cagiva mito powervalve issues
9mito3
PostPosted: 19:13 - 21 Apr 2009    Post subject: cagiva mito powervalve issues Reply with quote
hello,
searched all "powervalve" issue and cant seem to find a thread. plsc an ou point me in th eright direction if so.
Powervalue issues:
when i turned th ekey, the servo just kept moving back and fourth!
I bought a new control box and all seems fine, when i turn ignition, it does the test (not that iv seen a propper test but look slike one) then stops.
Great, problem fixed!
i hear the pv kicks in about 8000 revs or so however mine doesnt? i havent attache dit as i guess it make sno difference however the servo does turn if i rev right up?
Now is this likely to be an issue with the servo or the control box?
If its the control box il need to try send back quick sharp as he said it works fully. If its not likely to be this, is it likely to be servo or connections/wires? if wires, which ones do i need to check if at all possible!!??
Also, what controls the servo eg, hwo does it now when it reaches a certain rev pls?
Many Thanks
satans_BIG_helper
PostPosted: 19:21 - 21 Apr 2009    Post subject: Reply with quote
Are the cables from the servo connected to the power valve ?, or badly adjusted, as they do get worn and stretched over time. is the valve possibly stuck
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
9mito3
PostPosted: 19:41 - 21 Apr 2009    Post subject: Reply with quote
Hi, the cables are not attached at all at the moment.
i assume the dont need to be fo rthe servo to operate correctly?
i dotn no how the powervalue nos when to open either? any mor einfo on this would be great also.
Thanks
satans_BIG_helper
PostPosted: 19:51 - 21 Apr 2009    Post subject: Reply with quote
I think you need the cables attached from the servo to the power valve so when it turns on to self test it needs to check the movement and valve poistion if my memory serves me right..
9mito3
PostPosted: 16:43 - 22 Apr 2009    Post subject: Reply with quote
Hello,
no made no difference.
what electric bits are involved for the pv. the servom control box,any thing else? not sure what else it can be hmmm
Thanks
spitfire123
PostPosted: 17:31 - 23 Apr 2009    Post subject: Re: cagiva mito powervalve issues Reply with quote
9mito3 wrote:
hello,
Powervalue issues:
Many Thanks
i had the same problem.....turned out the powervalve was just not attached to its runners and was just floating in the barrol....ended up in smashed piston = NEW TOP END/ powervvalve unit Confused
sort it now matey i smy advice Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
The last post was made 17 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 48.51 Kb
