| mjshort |
 mjshort Derestricted Danger
| mjshort |
| ram_doom |
 ram_doom World Chat Champion
| joan33987 |
 joan33987 Renault 5 Driver
 Posted: 17:24 - 22 Apr 2009 Post subject: |
No start have the following reasons:
No spark!?
No fuel!?
No Compression!?
You said it has overheated before, do you think that it might have damaged the piston or piston rings or head gasket? which will make compression poor.
Water pump not working!? contributing to overheating problem?
Yeah, how is the oil?
When was the last time you rode the bike?
Where're you based? I own a 1992 GPZ500s ____________________ current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project |
| mjshort |
 Posted: 22:19 - 22 Apr 2009 Post subject: |
water pump should be fine, it was overheating before my service so they check that too. they changed the spark plugs so they should also be fine, it was starting first time after it was changed too.
ill check the oil tomorrow night see if theres any problems with it. bearing in mind im not a mechanic (most complicated thing iv done is a service and replaced an exhaust) how hard would it be to fix the head gasket or the pistons if thats what the problem is?
based in co durham too.
cheers  |
| Phil_G |
 Phil_G Traffic Copper
| stinkwheel |
 Posted: 01:24 - 23 Apr 2009 Post subject: |
Coolant spitting thing might well be the head gasket. Tends to be rev dependant. If it only spits the coolant over a certain rev speed but behaves below that, I'd be mightily suspicious.
If the coolant hoses get rock hard as it's happening, this would be another warning sign of a blown head gasket.
This shouldn't really prevent it starting though. Try giving the ignition switch a good scoosh of WD40 and work the key back and forth. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 17 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
