Rear Brake....Please Help...!
jakea
PostPosted: 16:29 - 22 Apr 2009    Post subject: Rear Brake....Please Help...! Reply with quote
My rear disc brake has suddenly stopped working...
It seemed to be rubbing that night, and when i come back to the bike in the morning it now does not work at all...
There is fluid in the brakes.
Deos anyone know what it could be...and how to fix it....?
joan33987
PostPosted: 21:00 - 22 Apr 2009    Post subject: Reply with quote
fill us in more, what do you mean by not working at all? when you press the pedal, it goes all the way down, with no brake at all?
brake fluid leaking?
OK, I've never owned a bike with rear disc brake, but isn't there's a way to check fluid level?
current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project
Itchy
PostPosted: 21:03 - 22 Apr 2009    Post subject: Reply with quote
Either a leak of fluid ie no pressure to the back.
The pad surface fell out due to knock off pads causing the fluid gap needing to be filled which pushed it below the hole in the master cylinder.
Or something else easiest way to check is your brake fluid level if it is the same then maybe its something else.
jakea
PostPosted: 22:10 - 22 Apr 2009    Post subject: Reply with quote
yeah i checked the break fluid and there is fluid in there. If it was leaking there would be none in there at all surely..?
when you push down the brake there is nothing it just falls, and i cannot feel it putting any presure on the brake.
Noxious89123
PostPosted: 22:42 - 22 Apr 2009    Post subject: Reply with quote
Check the pads.
EDIT: Just had another thought; Is the brake lever actually moving the piston on the master cylinder, or has the clevis pin gone AWOL?
Harold_Shand
PostPosted: 22:44 - 22 Apr 2009    Post subject: Reply with quote
Sorry for being obvious...
You know there's two resevoirs, one for the front and one for the back? The back one is under the seat.
jakea
PostPosted: 08:38 - 23 Apr 2009    Post subject: Reply with quote
if it was the pads would it have suddenly stopped working..?
And i will have to check the movment on the piston not sure about that.
And yes the break fluid for the rear brake on my bike is right next the the brake lever on my right foot.
clancy
PostPosted: 10:16 - 23 Apr 2009    Post subject: Reply with quote
if the pads have worn down, the break would have slowly got worse over time, not suddenly stopped.
you could have an air bubble or a blockage in the break line if its completely failing ? thats a bit unlikily though.
i think what Noxious89123 said is your best bet:
"Is the brake lever actually moving the piston on the master cylinder, or has the clevis pin gone AWOL?"
good luck.
leigh
KLX 300r
Hello there mandem
PostPosted: 16:05 - 23 Apr 2009    Post subject: Reply with quote
When my break went i blead it through and nothing. Ended up need a new mster cylinder. Blead it through, see if its that, If not seals might have gone.
Try working your way back from the the operation. Ie your pedal. and check everything, Usally works for me.
Jack Thumbs Up
Cigaro
PostPosted: 16:24 - 23 Apr 2009    Post subject: Reply with quote
You say it's been rubbing (I'm assuming you mean dragging). How badly? Could be that you've overheated and boiled the fluid?
Sounds like there's some crud stuck in your seals and your calliper needs to be stripped and cleaned (happened to me recently). Also, if the seals have gone, then air could have got in that way.
jakea
PostPosted: 08:32 - 24 Apr 2009    Post subject: Reply with quote
Thanks everyone for your help i am going to try the things suggestd tonight...
The last post was made 17 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 68.58 Kb
