Do sparkplug electrodes wear away?
tutton
PostPosted: 20:07 - 22 Apr 2009    Post subject: Do sparkplug electrodes wear away? Reply with quote
If so why do they do it?
Ive just whipped the plug out of my RS, and its a BR10EIX and compared it to a BR9ES from my old bike, and the electrode is very very small.
Some pics of the plug, What ya rekon sposes to be like this?
First pic is my plug, note electrode in centre size
https://i123.photobucket.com/albums/o297/Gfxs/DSC00341.jpg
Second pic is comparison plug closest to the bottom is the BR9ES top plug is the BR10EIX
https://i123.photobucket.com/albums/o297/Gfxs/DSC00337.jpg
PostPosted: 20:09 - 22 Apr 2009    Post subject: Reply with quote
I think it may be because someone has fitted an iridium plug to the bike.
tutton
PostPosted: 20:11 - 22 Apr 2009    Post subject: Reply with quote
What that its got a small electrode by getting too hot?
or by plug design?
I cant work out whether the plug is just about to give up from the electrode or not...
PostPosted: 20:16 - 22 Apr 2009    Post subject: Reply with quote
or by plug design?
Plug design.
As you can see, they have smaller electrodes.
https://ecx.images-amazon.com/images/I/51JJXBZBHYL._SL500_AA280_.jpg
Blue_SV650S
PostPosted: 20:19 - 22 Apr 2009    Post subject: Re: Do sparkplug electrodes wear away? Reply with quote
Google that plug, they have small center electrodes!! Wink
But yes, electrodes do wear.
Its the arcing, normally the center electrode goes from flat top to rounded.
tutton
PostPosted: 20:20 - 22 Apr 2009    Post subject: Reply with quote
Ahhh right,
pretty pointless having iridium in a 2smoke tho =/
Running really lumpy atm Laughing
Blue_SV650S
PostPosted: 20:23 - 22 Apr 2009    Post subject: Reply with quote
tutton wrote:
Ahhh right,
2-strokes do get through plugs!! Oil clogging them up/getting into the insulation shorting the plug out is a real problem Sad
tutton
PostPosted: 20:26 - 22 Apr 2009    Post subject: Reply with quote
Thats the thing, this one seems to have clean plugs for a 2stroke, too clean almost.
Was hoping it was why its running like it is,
Only things that have happened just before it was like this was exhaust rewelded up and repainted in high temp black.
Now my bike seems to get alot hotter it got to 90 degrees C today,
only ever peaked 73 before?
Blue_SV650S
PostPosted: 20:31 - 22 Apr 2009    Post subject: Reply with quote
Is the exhaust leaking?
What the exhaust modified in any way?
The excessive temperature could be it running lean ...
tutton
PostPosted: 20:34 - 22 Apr 2009    Post subject: Reply with quote
We had the sides off and it has one tiny pinhole,
had enough backpressure to cut the bike out when hand is over the end of the can.
Exhaust wasnt modified as such just a plate welded over where it had blew a hole.
Im thinking the VHT paint is not letting the heat dissapate out, and as the exhaust port will be near where the temp sender is its getting very hot around that area?
Blue_SV650S
PostPosted: 20:49 - 22 Apr 2009    Post subject: Reply with quote
Humm .
The VHT paint isn't a/the problem!
Has the bike got a powervalve?
tutton
PostPosted: 20:50 - 22 Apr 2009    Post subject: Reply with quote
As far as im aware no,
The bloke said it was full power, but i dont know what they look like although i was aware for powervalve the rave box needs to be in the rear seat unit which it isnt so id say it hasnt.
PostPosted: 21:13 - 22 Apr 2009    Post subject: Reply with quote
It could still have a powervalve though that has been locked in the open position giving you full power.
tutton
PostPosted: 21:14 - 22 Apr 2009    Post subject: Reply with quote
Any way i can tell then?
like obvious things i will know if i see em.
As far as i know its got a Debaffled can, Pipercross foam air filter, and bigger carb.
