| russeleoin |
 russeleoin Nova Slayer
 Posted: 21:05 - 24 Apr 2009 Post subject: Yamaha YB100 problem, please help. |
Hi All, I am hoping someone can help with some idea's on a problem I am having. My YB100 (6volt) has been running perfectly for a year now. Last week I noticed when I turned the key on, the neutral and oil lights dimmed quite quickly. When the bike was running all appeared well, but I dont ride too far so it was hard to tell. Thinking I had a poor earth, I have cleaned and proved all of them. The battery is now dead( well damned close, 2.4v) it was new 7 months ago and not a cheapie either. I connected my multimeter and see that upon revving the engine the voltage rises with the revs to around 7.5v so I believe the charging circuitry is working. But the problem is getting worse, unless I speed up the idle, it will cut out and upon riding, it is back firing and only appears to be firing on every second stroke. It has no power. I left the battery disconnected and as it should, the charge rose slowly. I think the battery is good, but am running out of things to try. I checked all the wiring now, it is in very good nic, and the few joins in the wires, I have soldered and covered with heatshrink. I am left thinking that it could be the rectifier, resistor or worst case, the alternator. Any ideas would be fantastic as I have run out, but will need to get to work on Monday!
Thanks and regards
Russ ____________________ I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer. |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:07 - 24 Apr 2009 Post subject: |
fuse ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| russeleoin |
| russeleoin |
| MaybeGuy |
 Posted: 10:01 - 25 Apr 2009 Post subject: |
tried charging the battery?
in the haynes manual on the RXS i owned, it said that the battery should be charged off a charger if long journeys arent taken.
mainly because the 6 volt system is a load of shit and cant really cope. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 15:36 - 25 Apr 2009 Post subject: |
The battery has absolutely nothing whatsoever to do with the ignition system.
Your battery charging problem and running problems are almost certainly not related unless something has taken out both coils on the stator plate (unlikely it would be running at all if this were the case).
So, charging problem could be the rectifier or could be a loose/damaged wire somewhere (Last time I had a charging fault on a YB it was in the wiring for the headlight, which pinches half the charging coil output when on). Don't panic, it's a single phase, half rectified system so it only has a diode in there to act as a rectifier, they only cost a few quid.
For the running problem. Change the sparkplug, check the points, check the plug cap and HT lead, test the coil. Lastly, replace the condeser. It is very unlikely to be a carburettion problem because it's crankcase induction and the carb is well protected.
To replace the points or condenser you need a rotor puller. The one for a Honda C90 fits perfectly and they only cost a tenner. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| russeleoin |
 Posted: 20:44 - 25 Apr 2009 Post subject: |
To get 12v out of it you'd almost need to replace half the bike, not really a viable option.
A Honda C50 one will work. You'd need to change the terminals is all. They cost in the region of a fiver.
Yes, the output is AC if the rectifier is dead. If your meter autodetects, this is what will be happening. Measuring D.C. will probably give you a flatline.
It MIGHT have cooked your battery (it's been trying to charge it backwards half the time) although a battery that holds charge isn't strictly necessary on a YB100.
I'll repeat, this does NOT explain why it is running badly, only why the flashers and dash lights aren't working properly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| russeleoin |
| russeleoin |
 Posted: 15:26 - 28 Apr 2009 Post subject: |
There is no seperate setting for points gap and ignition timing. Setting the gap ought to put the firing point within the correct "window" of acceptable timing.
If the points are badly worn, setting the gap correctly will lead to retarded ignition timing. A black sooty plug with a loss of power are a symptom of retarded ignition timing among other things.
Could also be the condenser, a dead condenser can cause scorching of the points and a weak spark.
Maybe worth checking the air filter is clean and the exhaust baffle isn't too coked up at the same time. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| russeleoin |
| bikedemon99 |
 bikedemon99 Spanner Monkey
 Posted: 21:25 - 28 Apr 2009 Post subject: |
| russeleoin wrote: |
I have just removed the rotor, managed to get my small bearing puller to do the job. The points are definitly worn, it will be good to get them replaced. I hope my strobe works on this so I can set the timing. |
The timing is very much "ballpark". Static timing is almost certainly good enough. With a new set of points, all you in theory ought to need to do is set the gap, by definition the timing should then be near enough correct.
As I say, there is only the means to adjust the points gap. The stator plate does NOT rotate to allow seperate timing adjustment.
Whenever I've done the timing on one, I've just used the old fashioned "fag paper" technique measuring distance before TDC with the "tail" of my verniers down the plughole. (ie. at the firing point, you should just be able to slide a fag paper out from between the points without tearing it.). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| russeleoin |
 Posted: 22:00 - 05 May 2009 Post subject: |
The end of the saga. Well, all my bits arrived, battery, coil, points and condenser. All of which were replaced and guess what, the problem remained!. I couldnt believe it, I nearly cried. I measured circuts and all sorts and still had a problem. The bike would start but would not run smoothly unless it was revving high. I checked everything I could, and the by accident, I pushed on the key while adjusting the idling and the bike cut out. A bit more fiddling the problem was proved, the key switch is faulty, it seems to be arching across to earth. The reason it happens at idle is, that is when there is a bit more vibration, if I held the key still it ran fine. Anyway, I needed the bike for work so rather than replace the switch as I would have had to wait for it to be delivered, I have wired in a small kill switch. So now I use the key switch for lights and the kill switch for engine!. Still I am happy as I was able to ride this morning problem free.
Thanks for all the suggestions.
Regards ____________________ I love classic merc's but bikes take up less space.
The last post was made 17 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
