from the solonoid strait to the positive batttery termainal? or is it nothimg to do with that?
need help asap!as i want to get on with it tonight.....cheers Thumbs Up
spitfire123
PostPosted: 17:05 - 20 Apr 2009    Post subject: Re: Mito back on the road..with yet another problem(electric Reply with quote
Another update,
Made myself take it down the workshop and have a look at it..and this is what i did/found:
Removed the 4 pink clip/ 2 pin clip and bullet clip from what attaches the engine to the loom...the connectors all looked 'okay'.
I then put them all back in and started the engine via starter motor (solonoid now works??) and removed the battery and it ran on its own? so the altenator MUST be working in oder to produce itself a spark? Confused
i belive that the battery charging altenator wires coming from the ALT is the 2 yellow ones on a seporate 2 prong clip....i put a multi meter to them and it read 0V? but as i say engine runs without battery?
all fuses are fine, i changed them all today.
verrrry strage Confused
any help MUCH apriciated Thumbs Up
PostPosted: 19:34 - 21 Apr 2009    Post subject: Reply with quote
Without digging into the wiring diagram now (too tired at this moment), with the engine off you should get a bit over 12V over the battery, going up to about 14.5V with the engine being revved. Much under 12V and not a lot will happen (ie, just because indicators won't flash doesn't mean the voltage is zero or close to it).
Some bikes will quite happily run without any battery or charging (certainly the older Aprilia RS125s). Not sure on the Mito.
With the 2 wires from the stator to the regulator / rectifier you need to check the voltage on those as AC (not DC). Without looking at the manual they probably should have something like 45V AC across them with the engine running.
It sounds like the bike is just not charging, and most of the time the issue is a failed regulator / rectifier.
spitfire123
PostPosted: 12:48 - 22 Apr 2009    Post subject: Reply with quote
hi mate,
is the regulator/reficter the square box underneeth the seat with 4 wires going in to it?
will it just be that tghat is at fualt and not apssing the charge ont o the battery.
wen i rev the engine, the voltage dosent go up AT ALL. just stays the same to the battery?
so what do i have to replace or change as the alternator is clearly working you say?
also the starter solonoid is just clicking now..i have to bump it Confused
cheers!
PostPosted: 13:01 - 22 Apr 2009    Post subject: Reply with quote
Regulator / rectifier will be a small unit with fins on it . 6 wires go to it (2 single wires and 2 pairs). And orange wire, a blue wire and 4 yellow wires. The blue goes to earth, the orange goes to the battery +ve terminal via the battery. One yellow from each pair goes to the alternator and one from each pair goes to the "starter contrl unit".
The regulator / rectifier converts high AC voltage to about 12V DC voltage for the electrical system (regulator part limits the voltage, rectifier part converts to DC).
What is the DC voltage over the yellow wires with the engine running?
spitfire123
PostPosted: 19:40 - 22 Apr 2009    Post subject: Reply with quote
Kickstart wrote:
1)Regulator / rectifier will be a small unit with fins on it . 6 wires go to it (2 single wires and 2 pairs). And orange wire, a blue wire and 4 yellow wires. The blue goes to earth, the orange goes to the battery +ve terminal via the battery. One yellow from each pair goes to the alternator and one from each pair goes to the "starter contrl unit".
2)The regulator / rectifier converts high AC voltage to about 12V DC voltage for the electrical system (regulator part limits the voltage, rectifier part converts to DC).
3)What is the DC voltage over the yellow wires with the engine running?
1) do you mean the ally cooling tower thing mouted to the L/H side of the A-frame?
2)where is th ereficter located?
3) the is no voltage coming from the 1 yellow wires Confused this is exacly what i mean....the engine runs with no battery but cant power speedo or anything BUT it can run itself...so it must be a break in the line?no?
cheers keith Thumbs Up
satans_BIG_helper
PostPosted: 19:51 - 22 Apr 2009    Post subject: Reply with quote
1) Yes its like a small ally block with fins looks like a heatsink from a pc or other cooling block from something similar.
2) regulator/rectifier is the same thing buddy Smile so is most likely the item you refered to in reference to number 1
3) And i believe he meant to test the voltage across both yellow wires with the engine running...
hope this helps
Dave
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
spitfire123
PostPosted: 16:25 - 23 Apr 2009    Post subject: Reply with quote
hope this helps
Dave
yep,
1) rook it to work today and the regulator is fine.
3) i did test acorss the yellow wires running and there is 0v output Confused
i recon it could be a wire has come out insid ethe bloody ALT?
cheers Thumbs Up
spitfire123
PostPosted: 19:21 - 24 Apr 2009    Post subject: Reply with quote
Did a 'beep' continuity test today....negative on the battery and positive on either yellow wiire from the ALT...no beep or nothing?
I take it the poles are fooked or an earth strap maby loose in the alt?
Cheers all Thumbs Up
dougon2wheels
PostPosted: 20:22 - 24 Apr 2009    Post subject: Reply with quote
did you do the meter on the d.c range when you checked the stator voltage (yellow wires) ?,as the output from the stator will be a.c
"beep" continuity test's only tend to beep if the circuit resistance is below 200 ohms,there's a good chance the overall circuit resistance is above that.......your going to need to look at a circuit diagram and check the circuit resistance with a full continuity test(there's also a good chance that the stators windings are not conneced to earth )
spitfire123
PostPosted: 16:59 - 27 Apr 2009    Post subject: Reply with quote
hi mate,
yea AC and it was giving nothing?
and ive looked at a circit digram with no such information on it???
The last post was made 16 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 86.42 Kb