Blue_SV650S
PostPosted: 21:23 - 22 Apr 2009    Post subject: Reply with quote
Letting us know what the bike is is a good start!! Very Happy
Have you checked the basic things like the coolent level?
tutton
PostPosted: 21:24 - 22 Apr 2009    Post subject: Reply with quote
'99 RS125
Coolant level checked plenty in there..
What else simple is there to check about cooling?
Paulington
PostPosted: 21:28 - 22 Apr 2009    Post subject: Reply with quote
Iridiums in a 2poke make a tiny difference, what we use for my racing, it's almost negligible. On the road, would be impossible to tell the difference.
As for power valves, if it is locked open it will give fuck all power top end. Low bottom end if it is locked down.
When I say bottom/top, 0-8k is bottom, 8k+ is top. You can tell if it's locked just by listening to the engine tone, if it fluffs a bit then goes a lot higher around 8500 revs, your power valve is fine. Thumbs Up
tutton
PostPosted: 21:30 - 22 Apr 2009    Post subject: Reply with quote
I have no real pull under about 6K,
then it takes off, any help?
and something with that exhaust is making it hot im sure.
Blue_SV650S
tutton wrote:
'99 RS125
Did a google, looks like it 'might' Wink
https://www.motorcyclenews.com/MCN/community/Forums/Categories/Topic/?topic-id=353642&message-id=4204519&__ia=message4204519#message4204519
Interesting that it might have a plate in there ... is it possible this plate got disturbed in the re-fitting of the exhaust?
Download the RS125 manual and check the power valve operation if its been fitted!
Its possible the thermostat is sticking ... if the bike is running at 90deg c its not going to be happy ... I think 2-strokes like it about 60eg IIRC.
Bearing in mind you have removed prior to this problem, I'd be taking it off again and looking at the power valve/plate and checking all is well .... if all looks fine, my next stop would be the thermostat ... then the carb ...
All this after trying a new plug obviously!! Wink
tutton
PostPosted: 21:32 - 22 Apr 2009    Post subject: Reply with quote
If the power valve is on the exhaust port hole, we didnt remove anything but the downpipe and can, and refitted it exactly the same?
So im guessing no powervalve there, as there was no solonoid near the port or anything.
Paulington
PostPosted: 21:34 - 22 Apr 2009    Post subject: Reply with quote
Agree with Blue, check out your thermostat, my racing engines are an RS125 engine without the gears and they like it around 55-60, 90 is starting to cook it.
Make sure you have coolant circulating, enough of it.
Check the valve as previously stated, the exhaust won't affect it that much.
MAKE SURE IT IS NOT RUNNING LEAN. And it has enough two stroke oil.
Blue_SV650S
PostPosted: 21:35 - 22 Apr 2009    Post subject: Reply with quote
You didn't remove the powervalve, but you have 'disturbed' that area!!! If you hammered or violently wiggle the exhaust to get it off, this may have been enough to dislodge summin???
Its gotta be worth looking into???
Paulington
PostPosted: 21:36 - 22 Apr 2009    Post subject: Reply with quote
Double post, woop.
If there is no cable coming out from above the exhaust, you have no power valve or at least no solonoid connecting to the valve. Thumbs Down
tutton
PostPosted: 21:39 - 22 Apr 2009    Post subject: Reply with quote
Two stroke full did that yesterday,
it wont be running lean as ive just said its only since the exhaust has been off and repainted its risen in temp,
I use to wait till 65 before giving it any proper abuse, and it would happily peak at 73.
Must have coolant circulating of the headgasket will be warped already.
Just checked no cables above exhaust :S
Blue_SV650S
PostPosted: 21:40 - 22 Apr 2009    Post subject: Reply with quote
Paulington wrote:
Double post, woop.
Indeed and this 'plate' might be moving around in there???
I'm just guessing now, but the OP said it was running rough!
As for the temperature ... trying to determine cause and effect ...
We need to start checking stuff and ticking them off the list!!
It just seems too coincidental it only started running rough after the exhaust was repaired to NOT be somehow related .... so looking there initially ...
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 3.04 - MySQL Queries: 13 - Page Size: 134.76 Kb
